10-14-2018, 09:20 AM | #1 |
Rep 12,565
Sensitivity to Wheel Spacers
I've run spacers on numerous cars including all my past BMW's but I'm surprised how sensitive the M is to spacers. I recently installed a set of budget brand spacers (same one I used on my Z4 3.0si and e90 328xi) but I felt noticeable shimmy from the steering at 70mph. Thought maybe a wheel weight had gotten knocked off so got all 4 factory wheels & tires rebalanced but that barely made a difference.
Figured maybe the M requires only the "best" so I purchased a premium brand this time around. With regards to install, I'm always meticulous too... wire brush to the face/lip of the hubs, wipe everything down with brake cleaner. Very thin layer of antisieze on inner lip of spacer. While wheel is still off the ground, make sure spacer sitting entirely flat against hub, wheel is centered with hub and then hand tighten the bolts. Put the jack down and torque everthing to 90ft-lb in star pattern. Final verdict: With new spacers, majority of steering vibration is gone but still slightly noticeable at 70mph. I would say 10% still present but really shocked that it wasn't fully eliminated. Anyone else have this issue? FYI both spacers (budget and premium brands) were very tight on the hubs, no play whatsoever. At this point I can't tell if it's STILL the spacers or the spacers are just exacerbating a different underlying issue. But with the 2nd rebalance, not sure what else would cause this. Also the M received fresh alignment few weeks ago with the install of my GC school kit (coilovers, camber plates and new oe FCABs). Vibration does NOT occur during braking so it's not the rotors neither. Only thing I can think of is previous owner didn't drive the car much so maybe it sat for a while and tires developed flat spots? But wouldn't that come up during a balancing test? And could that contribute to a steering vibration at higher speeds? Last edited by 3002 tii; 10-14-2018 at 09:40 AM.. |
10-14-2018, 09:44 AM | #2 | |
Rep 3,004
Spacers
When I purchased OZ Ultraleggera rims from Tire Rack, they included 20 MM spacers (rear only) and longer wheel bolts as part of the purchase. I have not experienced any vibration issues with this application.
Racerbruce
10-14-2018, 09:45 AM | #3 |
1821
Rep 5,337
That’s been my experience as well. The front end on the Z4 M is very sensitive to spacers. Not offset, SPACERS. First thing I noticed after installing the RacingBrake front calipers, since it required a 5mm spacer to clear the spokes, was the increase in vibration.
I’ve noticed that thicker spacers, like the 18mm I’m using for the Apex wheels, aren’t as noticeable. But 5-8mm spacers caused a vibration at highway speeds. I’ve managed to minimize it by keeping the contact area clean but have never been able to complete eliminate it and have just sort of “lived” with it, for what it’s worth. Since the Apex wheels are only installed for track events, the slight vibration at speed doesn’t bother me. Running a squared rear wheels up front does not require spacers for me and that’s the normal “street” setup now.
10-14-2018, 09:49 AM | #4 | ||
Rep 12,565
Perhaps 12 isn't thick enough 'drown out' the slightest imbalances... Like I said it's way better than before and I can definitely live with it. Just confused more than anything that the M's front end is so sensitive. |
10-14-2018, 10:47 AM | #5 |
Rep 874
I use 5 mm on all corners on mine, never had any problems. H&R spacers.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
10-14-2018, 12:13 PM | #6 |
Rep 1,688
I have had a shimmy in the 80-90 mph range on the highway.
Running 20mm on all four corners (non-m) but I don't recall if I have driven at those speeds since we installed them. My vibration is on the passenger side rear. This thread actually reminded me to revisit this issue. I hope you figure it out soon. |
10-14-2018, 02:13 PM | #7 |
Rep 1,031
I didnt notice any vibration or issues running 12m spacers up front on stock rims to get around the BBK.
10-14-2018, 04:01 PM | #8 |
Rep 355
yes, my M is the same way, and it's only at highway speeds. I had a 2.5i e85 before this, and never had the problem. Once i torqued the studs evenly, it seemed to go away. Every once in a while i get a tiny shimmy, but it's tolerable.(3mm all the way around)
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
10-15-2018, 03:30 AM | #9 |
Rep 375
I've got 10mm H&R hubcentric ones on the front of mine (to clear Porsche Brembos), and I've not noticed anything at 140mph+.
But that could just be my fat fingers/ass absorbing everything |
10-15-2018, 06:19 AM | #10 | |
Rep 932
10-15-2018, 11:30 AM | #11 |
Rep 2,782
Based on your previous post, it sounds like the spacers are 12mm. Did you install extended length bolts too?
Have you considered a stud conversion? I only have spacers in the rear of one of my M's but no vibration. I haven't tried spacers in the front yet.
10-15-2018, 11:38 AM | #12 |
Rep 874
Have you replaced your FCAB? They might be the culprit, spacers will enhance the problem.
10-15-2018, 04:29 PM | #13 |
Rep 932
I installed Apex extended studs. Same problem. I have to buy new set of wheels to eliminate need for spacer.
10-15-2018, 10:14 PM | #14 | |
Rep 758
Top Down 365
10-15-2018, 10:44 PM | #15 | |
Rep 12,565
So the new "premium" brand spacers I have are Apex 15mm (latest design). And I am running GLS TopStud 82mm extended studs. |
10-16-2018, 06:43 AM | #16 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Can confirm, always had vibration when running spacers on the front end, ran them when I had the M225 wheels on for street.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
02-02-2020, 11:31 AM | #17 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
02-04-2020, 08:20 PM | #18 |
Rep 175
You need hubcentric spacers with the lip extended to the wheel center bore. At that point the feel is the same as the wheel itself because it is machined to the same hub diameter that transfers to the wheel hub itself unless the wheel is not perfectly centered in the hub it should be no different with or without the spacer.
02-04-2020, 09:33 PM | #19 | |
Rep 165
However as we can only drive one car at a time, and it can be some weeks between drives if the car is garaged with warm tyres, a flat spot becomes evident on the cars next outing. A quick high speed gallop soon rids the car of those |
02-06-2020, 01:30 AM | #20 |
1621
Rep 4,294
I would assume that someone with the skills of Ti, would know about the hubcentric spacers. I wouldent use anything without. Currently ran 12mm hubcentrics at the front, zero shimmy. No issues. Going to be running quite a bit larger spacer on the front when my car is back on track. Ill be getting mine custom made, and off coarse.. hubcentric.. I did have a massive shimmy a year or so ago, that i finally traced down to one of the front tires having a delemination. (astetically the tire looked fine)
Powered by |
