12-08-2023, 02:59 AM | #1 |
Rep 7
2013 bmw 328i x drive reliable?
Hey so I am looking at purchasing my first BMW. The one I have found is a 2013 328i xdrive and it has 127k miles. The person told me that the timing chain has been replaced in 2021 and a brand new turbo this year with all oem BMW parts. I know the timing chain had issues so knowing it was replaced makes me feel better but I am not sure if this is a vehicle I should stay away from or not. They are asking 9k but I believe I can get them down to 7500-8000 range. Any information and recommendations would be greatly appreciated.
12-08-2023, 03:36 AM | #2 |
Rep 2,774
i would recomend you to look for similar 328d or x3 f25 2.8d instead
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
12-08-2023, 08:09 AM | #3 |
Rep 64
I had a 320xi from 2013. I traded it with 110K miles in 2019. There was really nothing wrong with it and it was a solid car. I would check all of the hoses and plastic parts in the engine bay as they start to degrade after 10 years and at that age it always worth a look over by a qualified mechanic.
12-08-2023, 09:23 AM | #4 |
Rep 537
I've got 100k on my 2014 and have had no serious issues. I work on the car myself so I inspect it every Sunday morning. I do an oil and filter change every 5k miles or 3 months.
Things I've done to date: Head unit failure (the stereo/CD player), replaced with a used one. (That did require coding) Valve Cover Gasket Oil Filter Housing Gasket Coils/plugs/filters Cooling system refresh Control arms struts/shocks Issues with the car are a chronic failure of the passenger door to lock. It will be unresponsive for several attempts then will start working. Chronic temporary failure of the left rear tail light/brake light/ turn signal. This is a known issue with the pin connection. I have a replacement in my tool box, but it's been working lately so I haven't been motivated to get out there and re-pin the new connector.
12-08-2023, 01:07 PM | #5 |
Rep 297
I'd stay away from early N20 engines - you can google their issues. BMWs at 125k miles will need maintenance. If you're looking at cars in (I'm guessing) a $10k or less pricepoint, an older BMW will probably be more maintenance than you'll be comfortable spending.
You should budget $1500 / year in maintenance for a 2013 328xi w/ 125k miles. If you're pretty set on a BMW, you'd be much better off getting a 2012 with an N52 inline 6 engine. |
12-08-2023, 07:32 PM | #6 | |
Rep 2,680
12-10-2023, 07:58 AM | #7 |
Rep 604
I agree with this statement. The N20 cars are usually cheaper than the rest given same model year. Same goes for early N63 cars (550s and others) they seem cheap and are fast but oh boy this engine is tragic if it comes to reliability. I would stick to non turbo well maintained car with 3.0 N52. If you’re on a tight budget keep in mind it’ll cost some money to get this car to where it should be. With above milage most of suspension components are done.
12-10-2023, 08:43 AM | #8 |
BMW Owner Since 1971
2276
Rep 1,422
Drives: 1964 700 Sport Cabriolet
12-10-2023, 01:09 PM | #9 | |
Rep 7
12-10-2023, 09:23 PM | #10 | |
Rep 604
Ac compressor will probably ho out at around 120-150k. I’ve never had electrical problems with any of my BMW’s. Water pump is electric. If you find one with 5-6k miles oil changes it should be fairly reliable. Keep in mind though. It’s not Toyota or Honda. It needs attention from time to time and once you hear/see something it needs to be addressed as quickly as possible. If you don’t work on your car or don’t have decent shop knowledgeable with those cars you will not like it. Plenty of repairs are shown on YouTube. This Engine has magnesium block it leaks in general Bmw fashion. Valve cover gasket oil filter housing gasket and oil pan gasket are common. If left not repaired it will come and bite you. If you are tight on your budget look elsewhere. |
12-10-2023, 09:44 PM | #11 | |
Rep 7
I appreciate all of that! So I have found a 2012 bmw 328i x drive with the n52 and it has 160k on it but the thing looks like it came off the show room floor. The guy has every maintenance record. Hasn’t driven it in the winter. He has had the valve cover gasket replaced, oil pan gasket replaced, replaced all the plugs and has changed oil every 5k miles. I have him down to 6k on this car. Would this be one you would buy or would you stay away with it having 160k on it? It is a very beautiful car |
12-10-2023, 09:48 PM | #12 | |
Rep 604
12-11-2023, 07:51 AM | #13 | |
Rep 7
12-11-2023, 02:26 PM | #14 |
Rep 3,058
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Do yourself a huge favor and get the 2012 E90.
If it is as clean and well maintained as you say, it will be a great car for you. Still lots of regular maintenance items all cars have, and some additional BMW specific ones like oil gaskets. But the E90 platform is perfection, you can update the iDrive to Android or Apple play if that's a desire. Everything is typically fixable on them, and a huge community here and on YouTube to figure out problems. I'm biased, and this is based on anecdote and personal experience, but I think you'll like the E90 more. |
Efthreeoh17430.50 |
12-12-2023, 03:34 AM | #15 | |
Rep 2,774
but with a such mileage you have to check if all recalls are done, because vanos bolts should be done, PCV heater (last well known recall) and after that you have probably be ready to replace water pump, head cover, that all will cost around 2k at dealer also xdrive can take its own maintenance, and if you location have no winter, i've tried to avoid car with xdrive with a significant mileage
