10-11-2010, 09:31 PM | #1 |
Rep 156
Any suggestions on alignment for street/autox with Turner camber bolts?
I just installed the camber bolts/shims ($15 kit) from Turner. Now I need to get it aligned. I run Autox events 2-3 times a month and street drive the car 3-4 days a week. I have a second set of wheels with Hancook RS3's for autox (245 square) and have my regular wheels I street drive on with stock tires and stock stagger.
I was thinking of running -2.25 to -2.50 front camber if I can get it with the bolts to help reduce understeer and promote better tire wear for events (I know I will wear the insides of my street tires a little) and keep it drivable on the street without any bad effects. I don't know what to run in the rear with this setup. Also not sure about the toe but .05 seems to be popular. I am open to any suggestions for someone who had done something similar as far as the specs, I need to tell the shop what I want. |
10-11-2010, 11:55 PM | #2 |
701
Here are few threads on this one:
http://www.zpost.com/forums/showthread.php?t=422123 http://www.zpost.com/forums/showthread.php?p=8091235 If memory serves you're right on the toe. Of course, the closer to zero the better for tire wear, but there are trade-offs naturally. Might want to see if the mods can join this thread to the one by dekaliber (same topic).... |
10-12-2010, 05:34 AM | #3 |
Rep 1,143
To share some information gleaned from the internet (FWIW):
Front Toe-Out Just Right Reduced understeer at turn-in Improved steering response Counteracts natural tendency for front- and all-wheel-drive cars to toe-in under throttle load Too Much Instability during braking Straight-line instability, especially over single-wheel bumps or split-traction surfaces Unrecoverable understeer (I think this might be a typo -- I would think too much toe out would mean oversteer) Front Toe-In Just Right Generally helps make the car feel more stable Too Much Wandering under braking Refusal to turn in or rapid turn-in followed by understeer Rear Toe-Out Just Right Easy midturn rotation Less front tire load Too Much Violent on-throttle oversteer on RWD cars Can help drift cars Violent lift-throttle or trail-braking rotation Rear Toe-In Just Right Easily controlled power oversteer in rear-wheel-drive cars Too Much Sluggish response Midcorner understeer Instability at turn-in I'm planning on running as little camber as I can with 2 washers, with alignment pins in place, which should get me to -2 to -2.2, with somewhere between 0 and 0.05 toe in. AFAIK toe setting affects tire wear much more than camber, with toe-in tending to wear at the outside and toe-out increasing wear the inside. |
10-12-2010, 09:31 AM | #4 |
Bimmer Noob
30
Rep 566
Running -2.5 camber Front, 0 Toe with 2 washers; -2.0 camber rear. After last autocross, going to take out one washer which should put me at -2 camber.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
10-12-2010, 12:04 PM | #6 |
1820
Rep 5,337
Here's what you can do. Align the suspension with 2 washers (that's nearly 1 full degree of negative camber added) for the street. If you have the alignment pin pulled, at furthest out point you'll probably get about -1.5 to -1.7 degree of negative camber with about 1/16" toe-in. Suitable for street use while not too aggressive on the tires. At auto-cross or track events, push the strut all the way in to get to -2.5 to -2.7 (they don't have to be even). With the negative camber pushed up, you'll get zero to slight toe-out which will aid in steering response. Mark the top of your strut tower with a permanent market to indicate where the street alignment is at.
10-12-2010, 02:36 PM | #7 |
Bimmer Noob
30
Rep 566
The -2.5 camber has greatly helped the understeer during autoX, but the tire wear is noticeable.
I was planning to do exactly what The Hack was suggesting, but my front end was off by .5 from left and right already. Have to pull a washer to be able to adjust one side down from -2.5 (ie, one side is all the way in, the other all the way out). Marking the range you have from adjusting the top is the best way to mix settings for autoX and street. Well, until you go camber plates, which I'm sure you can't in your category.
10-12-2010, 08:18 PM | #8 |
Rep 156
All good info here. NTB will do a 1 year alignment where I can have it re-aligned at will for one year to change my specs, they confirmed it when I asked and told them these will not be factory specs. Anyone use them for alignment?
I will probably shoot for -2.25 to start with .05 toe out? Maybe have the rears at -.5 less so -1.75? Don't know about toe for the rear. I do like the idea of just moving the struts but having toe in for street use, is that ok? |
10-13-2010, 03:09 AM | #9 | |
701
10-13-2010, 09:42 AM | #10 |
1820
Rep 5,337
10-13-2010, 07:13 PM | #11 |
701
10-14-2010, 06:42 AM | #12 |
Rep 156
I ended up at a performance shop to get it done. I told him what I was using the car for and he had some ideas and then called tc Kline and turner to get their opinion. I ended up with -2 up front and -1.5 in back. Zero toe in front. He said this was recommended for stock suspension. It was $135 for 1 year alingment.
10-14-2010, 06:51 AM | #13 |
Rep 156
He said I was -2.5 when I came in with the 2 washers. He actually took one out and replaced it with a thinner shim. He races an e36 m3 so he should know our front end.
So I guess I was around -1 before I installed the shims. |
10-14-2010, 07:08 AM | #14 |
Rep 11,667
FWIW, I found this site for shim washers.
http://www.washersusa.com/shimf.html
10-14-2010, 07:38 AM | #15 |
Rep 1,143
My company has a huge selection of shim washers so I was thinking about going that route myself -- I may still depending on how the alignment turns out. The standard shims (similar to those sold on the washersusa site) all have an OD of 3/4" (19mm) for the ID 1/2" sizes, whereas the washers have an OD of 24mm. Not sure how important the difference in bearing surface is in this application — it may be a nonissue. We also have "wide rim" shims where the OD is increased to 7/8" (22mm), but the hardness rating is reduced to RH B65 vs. the B85 of the standard shims and the B90 minimum of the hardened washers. Again, not sure if that matters much at all in this application.
jbh, do you remember what his toe recommendation was for the back? Would be interested in hearing your impressions of how the car handles with your setup. |
10-14-2010, 11:53 AM | #16 | |
1820
Rep 5,337
I'm not a material engineer or scientist, so I would only offer a guess that the material strength, stretch characteristics should all be equivalent to the factory washer. |
10-15-2010, 11:30 PM | #17 | |
Rep 156
Car drives fine, tracks fine in a straight line. Feels a little more planted or stable in the turns but I have only been on the street so far. I plan to do an autox next weekend to try it out. On the street I don't feel any compromise over stock alignment. He did say my rear toe was out of wack, both pointing to the right a little when I brought it in. |
10-15-2010, 11:52 PM | #18 | |
Rep 1,143
02-06-2011, 05:36 PM | #20 |
Rep 1,135
