04-21-2021, 08:42 AM | #1145 |
Rep 474
Drives: F36 440i GC
It's quartzite, named Platino.
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
04-21-2021, 12:44 PM | #1146 | |
Rep 755
vreihen1615336.00 |
04-21-2021, 01:59 PM | #1147 |
Rep 2,647
Drives: 2019 BMW 540
04-21-2021, 02:47 PM | #1148 |
Rep 3,032
We went from old school granite to a very reputable brand of man made quartz and the granite absolutely SHITS all over it. Granite is far less likely to stain and is far harder, wife already chipped the quartz.
04-21-2021, 09:53 PM | #1149 | |
Not willing to take advice
4053
Rep 1,528
If you're having chipping issues, staining, or can't set a hot pan on it...you don't have quartz. |
04-22-2021, 06:33 AM | #1150 |
Rep 4,821
Agree that quartz is harder and nonporous so less likely to stain, but granite is more heat tolerant. You don’t want to place a hot pan directly on quartz.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 Last edited by RickFLM4; 04-23-2021 at 09:04 AM.. |
04-22-2021, 07:41 AM | #1151 |
Rep 3,032
04-22-2021, 07:53 AM | #1152 |
Rep 2,043
Drives: 2022 X6///M Comp
Found this online.
The biggest difference between quartz and quartzite is that quartz is a man-made material, while quartzite is a natural stone. A quartzite countertop begins as sandstone, which under a natural process of heat and pressure is fused with sparkly quartz crystals to form quartzite. Quartzite typically comes in shades of white or light grey, but minerals in the stone can lend pink, gold, or reddish-brown hues. A quartz countertop is engineered with the same quartz crystals found in quartzite, but a man-made process binds the crystal with resins, pigments, and other materials such as bits of glass. This process results in a very durable, non-porous countertop material that comes in a wide variety of colors and designs. Aside from the different composition of these two materials, the stylistic differences are quite striking as well. Quartzite is often mistaken for marble or granite, as it has the delicate veining of marble and similar coloration and patterning to some granites. Those seeking a natural look with lots of movement may prefer a quartzite countertop. Quartz on the other hand, can be made to look like any stone, and is offered in many different shades and patterns. If you have a specific color in mind, or want a consistent pattern throughout your slab, a quartz countertop is probably a better bet for your home. Another big difference between quartz and quartzite is the care routine and durability of each material. The binding process makes quartz extremely durable as it helps to extract air, making quartz a hard surface that is non-porous, and therefore resistant to chipping, scratching, and bacteria. Quartzite is a fairly hard stone, but it's less dense than quartz and susceptible to easily staining in a heavy use area such as the kitchen. Quartzite requires sealing to prevent staining the surface, while quartz needs virtually no maintenance.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
04-22-2021, 12:33 PM | #1153 |
Space Force - 4 Star General
11466
Rep 3,264
Anyone else here stunned by the costs of raw materials, especially lumber? I'm constructing a small "shed" to store and season split firewood. Making it mostly out of cedar, repurposed from a fence I tore down. I need a couple of 2x6 for the rafters and some plywood for the roof sheathing. 2x6 cedar is $11 a linear foot and 1/2" doug fir ply is $60 a sheet! WFT?! Guess I'm using pressure treated 2x6 and OSB chipboard for the roof. Sheesh.
04-22-2021, 01:16 PM | #1154 | |
Rep 1,965
DETRoadster11465.50 Buug95917439.50 |
04-22-2021, 01:26 PM | #1155 |
Rep 1,189
04-22-2021, 01:29 PM | #1156 |
Recovering Perfectionist
15336
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
There was a story on our local TV news this week about wood shortages from the COVID construction and home improvement project boom adding $25K to the cost of new houses these days. If memory serves me correctly, the demand for lumber was up 70% and pushing the prices up.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
04-22-2021, 01:37 PM | #1157 | |
Rep 1,247
MPOWER52664753.00 DETRoadster11465.50 King Rudi13154.00 RickFLM410981.00 Marmugmotleocay1568.50 E92 M Sport286.50 S1nner126.00 jmack548.50 |
04-22-2021, 03:39 PM | #1158 | |
Rep 145
I just replaced a 55’ section of fence that the wind blew down, and it cost me 2x as much as the 110’ section I replaced 8 years ago.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
04-22-2021, 04:13 PM | #1159 | |
Rep 873
Wha' da ya mean? No brakes never stopped anyone before!
DETRoadster11465.50 |
04-22-2021, 06:04 PM | #1160 | ||
11466
Rep 3,264
04-22-2021, 06:38 PM | #1161 |
Rep 873
The plus side is that you have the land. Something to consider though happened to me years ago. I bought a large lot, about 4.5 acres, and sat on it for a few years before building. The problem I ran into was nobody wanted to give me a mortgage because I owned the land outright. They didn't want to be holding a mortgage without claim to the land the house was sitting on. You might want to check into that with your lender of choice just so you know where you stand.
04-22-2021, 07:11 PM | #1162 | |
11466
Rep 3,264
Buug95917439.50 |
04-22-2021, 07:17 PM | #1163 | |
Rep 873
04-22-2021, 07:29 PM | #1164 | |
11466
Rep 3,264
Our lender is just wrapping up a refi for us on our primary mortgage + the HELOC we used to help buy the land. They will roll that all up into a new mortgage at a low rate, then when the time is right do the construction loan and the mortgage on the new house. By keeping it all in-house they make more money and we save as they are able to extend better rates and lower closing costs as they have more of our business. |
Buug95917439.50 |
04-22-2021, 07:40 PM | #1165 | |
Rep 873
DETRoadster11465.50 hooligan_G016430.00 |
04-22-2021, 08:12 PM | #1166 |
Rep 1,247
lol3
Buug95917439.50 IllSic_Design2124.00 vreihen1615336.00 DETRoadster11465.50 ramman434712.00 Kilabyte3948.00 |
