      03-14-2022, 08:14 PM   #1
stephenkirsh
Drives: Z4M, E46 ZHP, E46 ZSP, NA MX5
Tekarbon spoiler attachment
I got my spoiler today. I had assumed some 3M automotive tape would be used to attach it, but I was expecting the bottom of the spoiler to be fully flat. Instead, it's empty except for a thin line on each side.
Do I need to just cut said tape to size, or does somebody make an automotive tape that'll work for this?
His: 07 Z4 M Coupe - 05 330i ZHP
Hers: 04 330i ZSP
Sold: 04 325i M56 SULEV, 95 NA Miata
      03-14-2022, 09:39 PM   #2
ToddBlack88
ToddBlack88's Avatar
595
Drives: 2007 Z4MC 2010 F650GS
See if yours site flat before trying to attach it. Mine didn’t.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab,
      03-15-2022, 03:49 PM   #3
stephenkirsh
How flat is flat? Should it be 100% perfect?
Did you get a replacement from Tekarbon?
Hers: 04 330i ZSP
      03-15-2022, 04:35 PM   #4
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Same here. I binned mine. Big waste of money.
      03-18-2022, 12:27 AM   #5
ToddBlack88
595
IMO it should fit perfect. It’s a replica of the OEM one and should fit like it.
Mine didn’t fit correctly. It didn’t curve to the hatch lid, so the ends stuck up. It looked terrible
      03-18-2022, 09:28 AM   #6
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
I got my spoiler today. I had assumed some 3M automotive tape would be used to attach it, but I was expecting the bottom of the spoiler to be fully flat. Instead, it's empty except for a thin line on each side?
I'll shoot a picture of mine in the garage this evening, got your PM note.
      03-19-2022, 01:37 PM   #7
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Install was done ages ago (before 2015) by an independent BMW specialist. It is not flat at the very edge (driver and passenger).
      03-19-2022, 03:04 PM   #8
Willy Sea
That is just an awful fit, frankly not good enough
      03-19-2022, 03:23 PM   #9
grannyknot
grannyknot's Avatar
951
Drives: 2008 Z4M coupe
If you had taken that spoiler to a body shop to install they would have sanded the center down so you got a tight fit all across. It is pretty easy job to do if you have access to a floor mounted belt sander, I guess it could also be done with a hand held sander but you would have to do multiple test fits to make sure you weren't taking too much off in one area.
When done, seal up the raw surface on the bottom with that new rattle can 2 part clear coat and you're done.
2008 E86 M coupe
      03-19-2022, 03:43 PM   #10
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Y'all care a great deal more than I do, purchased the car with it installed and never thought twice. Certainly could be massaged to perfection, however that gap is mostly due to no servo tape being present in that final half inch. Having a larger flat surface the full length of the trunk would certainly create more chances for poor fitment. Tolerances on mass produced pieces…
Quick google search shows similar fit for Tekarbon applications on the Z4. Same since day one
https://www.zpost.com/forums/showthread.php?t=266560
      03-20-2022, 05:55 AM   #11
grannyknot
grannyknot's Avatar
951
Yeah you're right, it's not very important but if I can't drive the car yet I might as well talk about it. Spring is almost here.
2008 E86 M coupe
86Zed932.00
wdb4732.00
