      12-02-2018, 01:44 PM   #1
rueyme
Drives: red z4
H&R 5mm spacers for BMW with extended lugs
USD 45.00
I'm selling a pair of 5mm h&r spacers I put on my z4m to test fit for new wheels I put but they were not big enough to space out my wheels.
It was only mounted once and driven around the block. Still like new.
Wheel Spacer Set (5mm) (Black) by H&R
H&R DR Series Wheel Spacer
Spacer fits between the wheel and hub. Requires the use of extended wheel bolts or wheel studs. Also requires the use of the OEM wheel hub to center the wheels.
Spacer Thickness: 5mm
Bolt Pattern: 5 lug x 120mm
Center Bore: 72.5mm
Wheel Bolt Thread: 12x1.5
Asking 45+ shipping for the spacers plus the extended bolt lugs.
      01-18-2019, 02:16 AM   #2
rueyme
Drives: red z4
btt any takers?
