06-26-2020, 06:08 PM | #1 |
Rep 12,565
Help Diagnose CEL Bulb Out on Cluster
I have a bizarre issue that I cant figure out. I went to a local inspection facility to get my emissions renewed but was surprised to hear that I failed... not b/c of any OBD monitors readiness or aftermarket cats. The issue was that my CEL dash bulb was not functioning, mind you there were no actual codes to set it off. But the operator will flip the ignition key on/off to see the dash lights are working as they should. Every other light worked except the CEL.
I've checked all the fuses and they all seem fine. Are the codes I'm seeing not related? Is it possible that the short from few months ago damaged the CEL bulb (and only that bulb and no others) on the cluster? Edit Seems to be tune related. Flashing back to factory shows the SES light working. Need to talk to my tuner to see if he can enable the SES light for the header tune. Last edited by 3002 tii; 06-27-2020 at 08:22 PM.. |
