      06-05-2020, 06:40 AM   #1
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Quickjack
Accidently posted in this section but any way got for myself Quickjack awesome lift for home use
      06-05-2020, 06:53 AM   #2
bwright657
bwright657's Avatar
258
Drives: 08 Z4 M Coupe
I've been on the fence about getting one for a while. Which one did you get?
      06-05-2020, 07:07 AM   #3
AK72
AK72's Avatar
Quickjack BL-7000SLX but I think 5000 is better option for our cars, 7000 a bit too long but no problem as you can see
      06-05-2020, 12:03 PM   #4
chickdr
Drives: 2006 M Roadster
It seems like the 3500 would do just fine... It says its for shorter wheelbase cars.
https://www.quickjack.com/car-lifts/bl-3500slx/
      06-05-2020, 01:40 PM   #5
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
3500 is just fine - most of the Costco/etc deals are on the 5000 model. Can confirm both work
Older Model
Newer 5000 model
      06-05-2020, 02:26 PM   #6
SD ///M4
///Multiple
SD ///M4's Avatar
I bought the BL-5000SLX model at Costco for $999 about 1.5 years ago. It works for all three cars, the 2016 M4, the 2018 M3, and the 2006 Z4 M Roadster. I've done oil changes on all three cars and have done multiple brake pad swaps on the M3 & M4 getting the cars ready for track weekends. It beats having to drive up on a couple of planks to get the car high enough so that you can get the car up high enough to use even a low-profile jack, then jockeying with the jack stands, then doing the rear, etc. I can have any car 20" up in the air in 10 minutes.
The BL-3500 model would probably be fine for just a Z, but then you're limited in the future if you get a larger car. For the price difference you're better off getting the BL-5000.
Make sure that you get the newer QuickJack Wall Hangers Set that lets you hang the ramps on the wall. I used a couple pieces of cord and made a sling so that I can also hang one hose on each hanger. (Click for link)
David701567.00
T-Bears42.50
3GFX722.50
      06-05-2020, 06:24 PM   #7
pungo
pungo's Avatar
I also purchased a Quickjack BL-5000 from costco for $999. I've used is many times and have been impress with how quick it is to set up and put away. I agree the BL-3500 would work fine for the Z4, but it limits you for use on heavier vehicles. I've used it on my Z4MC, 525i, X3, 4runner, Corrado and S10 pickup. Note: the 525i lift points are too far apart by a few inches for the BL-5000SLX and the quickjack fame extension accessory is $265 shipped, so I made extensions from some 2x8s that work perfectly.
I didn't know about the wall hangers, they must be new, cause I didn't see them on their site when I bought mine over 1 year ago. I might look into getting a set.
      06-05-2020, 07:34 PM   #8
SD ///M4
///Multiple
SD ///M4's Avatar
I only saw them in a video a couple of months ago but they've apparently been around for awhile. As soon as I saw them I ordered them immediately. I had the ramps standing on end in a corner with a couple of eyebolts and a chain with carabiners to hold them in place, but these are way better, as long as you have space on a wall and can mount them directly into a stud.
Only a couple of nits, they should have been gloss black to match the ramps and the hooks could have been a little wider so that you could also hang the hoses from the hooks. As I mentioned, I made a sling out of some cord and I hang the sling from the hooks. Some day, if I have absolutely nothing else to do, I may take them down and spray paint them.
      06-10-2020, 07:16 PM   #9
pungo
pungo's Avatar
I don't mind the hangers not being black. If I designed it, there would be L-brackets on the top to hold a small shelf for the power unit and hooks to hold the hoses. I might ask for a set for Christmas, unless I fabricate something better before then
      06-10-2020, 08:21 PM   #10
SD ///M4
///Multiple
SD ///M4's Avatar
I'm old and feeble, I probably couldn't lift the hydraulic pump up that high! It's bad enough moving the ramps around.
      06-10-2020, 09:26 PM   #11
David70
Plan on buying some relatively soon. Seems like a reasonably priced, useful tool. With the weight ratings I will go with the 5000, just to make it useful for more cars.
      06-11-2020, 12:55 AM   #12
pungo
pungo's Avatar
I here ya, I'm old too, but over 6' tall and currently keep the pump on a shelf about head high, so it'd work ok for me. Come on, the jacks have wheels
SD ///M42992.00
      06-22-2020, 06:49 PM   #13
pungo
pungo's Avatar
Used them on something a little heavier. Job was entire drivetrain fluids and F&R brakes. Here's some pics showing the versatility (note the tool creeper, it's really useful to keep your tools with you).
      07-24-2020, 12:16 PM   #14
pungo
pungo's Avatar
Today only, home depot has quickjack accessories on sale. Picked up the hangers for $27 shipped. Was looking at the suv/truck height adapters for my pickup, but even @ $200 shipped I'm not sure, I've been using sections of 4x4s.
https://www.homedepot.com/SpecialBuy/SpecialBuyOfTheDay
      07-24-2020, 04:55 PM   #15
SD ///M4
///Multiple
SD ///M4's Avatar
That's a great deal and free shipping too!
      08-03-2020, 04:49 PM   #16
David70
Costco has the SLX 5,000 capacity with pinch weld blocks and wall hangers on sale for $1199
      08-10-2020, 11:01 PM   #17
pungo
pungo's Avatar
Wow, price increase, they used to go for $999 without the extras. Don't think the extras are worth $200 more considering I just got the hangers for $27 shipped you don't need the pinch weld blocks for the BMWs
      08-11-2020, 12:48 PM   #18
David70
Agree on the price increase but I think still by far the cheapest place to get it. Quick Jack sells this model direct for $1416 without the extras.
      08-11-2020, 01:23 PM   #19
SD ///M4
///Multiple
SD ///M4's Avatar
This was my first impression when I saw the price and the bundle contents.
Regretably true.
      08-11-2020, 07:05 PM   #20
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
That might be for the SLX3500.
      08-13-2020, 06:15 PM   #21
pungo
pungo's Avatar
No, the $999 price was for the 5000SLX before the increase with the bundle.
David701567.00
      08-16-2020, 02:39 PM   #22
pungo
pungo's Avatar
Another home depot "today only sale" on QJ and other automotive equipment.
