      01-02-2013, 04:57 AM   #23
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Originally Posted by Beedub View Post
John how thick is the plate???
I've used 5.5mm bar.
      01-02-2013, 09:08 AM   #24
Beedub
oh woooo, thats thicker than i thought........ using that 3m resin that should be seriously strong.....
      03-23-2013, 08:58 PM   #25
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Got my ARBs ordered and some Scotch Weld DP-420.
...will update when I get these in.
      04-05-2013, 10:55 AM   #26
Gallardo Rosso
Drives: 2007 Z4M Coupe
I'm a big fan of 3M DP-420 (it's also available in black). I don't recommend it for this application. It's a great adhesive with really good peel strength, but those properties require it to be kind of soft and creep under continuous load(bolt clamp). I recommend a metal filled epoxy like JB weld. It's cheaper and more readily available and should have much less creep.
If you want something a little better you can spring for the titanium filled "repair" epoxy from Devcon.
      05-20-2013, 07:38 AM   #27
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Update
I just did this reinforcement this weekend.
When you get into it, you can see why these fail.
The gauge of metal used is very thin.
They rely on putting a profile on the metal to add strength (it's not a flat surface)
This makes it more suitable to expoy because it fills the profile under the flat reinforcement plate.
After getting into it, I agree with above, something like JB weld would work just fine.
I upgraded to the H&R ARBs as well so we'll see how these stand up.
      07-27-2013, 08:08 AM   #28
3002 tii
3002 tii's Avatar
2288
Bump, does anyone know if the measurements provided here are the same for a non-M (3.0si)? I assume they are because both M and non-M share the same p/n 31351094552 for support bracket #3 in diagram below:
Follow for latest mods
      07-27-2013, 09:22 AM   #29
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'm sure they would be the same.
I can't see then making the frame different just for the M.
      07-27-2013, 01:34 PM   #30
Incompatible
Drives: 07 AW Z4C 3.0Si
Frame mounting points are the same between Si and M as inTgr8r points out.
      01-05-2016, 01:56 AM   #31
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
sorry...reviving the thread...did you end up making a diy?
      01-05-2016, 08:42 AM   #32
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No, most of the info is contained in this thread.
I think I have a few pics, I'll see if I can dig them up for a DIY thread.
As an update, after several years and many track days, the plates are still holding strong with no signs of stress fractures.
      08-08-2017, 12:35 AM   #33
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Is there any way we can get the picture of your template again? Due to photobucket its not available anymore =( Going to be performing mine Friday need as much info as I can get to make the process faster. Cheers
I'm more organised that I thought and I could readily lay my hands on the template.
Here you go! Obviously, it's reversible L <--> R
      08-08-2017, 03:36 AM   #34
Boosted 1
Where Does He Get Those Wonderful Toys?
Boosted 1's Avatar
Drives: 07 M coupe, Gx470, M2 PE
I can check to see if I still have it from when I made mine.
      08-08-2017, 09:37 AM   #35
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
That would be greatly appreciated bud!
      08-08-2017, 09:13 PM   #36
Boosted 1
Boosted 1's Avatar
you have pm
Z4M_Coupe201.00
      08-09-2017, 12:01 AM   #37
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
It would be nice if you could post the templetes up here for thread completion.
Thx
Powered by
      08-09-2017, 12:27 AM   #38
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Vanne, I will be making them this week. If all goes well I will post the template AND make these with 3/16" steel for Z owners for $30 shipped =)
Thx
      08-09-2017, 01:23 AM   #39
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
cool add me for a set mate please
Powered by
Z4M_Coupe201.00
      08-12-2017, 06:57 PM   #40
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
I completed a set, and they are great! If anyone is interested, I can make you a set for $35 shipped. Made with 3/16" steel. You can epoxy it on, or weld it on the choice is yours. I will send it to you as bare metal, 2 plates only. If you like, I can also add 4 new sway bar self locking OEM nuts and 2 tubes of loctite metal epoxy as a kit and sell for $55 shipped. I will be making them first to pay first to get and will produce a unlimited amount needed. Same week fabrication and shipping!! Can either PM me or make a list here, and PLEASE LET ME KNOW IF YOU WANT THE PLATES ONLY OR THE KIT. I will also be posting this on the classifieds. Thank you!
(Please note I am not a master fabricator or what not, so it will not be a laser cut perfect piece. I will obviously sand the edges down and get it to be as smooth and fitting as possible)
      08-14-2017, 12:27 AM   #41
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sweet. Yeah put me down for set please..
      08-14-2017, 12:40 AM   #42
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
Will be ready Tuesday! =)
      10-17-2017, 06:14 PM   #43
joelselman
Drives: 2005 Z4, 2001 530
Interesting thread. My '05 3.0i is tracked regularly and I assumed this problem was only on M's because of the larger diameter front ARB's either stock or aftermarket. I'm running the stock 24mm.
However, a year or two ago I broke a support clamp on the right front. Didn't notice any issue with the frame but I see the support clamp is identical between my car and the M. Wonder if I'm generating enough stress that the issue should be addressed?
      10-21-2017, 06:41 AM   #44
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Given how simple this modification is, the question isn't should I do this, but why wouldn't you?
