05-06-2020, 11:00 AM | #2 |
Rep 1,776
Drives: E86 3.0si
Garage List '08 Z4 3.0SI [8.50]
'66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '55 Ford F100 [0.00] '19 VW Golf "R ... [0.00] |
Get a "puck" to fit the Z4's lift pads and a small scissors jack...both the pucks and the jacks can be found on eBay.
05-06-2020, 04:23 PM | #4 |
Rep 135
I've had good luck with the Harbor Freight low profile jack.
Also, there's good jack technique in this thread I don't jack using the pads, I follow the technique in the thread and jack using the diff support (first) and the front middle jack point (second).
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i |
05-06-2020, 04:34 PM | #5 |
Retired
96
Rep 174
If you were jacking to change a flat on the side of the road would you not use the jack pad location?
05-06-2020, 04:40 PM | #6 |
Rep 1,776
Drives: E86 3.0si
Tough to get the HF jack in the trunk with a spare.
05-06-2020, 04:41 PM | #7 |
Rep 1,776
Drives: E86 3.0si
wdb4673.00 |
05-07-2020, 08:50 AM | #9 |
Rep 127
In order to get down low enough you will need to use a scissors jack. The puck is a great idea if you can find one that fits the jack. You may want to measure how low the jack need to go before buying one. I got lucky as my Dad had one in his garage that was out of a 70/80's Ford Tempo. It needed to be brought all the way down but fit under the car.
05-07-2020, 09:17 AM | #10 |
Rep 135
Ah geez...sorry about that. In my haste, I missed the spare tire part of that.
I'll leave the above post in case it's helpful, but it's not a great option for the side of the road.
05-07-2020, 09:31 AM | #11 |
Rep 3
Thanks to all that replied. I decided to go with a scissor jack and pad. Safety first and only if stuck on the side of the road. If I can nurse it back home to my garage and fix it there would be a better and safer option.
05-07-2020, 10:20 AM | #12 |
Rep 390
Get yourself a small Gardener's trowel to go with it as well....
Given how low the car is you will might need to dig a small depression for the jack to fit under the jack pad...
Sent from my smart phone...
05-07-2020, 10:29 AM | #13 |
Retired
96
Rep 174
When we were on our Blue Ridge trip I packed a breakdown kit in the trunk
1)Swing bar with 17mm socket 2)Scissor jack 3)Small portable compressor 4)Tire repair kit with plugs 5)Bottle of slime (last resort) 6)1lt of Motul 10w60 The car also has the standard mobility kit in the trunk. Of course we are members of CAA/AAA and would call for assistance but not all areas we travelled through had cell coverage. |
05-09-2020, 07:28 AM | #14 |
Rep 18,580
Screwing around with an adapter and scissor as pictured seems a bit risky. BMW makes a spare tire kit for a lot of its RFT cars and most cars use a version of the lifting block on the E85/86. The low-profile jack is pricey, but is very compact and fits the lifting block. It needs a ratcheting wrench with it:
Jack P/N: 71126799169, $122 Wrench P/N: 71126769151, $22 https://www.turnermotorsport.com/p-2...uine-bmw-part/ https://www.turnermotorsport.com/BMW...tt=71126769151
05-09-2020, 09:28 AM | #15 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
I don’t actually keep a spare kit in the car but I’ve bookmarked this one just in case:
https://www.amazon.com/dp/B004PX8BC2..._g5RTEb50JV3NK No clue though if it’ll actually fit underneath. Luckily I don’t drive far with the Z and if I do, it’s usually to/from track where I know I’ll have some friends nearby. For home duty, I use an Arcan 3T from Costco. It’s low enough to get underneath the Z but goes up enough to work on my wife’s X3. They go on sale every once in a while but I think I got mine for $99 (currently $120). FWIW unless you can get a really long one that reaches the center jack point underneath the car, I don’t think it’s worth paying a huge premium other than weight if you plan on lugging it to the track. |
wdb4673.00 |
05-09-2020, 10:37 AM | #16 | |
Rep 2,846
https://www.ebay.com/itm/BMW-X5-Emer...UAAOSwLfZea~bJ |
05-09-2020, 12:32 PM | #17 | |
Rep 160
05-09-2020, 12:46 PM | #18 | |
Rep 18,580
