      04-18-2017, 01:09 PM   #67
RossBMWZseries
Thanks for the response guys. I brought the Z4 to work today and I'm out to lunch, so I'm going to head out right now and see if it starts. The last thing I want is a coworker having to jumpstart a BMW, I'm going to hear it tomorrow lol. For the record, sometimes it dies as quick as in 2-3 hours of not driving it, not just a 12 hour window
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      04-18-2017, 03:10 PM   #68
Shipkiller
Shipkiller's Avatar
Drives: Me
If the battery is becoming discharged after two or three hours (sometimes), then you should be able to find the issue rather quickly. The problem child should be really HOT with that sustained high discharge rate......
      04-18-2017, 05:03 PM   #69
RossBMWZseries
You're probably right Shipkiller. I just think that at this point my frustration is not allowing me to think and quickly get fed up with the car
      04-18-2017, 10:53 PM   #70
RossBMWZseries
Soooo another day gone by with no solution. Haven't jump started the car today as there was no need but my AC still isn't working in this 95 degree day. Fuses seem to light up steady, battery voltage is on point (testing from the dash itself). Maybe somehow the jumpstart put it on transport mode..? Which I'm still unclear as to how that works. I read somewhere in forums that disconnecting the battery and touching both negative/positive cables will do a "master reset" and could do the job. Not sure how I feel about dying though. The only thing I accomplished was to break the left side hinge from my passenger compartment, now It's sagging like the common issue on Z3's. I'm gonna call it a night, take a cold shower, curl up in a fetus position in bed, and cry the night away. Cheers guys!
      02-18-2018, 11:40 PM   #71
jdoege
Drives: 2007 M Coupe
This is a bit late, but have you considered measuring the current through each individual fuse with an ammeter? There should be almost no draw when the ignition is off so anything over something less than an amp would be a clue as to what is drawing power.
      02-22-2018, 01:25 PM   #72
RossBMWZseries
Hey bud, very late indeed lol. Thank you anyway for your input, I got this resolved. It was my OEM Navigation that was staying on even when the car was off and was killing the battery. Navigation is now disabled.
      02-22-2018, 07:31 PM   #73
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Given how archaic the nav is that seems like a good move.
      11-10-2019, 12:58 PM   #74
duke48
Drives: Z4
'03 Z4 Alternator
My charging light has been on in the morning. Goes out after a mile or so. battery registers 12.4 V Battery charging 14.3 V. What the....?????
put a 2 hr. charge on the battery and the light was on when I went to start it. Went out per usual.
      05-05-2020, 05:56 AM   #75
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Originally Posted by CJW2OO4 View Post
Did you guys experience the brake lights and the music and corner lights cut in and out?
My car have exact symptoms + throttle adaptation value errors with reference to terminal 15 = alternator
      05-05-2020, 07:11 AM   #76
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
I did
I had my alternator rebuilt and is now mint again
Revolution of our Times
I will return to the track, one day.
      06-01-2023, 08:35 PM   #77
eruiz
Drives: 2008 M3 coupe - Alpine White /
Does anyone have the P/N for the voltage regulator? My Z4M is starting to show the same trouble, I want to try with the regulator first, but canīt find it on REALOEM.
Thanks
      06-02-2023, 06:45 AM   #78
AK72
AK72's Avatar
Unfortunately BMW stop selling voltage regulator separately # 5 on the picture,
but you can try this guys - https://www.maniacelectricmotors.com...-bearings.html
