03-12-2020, 02:59 PM | #1 |
I like Coffee & Z4s.
107
Rep 366
Drives: 2007 Z4MC
FS: 2007 Z4M Coupe black/black in NY, mods & maintenance
Selling because I miss having a roadster. PROS: Rod bearings, Vanos taken care of. FANTASTIC brake feel, acceleration, feeling of connectedness from the light flywheel, noise from the headers, intake, and exhaust. Looks amazing. The coilovers make the car very nimble without ruining streetability. Barely any squat / dive / body roll. No Nav!!! Car has been cared for obsessively, I garage it in Brooklyn and mainly use it to visit relatives in Long Island on weekends where the roads are better. CONS: A few exterior issues that I plan to sort out, see below. (or, shoot me an offer before 3/22 and I'll cancel my appointment with the body shop, you can take the car as-is and save some money). Lightweight flywheel means that the car vibrates at low RPM high load so you have to avoid that at < 1500 RPM. Flywheel chatter at idle doesn't bother me at all though. 2007 BMW Z4 M coupe for sale Mileage: approx. 68,000 VIN: 5UMDU93557LM08564 Location: Syosset, NY, 11791 Car has never been in an accident. Modifications done during my ownership: - Installed stock lighted shift knob (ZHP was too short/stiff) - Status Gruppe Headers - AFE Intake - Epic Race Tune (93 octane, secondary o2 sensor is ignored) - Supersprint Powerloops exhaust, bought here from 3002_tii - Fortune Auto MSC-1 Coilovers, bought from a forum member Modifications done by RRT (independent marque specialist in Stirling VA) under previous ownership: - Diffsonline 3-clutch diff with 3.91 gears and 45/45 ramps - Stoptech ST40 BBK front and rear, 355mm rotors - Stoptech street brake pads - Stainless Steel Goodridge brake lines - Rogue Engineering short shift kit - JB Racing Aluminum lightweight flywheel (car does have mild flywheel chatter at idle) - South bend stage 2 clutch for single mass flywheel - Bimmerworld 82mm race studs and Turner Motorsports open lugs - Apex SM-10 wheels, 18x9” ET30 front, 18x9.5” ET22 rear, mounted with low miles Michelin PSS 235 front/265 rear tires - APR Performance Front splitter - Castrol SRF brake fluid - Rear diffuser and carbon fiber spoiler Maintenance done by me: - Oil changes with liqui-moly 10w-60 and blackstone oil reports. - Brand new Primary O2 sensors at ~66k miles Maintenance at 57,079 miles: - Rod bearings replaced, blackstone oil reports for every oil change since - ABS replaced (pump/motor/sensors) - Oil relief valve replaced - VANOS inspection and reseal - Valve adjustment: New valve shims and washers - NGK Spark plugs - New battery - Replaced power steering hose and fluid Previous owner has done 3 HPDE track days. I'm getting the following fixed (appointment 3/22) - Rock chips on front bumper cover - A few scratches including a scratch near the rear passenger side wheel well. https://photos.google.com/u/1/share/...hrbEhhM3ZCNENR Car comes with indoor car cover, manuals and two keys, and the following if wanted: - OEM Clutch, dual-mass flywheel - OEM Mufflers - OEM Headers - OEM struts, rear spring/dampers - OEM Airbox - Will include stock ECU map and ECU flashing device from Epic - Extra set of Stoptech Street pads and track pads - Remus mufflers (though I'll need to take the powerloops back if you want remus) Original equipment per: http://www.z4mcoupebuyersguide.com/vin VIN Number 5UMDU93557LM08564 General Information: VIN: 5UMDU93557LM08564 Year: 2007 Exterior Color: Black Sapphire Metallic Interior Color: Black Nappa Interior Trim: Brushed Aluminum Production Date: September 20, 2007 Last edited by filtercoffee; 03-14-2020 at 11:38 AM.. |
03-12-2020, 09:11 PM | #2 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.09] |
There were times I missed my old coupe but having the hard top definitely solved that. Can't beat top down during summer and hard top for colder months.
GLWS, hope you find yourself in Z soon! |
03-14-2020, 11:40 AM | #3 |
107
Rep 366
Drives: 2007 Z4MC
Updated with pics
03-16-2020, 06:26 PM | #4 |
107
Rep 366
Drives: 2007 Z4MC
Could use some advice. Do you think the following mods help or hurt this thing sell?
1. APR Splitter 2. Lightweight flywheel Asking because when I get the bumper resprayed this Saturday, it's more convenient for the shop to leave the splitter off, so that makes sense if it will help resale. and I feel like doing the flywheel job might help. |
03-16-2020, 06:31 PM | #5 |
Rep 410
With all those mods, I would leave them (unless you don't care for the splitter - could sell that separately). If the car were otherwise stock, or near stock, I'd say ditch those parts.
filtercoffee107.00 |
03-17-2020, 09:22 AM | #6 |
Rep 12,570
I’d ditch the splitter, it makes the car look more track focused / missed than it is. Before someone even clicks on description, just seeing that pic in a listing may turn off most buyers looking for a stock-ish road car. Re flywheel, remove only if affects driveability.
If you want to sell that diff btw... let me know. Swapping pumpkins would be really quick. |
03-17-2020, 10:51 AM | #7 |
107
Rep 366
Drives: 2007 Z4MC
Thanks for the input. Yeah I'm open to selling the diff, PM me. Also TIL they're called pumpkins.
03-17-2020, 07:56 PM | #8 |
Rep 12,570
pumpkins, carriers, all the same. =)
03-18-2020, 08:27 AM | #9 |
Rep 264
PM'ed
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
