      06-18-2018, 01:42 PM   #111
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Originally Posted by Vanne View Post
Hey buddy, how is it going?
Couple of questions man, that part number for the flywheel you listed previously is NOT for the z4m, and is only for the z3m. Not sure if that makes any difference, but found out as my freaking pressure plate won't fit the lightweight flywheel. My flywheel part number is 520-180-240 which is the proper fitment for z4m.??? Yes
The clutch plate will fit both, but the pressure plate won't.
What did you end up fitting to your car?
That's strange, I had no problems with the installation and fitment. I did send my flywheel out to be balanced prior to install.
I would reach out to the guys at Turner since they put this package together and see if they can help.
OEM LuK Clutch Throw Out Bearing / Release Bearing -- E46 M3, E39 M5 (Mfg Part #
21511223582)
Sachs Performance Pressure Plate - E36 Z3 M3 3.2L (Mfg Part #
883082999792)
E36 M3, MZ3 JB Racing Lightweight Aluminum Flywheel (Part Number: 520-010-240 )
https://www.turnermotorsport.com/p-8...-flywheel-kit/
      06-18-2018, 01:58 PM   #112
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Street Shoes vs Track Shoes, You gotta love HRE's but the square set up for the track handles so much better. DME should be back this week get it on the road and start getting her dialed in.
ZAR4MC93.00
yousefnjr6157.50
crfine88442.00
      06-18-2018, 04:05 PM   #113
RossBMWZseries
Wow this thread is insane! Great looking car, and the massive balls it takes to do this type of work! What wheels are those on the bottom picture?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      06-18-2018, 06:25 PM   #114
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Those are Titan 7's almost 5lbs lighter per wheel than the HRE's, Great Track wheel for the price.
      06-18-2018, 09:58 PM   #115
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
21511223582)
883082999792)
Thanks matey, yeah I think the difference is I have the 520-180-240 flywheel, not the 520-010-240 one. Thanks for the help though, and yeah trying to sort it out with Turners atm. Sorry to sidetrack you from your build thread. LOVING your car man, I just cant wait to see it running/going. going to be completely EPIC!!!!!
as you said man, work of art of those parts going together.
Love the new Titans, looks like they will be the goto track wheels. They look much better than the HRE's , esp on the front.
Powered by
      06-19-2018, 03:54 AM   #116
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
No Worries, I am always available.
      06-27-2018, 04:37 AM   #117
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Well, we finally figured out what was going on with the throttle actuator. The Dinan throttle bodies were not set correctly by the manufacturer and the fail-safe was cutting power and not allowing the car to complete the startup sequence. Since they specifically tell you not to mess with the settings or it will void the warranty it makes this hard to track down.
The next step is getting the new Epic Alpha tune flashed to the ECU and then off to the Dyno Next week.
Mirko182.00
Vanne1620.50
      06-27-2018, 01:26 PM   #118
GPower
GPower's Avatar
Drives: 2007 BMW Z4M Coupe
Great work, looks really nice. Can you take a shot of the snorkel interacting with the intake scoop in the front bumper.
Also what are you running exhaust wise?
      06-28-2018, 09:06 PM   #119
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We had to cut most of the snorkel off. there is no way around that and I used my RPI scoop which pushes the air directly into the box.
The exhaust is a set of epic stepped headers, Supersprint straight, and x-pipe with RPI cans.
crfine88442.00
      06-30-2018, 06:34 PM   #120
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
I finally got her back out on the road for testing. All looking surprisingly good with only a few adjustments and we have not even completed the alpha tune yet. .
PLCZ4MC79.00
Vanne1620.50
crfine88442.00
      07-04-2018, 07:11 AM   #121
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Getting close to scheduling our first Dyno. Trying to get a few miles on the car and work out some tweaks, But all is good!
Vanne1620.50
ZAR4MC93.00
      07-07-2018, 08:43 AM   #122
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
that's awesome!!!!!
Powered by
      07-10-2018, 12:33 PM   #123
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
Looks bad ass! engine bay is porn!! Congrats!
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      07-10-2018, 11:14 PM   #124
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
hey buddy, just wondering if anyone has asked about it yet, but do you have 4 big yellow spotlights in front of your radiator core? what are those for?
Powered by
      07-11-2018, 04:03 AM   #125
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We have evening track days at Road Atlanta and my night vision is not great, so I added them and swapped out all my OEM headlights to LED lamps, I get twice the vision without blinding the guys in front of me.
crfine88442.00
      07-12-2018, 05:45 AM   #126
NISxMO
Drives: Looking to purchase soon!
Holy $#%& I love the yellow fogs man! Your car has pretty much become my inspiration and I have been wondering how best to add fogs without making any permanent changes to the car..... this looks fantastic!
      07-12-2018, 01:32 PM   #127
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Thanks, the car started out as just a daily and has progressed over the years. I did not want the fog lights to be seen, so I put them behind the lower grill.
I ended up finding a piece of Zinc-Plated Slotted Angle and attached it to the subframe. I had to grind down the corners, which I would have made a little cleaner if I did it again.
The lights are 4"LED with a yellow tint and I have a toggle switch on the dash that turns them off and on. They are solid and fit perfectly behind the grill.
Mirko182.00
crfine88442.00
      07-16-2018, 07:02 AM   #128
ZAR4MC
South Africa
93
This is just bad ass...
My S54 Journal
      07-17-2018, 09:04 PM   #129
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Mirko182.00
ZAR4MC93.00
XMetal1134.50
KevsZ411.00
      07-25-2018, 05:04 PM   #130
RossBMWZseries
Even better. Your engine bay is GOALS! All that carbon fiber
      08-17-2018, 05:22 PM   #131
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
First dyno session pushed a 377.48 to the wheels "dyno jet equivalent" and 266 lbs of torque. Sending my data logs back to Epic for tweaking. I stopped at 7200RPM because I am running a 4:10 rear diff.
      08-17-2018, 11:16 PM   #132
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Those last HRE shots
-Matt
| Z4M Build Thread | @violetnites | flickr |
