      11-29-2009, 08:17 PM   #1
redsoxx
Drives: 2008 328xi coupe
Space saver spare and tool kit!
I have the space saver spare and toolkit sold by leatherz.com. The tire and tool kit is new and has never been used. The tool kit includes a jack, lug wrench and tire block. The tire was never mounted on my Z4. Leatherz.com sells the tire and tool kit for $335 plus shipping. I will sell all, including a black, vinyl tire cover, for $275 INCLUDING shipping. You will save around $100. I'll include some info from their website below. I was unable to upload pictures, but if you are interested, you can see photos on the leatherz site. You can also give me your email and I will send you pics.
Many late-model BMWs like the E90 3 Series, Z4, M roadster, M coupe, and E46 M3 are not equipped with a spare tire from the factory. While the M Mobility System works in most cases, it is not always 100% reliable depending the type of tire damage you have; and it often adds expense when replacing the damaged tire. Cars like the E90 3 Series, Z4 and certain E46 3-series include run-flat tires - which avoids the mobility kit - but the performance of said tires is often less than ideal. Our solution is simple: use a BMW Space Saver Spare. Using a Space Saver Spare allows you to refrain from using the M mobility system and also allows you to replace your run-flat tires with performance tires. Our Space Saver tire uses an original BMW space saver wheel and a spare tire in the correct size. The wheel is the correct offset and bolt pattern to clear the front and rear brake calipers on the Z3 (all models including MZ3), Z4 (non-M), E9x 325i 3 Series (excluding the M3) and all E46 3-series cars (excluding E46 M3 with Competition Package) without any interference.
-Size Information-
Option 1 and 2 - Z3 and M Z3 Roadster/Coupe, E46 3 Series, E82/E88 1 Series, Z4 (non-M) Roadster/Coupe, & E9X 325i -
Wheel Size: 17" Steel Wheel
Tire Size: Continental 125/80/17
The Space Saver Spare Tire will work with the following models:
Z3 Roadster and Coupe - all models including M
E46 3 Series - All models including M3 (will not fit M3 with Competition Package)
E8x 1 Series - All models
E85/E86 Z4 Roadster and Coupe - all models excluding M
E9x 3 Series - (2006+) 325i only (The spare will NOT work on the 328, 330, or 335)
      12-10-2009, 05:35 PM   #2
redsoxx
Tire has been sold. Thanks.
      12-10-2009, 06:48 PM   #3
vdubb2bmw
Drives: e86 m
how much for the tool kit? I'm in connecticut.
