09-21-2016, 08:33 AM | #67 | |||
![]() 441
Rep 2,747
![]() Quote:
![]() ![]() ![]() Quote:
![]() Thank you!
09-21-2016, 08:50 AM | #68 |
#dubspec
![]() 6332
Rep 5,201
amazing work so far! looking forward to new updates
crfine88441.00 |
09-21-2016, 08:54 AM | #69 | |
![]() 441
Rep 2,747
09-21-2016, 10:11 AM | #70 |
![]() ![]() ![]() 7485
Rep 12,307
One of the best and thorough build threads I've seen. I'd love to see how a car setup like this feels like!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
crfine88441.00 |
09-21-2016, 11:35 AM | #71 | |
![]() 441
Rep 2,747
09-21-2016, 01:07 PM | #72 |
![]() ![]() ![]() 423
Rep 5,327
i cant tell you how happy i am that you back with us again, these are seriously special cars...
one of the best kept secrets in the last decade!
crfine88441.00 |
09-21-2016, 01:19 PM | #73 | |
![]() 441
Rep 2,747
Cheers!
09-21-2016, 02:14 PM | #74 | |
![]() ![]() 37
Rep 398
Another helpful section ![]() Do you have a better pic of the first pic with the horn wiring to the control stalk/column?
BSM Z4M Coupe
09-21-2016, 09:08 PM | #75 | |
![]() 441
Rep 2,747
Thank you! Here are a couple. Let me know if this is what you are looking for. I didn't take an pictures from before trimming off the female plug housing and isolating the unused pins. That step was necessary to make the short hub fit; not sure if it is needed for longer hub adapters.
09-21-2016, 10:19 PM | #76 | |
![]() ![]() 37
Rep 398
I had to trim as well to fit my Ring (no QR) and tried to reuse the connector pin. Given that the trim had to be cut, the connector is not holding well. I will also have to solder them on as you did. Thanks Chris.
BSM Z4M Coupe
09-26-2016, 08:40 PM | #77 |
![]() 441
Rep 2,747
0023
0023 Phase 1: Appradio + Layout For Future Removable Amp Rack Since this build is dual purpose, the goal is to build a lightweight stereo system with removable amp rack. The monitor will stay in the car on track days to support track related apps. The amp rack, cross overs and sub (if I add one) will all be set up with quick disconnects for easy removal. This phase shows the layout for the current testing configuration. Pros:
Cons:
PHOTOS:
09-26-2016, 08:46 PM | #78 |
![]() 441
Rep 2,747
0024
0024 Rogue Transmission Mounts Needed upgraded to help with shifting ![]() Pros:
Cons:
PHOTOS:
09-26-2016, 08:51 PM | #79 |
![]() 441
Rep 2,747
0025
0025 Vibra-Technics Engine Mounts Excellent upgrade! Was able to score these new from Finnegan ![]() Pros:
Cons:
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 09-28-2016 at 06:03 PM.. |
09-26-2016, 08:55 PM | #80 |
![]() 441
Rep 2,747
0026
0026 10.9 Engine Mount Bolts + New OE Washers Well know maintenance item on our cars. All replaced and properly torqued ![]() PHOTOS:
Vanne1620.50 |
09-26-2016, 09:14 PM | #81 |
![]() 441
Rep 2,747
0027
0027 CAE / Hardmotorsport Shift Kit Anodized Black Looking to further improve shifting accuracy & bring the shift knob up closer tot he steering wheel, I turned to CAE / Hardmotorsport. Pros:
Cons:
PHOTOS:
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 09-26-2016 at 09:24 PM.. |
Vanne1620.50 |
09-27-2016, 08:56 AM | #82 |
![]() ![]() ![]() ![]() 2426
Rep 11,667
Love that shifter Chris!
Must be a dream on track! Would love to feel what that's like Is it still possible to work the center consol back on ? (Even if modified)
09-27-2016, 09:42 AM | #83 |
![]() ![]() 37
Rep 398
Very nice audio install!
I just completed a similar install with an JL XDv2, and added an 8" microsub+. Works great with just solid 3-way upfront. In hindsight, since the sub is removable I would go 10" ![]()
BSM Z4M Coupe
09-28-2016, 10:05 AM | #85 | |
![]() 441
Rep 2,747
Yes, it is a dream! Unbelievably crisp and consistent ![]() No real track time yet, but Many sessions at the local proving grounds (2.2 mile run through the desert mountains to the lake) ![]() many rollers, elevation changes and switchbacks. Especialy great for testing suspension and tire clearance. Yes, modified OE console can still be used. I will still be using most of the OE console, trimming to accommodate the shifter and screen (work in progress).
inTgr8r2425.50 |
09-28-2016, 10:14 AM | #86 | |
Rep 11,667
Is the shaft adjustable for height and right to left orientation? .....soooo tempting! ![]()
09-28-2016, 10:15 AM | #87 | |
![]() 441
Rep 2,747
I am really impressed with sound from the 3-ways running bridged (C5-653's w/ XD700/5 V2) I have a new 10TW1 I am planning to use for the removable inclosure
09-28-2016, 10:22 AM | #88 | |
![]() 441
Rep 2,747
No height adjustment for the shift lever & no left to right adjustment for the carrier. Only adjustments for limiting pins to dialing in throw range.
