08-09-2022, 03:29 PM | #3 | |
Rep 781
I'm not much of an electronic/computer guy and it took me a couple weeks to track down this info. I'm trying get coolant temp and oil pressure readings into the cab where I can see them, I could just plumb in water temp and oil pressure sensors but I was hoping I could tap into those wires that feed into the DME. I think I can use the signal from the existing coolant temp sensor but the oil pressure sensor is just a switch that tells the DME that there is pressure so it is safe to start the engine, don't think it is relaying data on how much pressure.
2008 E86 M coupe
08-09-2022, 04:46 PM | #4 | |
Rep 3,004
Thanks -
Racerbruce
02-05-2023, 07:27 AM | #5 |
Down Under!!
1621
Rep 4,294
yup thats correct, no oil px data aside from (there is oil px) on the bus. youll need to add a sensor for that. Exellent info up there though, thanks for that!!!
Powered by |
02-05-2023, 08:34 AM | #6 | |
Rep 781
The water temp sensor was installed in the coolant drain plug on the block under the header and the oil pressure sensor was installed on the side of the oil filter housing. I had to fart around with the fittings to get the right combination but it works well now. I used the push button gauge from these guys, https://blackstarmanufacture.com/produkt/multigauge/ Now I can see what the fluids are doing before the TOO LATE warning light flashes.
2008 E86 M coupe
racerbruce3853.50 3002 tii2281.50 |
02-05-2023, 09:55 AM | #7 |
Rep 3,004
Well done!!
Your engineuity should have been on the front end of BMW's Z4M design/construction. On a much more mundane point, love your CoCo flor mats; their fit and finish and style are at the top of the floor mat market; just ordered a set for my 335is E93 and had them in my Z4MR.
Racerbruce
grannyknot950.50 |
