      09-21-2016, 08:33 AM   #67
crfine88
crfine88's Avatar
414
Drives: E86M
Originally Posted by Vanne View Post
Chris, … Enough said mate, soo glad you did that man
Originally Posted by MT135 View Post
I remember your first build thread, saw that car at a Savini meet in California. So cool you've got another!!
I remember that meet, fun trip!
Originally Posted by yousefnjr View Post
Quality build, A++ that Karbonius box is the bees knees, work of art
Thank you! Since installing the Karbonius box I always leave the hood open when parked in the garage
^+1
that Karbonius keeps calling my name.
Luke... I am your air box
Originally Posted by j03chu View Post
This threads going to make me eat a ton of popcorn!
Really making me miss my old Z4M!
Should I make the switch from my 997.1 C2S back to Z4M?
Yes, and this is a completely unbiased opinion
If you have to ask yourself that question, you already know the answer.
Chris, love the steering wheel mod, very cool.
Thank you!
      09-21-2016, 08:50 AM   #68
dubsesd
#dubspec
dubsesd's Avatar
No_Country
5944
amazing work so far! looking forward to new updates
instagram: @ dubsesd
crfine88413.50
      09-21-2016, 08:54 AM   #69
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks!
      09-21-2016, 10:11 AM   #70
W///
W///'s Avatar
6547
Drives: F87 M2C, E92 M3, E36 M3, Z4MR
One of the best and thorough build threads I've seen. I'd love to see how a car setup like this feels like!
Current: 19 F87 M2C / 08 E92 M3 / 07 E85 Z4M Roadster / 99 E36 M3
crfine88413.50
      09-21-2016, 11:35 AM   #71
crfine88
crfine88's Avatar
414
Drives: E86M
Thank you!
      09-21-2016, 01:07 PM   #72
Beedub
i cant tell you how happy i am that you back with us again, these are seriously special cars...
one of the best kept secrets in the last decade!
crfine88413.50
      09-21-2016, 01:19 PM   #73
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks Byron, Happy to be back,
Cheers!
      09-21-2016, 02:14 PM   #74
EMP07
EMP07's Avatar
34
Drives: Z4M
Originally Posted by crfine88 View Post
0022
Sparco Ring / NRG Short Hub / NRG Quick Release
Have always loved the BMW Motorsport D-Ring wheel. This and the Momo mod 88 are the closest I have found. Really enjoy the look and feel of this wheel
Pros:
  • Easier to get in and out with steering wheel removed
  • Better feel in hand IMO
  • Enhanced steering response with slightly smaller wheel
Cons:
  • Loss of steering wheel buttons/controls other than the horn
  • Dealing with airbag/airbag light
  • Modifications to wire horn and make short hub fit are tough to reverse
Another helpful section , nicely done on the steering wheel & assembly.
Do you have a better pic of the first pic with the horn wiring to the control stalk/column?
BSM Z4M Coupe
      09-21-2016, 09:08 PM   #75
crfine88
crfine88's Avatar
414
Drives: E86M
EMP07
Thank you!
Here are a couple. Let me know if this is what you are looking for. I didn't take an pictures from before trimming off the female plug housing and isolating the unused pins. That step was necessary to make the short hub fit; not sure if it is needed for longer hub adapters.
      09-21-2016, 10:19 PM   #76
EMP07
EMP07's Avatar
34
Drives: Z4M
EMP07
Thank you!
That was helpful. Nice finish considering what you were dealing with.
I had to trim as well to fit my Ring (no QR) and tried to reuse the connector pin. Given that the trim had to be cut, the connector is not holding well. I will also have to solder them on as you did.
Thanks Chris.
BSM Z4M Coupe
      09-26-2016, 08:40 PM   #77
crfine88
crfine88's Avatar
414
Drives: E86M
0023
0023
Phase 1: Appradio + Layout For Future Removable Amp Rack
Since this build is dual purpose, the goal is to build a lightweight stereo system with removable amp rack.
The monitor will stay in the car on track days to support track related apps. The amp rack, cross overs and sub (if I add one) will all be set up with quick disconnects for easy removal.
This phase shows the layout for the current testing configuration.
Pros:
  • System sounds much better than OE with just the 3-way components, amp and monitor installed
  • Will save weight over OE fully installed
  • Will save even more weight on track days with amp rack/sub reomoved
  • Nice having good tunes on long road trips
Cons:
  • A long way away from complete
  • Time suck as it relates to what I consider more important mods
PHOTOS:
      09-26-2016, 08:46 PM   #78
crfine88
crfine88's Avatar
414
Drives: E86M
0024
0024
Rogue Transmission Mounts
Needed upgraded to help with shifting
Pros:
  • Easy Installation
  • Helps reduce 2nd gear denial
  • I proves shifting overall
Cons:
  • Non observed
PHOTOS:
      09-26-2016, 08:51 PM   #79
crfine88
crfine88's Avatar
414
Drives: E86M
0025
0025
Vibra-Technics Engine Mounts
Excellent upgrade! Was able to score these new from Finnegan Thanks for the great deal!
Pros:
  • Reduces Engine moevment
  • Improves traction under acceleration
  • Improves shifting reliability
Cons:
  • None Observed
PHOTOS:
      09-26-2016, 08:55 PM   #80
crfine88
crfine88's Avatar
414
Drives: E86M
0026
0026
10.9 Engine Mount Bolts + New OE Washers
Well know maintenance item on our cars. All replaced and properly torqued
PHOTOS:
Vanne1463.00
      09-26-2016, 09:14 PM   #81
crfine88
crfine88's Avatar
414
Drives: E86M
0027
0027
CAE / Hardmotorsport Shift Kit Anodized Black
Looking to further improve shifting accuracy & bring the shift knob up closer tot he steering wheel, I turned to CAE / Hardmotorsport.
Pros:
  • The ability to set throw limits is awesome
  • Hands down, the most crisp/positive engagement I have experienced
  • Top notch build quality
  • Puts the shift knob right next to 3 o'clock on the steering wheel
Cons:
  • Requires modification of the center console (big space commitment)
  • May be too tall for some
PHOTOS:
Vanne1463.00
      09-27-2016, 08:56 AM   #82
Drives: M2 Comp
Love that shifter Chris!
Must be a dream on track!
Would love to feel what that's like
Is it still possible to work the center consol back on ? (Even if modified)
      09-27-2016, 09:42 AM   #83
EMP07
EMP07's Avatar
34
Drives: Z4M
Very nice audio install!
I just completed a similar install with an JL XDv2, and added an 8" microsub+. Works great with just solid 3-way upfront.
In hindsight, since the sub is removable I would go 10"
BSM Z4M Coupe
      09-27-2016, 11:50 PM   #84
Vanne
Vanne's Avatar
United Arab Emirates
1463
Drives: 2007 Z4MC
Wow!!! That shifter mate!!!! Pure awesomeness.. very cool, I bet that feels great when swapping gears.. love it!!!
crfine88413.50
      09-28-2016, 10:05 AM   #85
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks Ian!
Yes, it is a dream! Unbelievably crisp and consistent
No real track time yet, but Many sessions at the local proving grounds (2.2 mile run through the desert mountains to the lake)
many rollers, elevation changes and switchbacks. Especialy great for testing suspension and tire clearance.
Yes, modified OE console can still be used. I will still be using most of the OE console, trimming to accommodate the shifter and screen (work in progress).
inTgr8r2250.00
      09-28-2016, 10:14 AM   #86
Drives: M2 Comp
Thanks Ian!
Thanks, that's great!
Is the shaft adjustable for height and right to left orientation?
.....soooo tempting!
      09-28-2016, 10:15 AM   #87
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks, it's a work in progress!
I am really impressed with sound from the 3-ways running bridged (C5-653's w/ XD700/5 V2) I have a new 10TW1 I am planning to use for the removable inclosure
      09-28-2016, 10:22 AM   #88
crfine88
crfine88's Avatar
414
Drives: E86M
Anytime!
No height adjustment for the shift lever & no left to right adjustment for the carrier. Only adjustments for limiting pins to dialing in throw range.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
