      09-11-2016, 11:41 AM   #1
crfine88
crfine88's Avatar
414
Drives: E86M
2007 IR E86M Photo Journal
0001
Keeping this journal to document the build and experience of E86M ownership the second time around
Photos also posted to
IG: CSLFMotorsport
Links to Journal Entries:
0002 Seat Upgrade: Cobra / VAC / Schroth
0003 Pedal Upgrade: Pedal Haus
0004 Shifter: Autosolutions
0005 Half Cage Preparation: Bulkhead Delete
0006 Air Intake: Eventuri
0007 Suspension Upgrade: JRZ / Hyperco / Ground Control
0008 Strut Brace: Rogue Engineering
0009 Battery Upgrade: Braille / Macht Schnell
0010 Half Cage Preparation: Headliner & Wire Harness Protection
0011 Half Cage Build
0012 Battery Relocation
0013 Aero Upgrade: VRS GT Wing
0014 Half Cage Preparation & Paint: Titan (Titanium) Silver
0015 Exhaust Upgrade: Stromung Axle Back w/ 89mm Tips
0016 Exterior Upgrade: Gloss Black Roof
0017 Wheel Upgrade: HRE R43
0018 Exterior Upgrade: VRS 2 Piece Splitter / Euro Bumper / Aero Side Skirts
0019 Intake & Tune Upgrade: Evolve
0020 Exhaust Comparison: OEM / Supersprint / Rogue / RPI
0021 Intake & Tune Upgrade: Karbonius + Evolve
0022 Steering Wheel Upgrade: Sparco + NRG
0023 Stereo Upgrade: Appradio + JL
0024 Transmission Mount Upgrade: Rogue Engineering
0025 Engine Mount Upgrade: Vibra-Technics
0026 Engine Mount Bolt Upgrade: McMaster-Carr
0027 Shifter Upgrade: CAE / Hard Motorsport
0028 FCAB Upgrade: SuperPro
0029 RTAB Upgrade: Meyle + ECS
0030 Exhaust Upgrade: DKF S-Pipe
0031 Brake Upgrade: Brembo GT BBK
0032 Road Trip / Parts Run: VRS Cooling Bonnet + Rear Diffuser System
0033 Weight Comparison: Varis VSDC Hood VS OE Aluminum
0034 Quality Check: OE vs Varis Hood Mounting Point Dimensions
0035 Exhaust Upgrade: Rogue Engineering X-Pipe
0036 Pre-Install Detail Photos: VRS Diffuser System 1 & 2, Carbon
0037 Pre-Install Detail Photos: VRS Cooling Bonnet, VSDC
0038 Data Acquisition Upgrade: Coolant Temperature Sending Unit Installation
0039 Cooling Upgrade: CSF Aluminum Radiator
0040 Dipstick Upgrade: OE BMW CSL
0041 Photo Opp: Engine Bay w/Hood Removed
0042 VRS Cooling Bonnet Installation
0043 Data Acquisition Upgrade: Bimmerworld Oil Distribution Block + Oil Pressure Sending Unit
0044 Exhaust Upgrade: KKS Titanium Axle Back Mufflers
The calm before the storm.
Picked this beauty up from a fellow ZPOST member. Added APEX ARC-8 wheels, Toyo R888s and RPI GT exhaust to the otherwise stock M
First deep cleaning!
      09-11-2016, 11:59 AM   #2
crfine88
crfine88's Avatar
414
Drives: E86M
0002
0002
Seat Upgrade Time!
Cobra Evolution / VAC motorsport mounting Kit / Schroth Harnesses
Pros:
  • Significant performance upgrade
  • Maintained comfort for long road trips
  • Seat, Mounting Kit and Harnesses quality all top notch
Cons:
  • Loss of quick electronic adjustment for use with multiple drivers
  • Increased time to buckle up with harnesses compared to OE belts
PHOTOS:
      09-11-2016, 12:36 PM   #3
crfine88
crfine88's Avatar
414
Drives: E86M
0003
0003
PEDAL HAUS Upgrade
Pros:
  • Improved grip
  • Improved aesthetics
  • Easy installation
Cons:
  • None observed yet
PHOTOS:
Vanne1463.00
      09-11-2016, 12:38 PM   #4
Philly_sweden
Philly_sweden's Avatar
Sweden
125
Drives: No car
Holy shit!
Wow!!!
crfine88413.50
      09-11-2016, 12:59 PM   #5
crfine88
crfine88's Avatar
414
Drives: E86M
0004
0004
Autosolutions SSK
Pros:
  • Significantly shorter distance between shifts
  • Crisp/positive engagement into each gear
  • Eliminates the "rubbery" feel of the OE shift lever
  • Helps to reduce the common 2nd gear denial during fast shifts
Cons:
  • None observed yet
PHOTOS:
      09-11-2016, 01:07 PM   #6
crfine88
crfine88's Avatar
414
Drives: E86M
0005
0005
Bulkhead Delete (Preparation for Half Cage)
Pros:
  • Makes room for half cage
  • Opens up cabin
Cons:
  • Difficult to reverse
PHOTOS:
Vanne1463.00
      09-11-2016, 01:18 PM   #7
crfine88
crfine88's Avatar
414
Drives: E86M
0006
0006
Eventuri Intake
Pros:
  • Beautiful piece, top notch quality
  • Fast shipping from the UK
  • Improved engine bay aesthetics
  • Improved engine sound
Cons:
  • Sounds great, but wish it was louder
PHOTOS:
      09-11-2016, 01:30 PM   #8
crfine88
crfine88's Avatar
414
Drives: E86M
0007
0007
JRZ / Ground Control / Hypero Suspension Upgrade
Pros:
  • Best Dampers I have used
  • Significant performance increase at the limit
  • Better than stock ride quality on street when dialed back
  • Best rear spring mounting solution I have come across (articulating and adjustable from beneath the car
Cons:
  • None observed yet
PHOTOS:
Vanne1463.00
      09-11-2016, 01:36 PM   #9
crfine88
crfine88's Avatar
414
Drives: E86M
0008
0008
Rogue Engineering Race Brace
Pros:
  • Reinforces shock towers
  • Top notch weld/finish quality
Cons:
Required some extra fitment work during installation (not surprising considering the one piece construction and worth the extra work IMO)
PHOTO:
Vanne1463.00
      09-11-2016, 01:46 PM   #10
crfine88
crfine88's Avatar
414
Drives: E86M
0009
0009
Braille 21lb Battery / Macht Schnell Bracket
Pros:
  • Significant wight savings
  • The most reliable "race" battery I have used
  • Smaller profile increases cabin space
Cons:
  • None observed yet
PHOTOS:
Vanne1463.00
      09-11-2016, 01:52 PM   #11
crfine88
crfine88's Avatar
414
Drives: E86M
0010
0010
Custom Frog Tape Headliner & Final Preparation for Half Cage
Pros:
  • Interior protected
  • Half Cage can be built with headliner in place
Cons:
  • A lot of freaking tape and time
PHOTOS:
      09-11-2016, 02:01 PM   #12
crfine88
crfine88's Avatar
414
Drives: E86M
0011
0011
Half Cage Build
Pros:
  • Improved Safety
  • Built to SCCA specification & could be converted to a full cage
  • Imporved interior aesthetics (if you are into motorsport )
Cons:
  • Tough to reverse
  • Takes up cabin space
PHOTOS:
Vanne1463.00
      09-11-2016, 02:12 PM   #13
crfine88
crfine88's Avatar
414
Drives: E86M
0012
0012
Battery Relocation Project
Pros:
  • Saves cabins space
Cons:
  • Tough to reverse
PHOTOS:
Vanne1463.00
      09-11-2016, 02:19 PM   #14
crfine88
crfine88's Avatar
414
Drives: E86M
0013
0013
VRS (Varis) GT Wing
Pros:
  • Increased rear downforce
  • Top notch quality (Motrosport art )
  • Butterfly approved
Cons:
  • Requires drilling holes into hatch
PHOTOS:
Mirko180.50
      09-11-2016, 02:26 PM   #15
crfine88
crfine88's Avatar
414
Drives: E86M
0014
0014
Half Cage Prep / Primer / Paint
Titan Silver OE Color Code 354
PHOTOS:
JoosyJoos108.00
Vanne1463.00
      09-11-2016, 03:33 PM   #16
crfine88
crfine88's Avatar
414
Drives: E86M
Originally Posted by Philly_sweden View Post
Holy shit!
Wow!!!
      09-11-2016, 05:18 PM   #17
Mirko
Mirko's Avatar
Wicked! Worth the wait!!
crfine88413.50
      09-11-2016, 05:34 PM   #18
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks!
More to come
      09-11-2016, 07:56 PM   #19
dre99gsx
Drives: 1994 Toyota Supra
Saw the bulkhead removal pics ... and I thought I was crazy Looking good!
crfine88413.50
      09-11-2016, 08:13 PM   #20
EMP07
EMP07's Avatar
34
Drives: Z4M
Nice Chris, always setting a high bar!
Q: Why VAC vs Macht Schnell floor mounts?, Do you find that at least the drivers side is not shifted to the right enough for the VAC?
Looking forward to seeing more!
BSM Z4M Coupe
crfine88413.50
      09-11-2016, 08:31 PM   #21
crfine88
crfine88's Avatar
414
Drives: E86M
Thanks!
      09-11-2016, 08:42 PM   #22
crfine88
crfine88's Avatar
414
Drives: E86M
Thank you!
I like the floor mounts from MS and VAC equally. I went with VAC this time because I prefer the adjustability of their side mounts and took advantage of their package deal for seat mounting hardware. Was able to save a couple hundred dollars overall installing driver and passenger seats.
I haven't run into any fitment issues using the VAC floor mounts withe VAC side mounts. I have the driver seat installed all the way up agains the center console. There is still room to push further toward the console in the mounts.
I did experience what you are talking about when using Recaro side mount with VAC floor mounts. The narrow base of the Recaro mounts combined with the narrow inside VAC floor mount did not allow enough movement toward the center console. MS Mounts are definitely the way to go in this scenario or any other narrow based side mounts like Recaro
Copyright ©2000 - 2022, vBulletin Solutions Inc.
