06-21-2018, 04:17 PM | #67 | |
Not willing to take advice
4020
Rep 1,519
I've been looking for plantation xo or 20 for years now...everyone talks about it, PA doesn't sell it. Actually in looking, I'm #5 in posting on that thread. How's that for alcoholism. But I can step up my game if needed. Last edited by ShopVac; 06-21-2018 at 04:43 PM.. |
06-21-2018, 04:51 PM | #68 |
Rep 238
Drives: '16 M4
06-21-2018, 04:53 PM | #69 | |
"Salud"
13653
Rep 4,662
Drives: F01 & F15 / Mineral White
06-21-2018, 05:05 PM | #70 |
4020
Rep 1,519
2 subs. If I did 2 subs it'd rock my house apart. My Onkyo can do it...just don't see the need for more
Actually, I lied on my 7.1 system...it is a 5.2.2 Atmos but can run either way (set as 5.1.2 now). Must he the medication I'm on at the moment... |
TXSTYLE13653.00 |
06-21-2018, 05:24 PM | #71 | |
Rep 238
Drives: '16 M4
Some people don't realize that those numbers correlate to the number of discrete channels. And those people often incorrectly think that, because they have two subs, that they now have a 5.2 system. When in reality what they have is a 5.1 system with two subs. But if you're sending a separate and distinct signal to each of your subs, then .2 is valid. By the way, as long as your house isn't made of paper mache, two subs won't hurt anything. I've got two dual-15" driver subs that I punish with LFE content and I've yet to destroy anything. |
06-21-2018, 07:10 PM | #72 | |
Rep 3,235
06-21-2018, 07:43 PM | #73 |
Rep 3,235
Since this is turning into another post up your HT/AV system, here's mine.
Pioneer Kuro 141FD Signature (ISF calibrated by D-Nice from AVS Forum) Oppo Digital BDP-103 Darbee Edition (may replace with UDP-203 I just bought) Meridian HD621 Meridian G65 Bryston 6B-ST Emotiva XPA-2 B&W Nautilus N804 (left, right, left rear, and right rear) B&W Nautilus HTM-1 Velodyne HGS15II w/Velodyne SMS-1 EQ Velodyne DD18 Equitech 2Q balanced power line conditioner on dedicated 20A circuit Equitech 1.5BQ wired in balanced power transformer Equitech 2BQ wired in balanced power transformer VPI HW19Jr w/ MKIII platter upgrade turntable Audioquest PT9 tonearm Sumiko Blue Point Special EVO III HO MC cartridge Vincent Audio PHO-700 tube phono preamp Acoustical room treatments from Acoustical Solutions Room EQ'd via Meridian Room Correction and Velodyne SMS/DD Balanced power transformers with 100A subpanel added when room was built. |
06-21-2018, 10:47 PM | #74 | |
"Salud"
13653
Rep 4,662
zx10guy5139.00 |
06-22-2018, 09:00 AM | #75 |
Rep 3,235
Thanks. If you're ever out in the DC area, hit me up!
06-22-2018, 09:22 AM | #76 | |
Rep 9,004
06-22-2018, 10:23 AM | #77 |
Rep 325
Two subwoofers, everyone in the industry uses the ".1" or ".2" as how many subs are in the system so a 5.1 is 5 main channels plus a sub and so forth.
I agree with you, two subwoofers does not mean louder, just means you're covering the whole sweep and making sure the room is pressurized. |
TXSTYLE13653.00 |
06-22-2018, 11:59 AM | #78 | |
Rep 238
Drives: '16 M4
Let's try this. You have one center channel speaker. Why? Because there's only one center channel. Let's say you split the signal and install a second center channel speaker. Is your system now 6.1? No, it's not. It's still 5.1. Why? Because there is only one center channel and both center speakers are reproducing the exact same signal. The .1 doesn't change, regardless of how many subwoofers you have, until each of the subwoofers are being fed something different that the others are not. |
06-22-2018, 12:30 PM | #80 |
Rep 238
Drives: '16 M4
The masses also write "your" when they should write "you're". That doesn't make them correct.
I'm just trying to help educate. That's all. |
06-22-2018, 12:52 PM | #81 |
"Salud"
13653
Rep 4,662
Oh brother... Tried to give you credit and you have to clap back. *sigh
MKSixer34171.50 NCThreePedals226.50 |
06-22-2018, 01:22 PM | #82 |
4020
Rep 1,519
Back on track...is there a website that has more codes for setting up remote controls? I can't find a code that allows my main Tivo system remote to work the volume on my Onkyo unit.
Or...is there a really good remote out there that truly runs everything? Running 4 remotes right now cause I can't get one to do everything. Suggestions? |
TXSTYLE13653.00 |
06-22-2018, 01:26 PM | #83 |
Rep 3,235
I've posted this pic before. It's the actual in room measured response doing a frequency sweep. It's done via Trifield DSP mode on my old Meridian 568.2MM but the sub setup is the same as I've described with each sub getting discrete signals.
I didn't think to take a picture of what the current in room response is with my new G65 processor adding in Meridian Room Correction into the mix. But it's pretty similar. With the setup this way, the bass goes deep without any boom. The musicality and integration of the subs with the main speakers is extremely transparent. My buddy who managed an A/V store where I got some of my equipment from came over to audition the system when it was completed. He commented on how well everything is dialed in. And this is the reason why I have not bothered to audition anything new...especially speakers. I don't need to go down that financial rat hole....although if I had to do it again...I would have not purchased the HTM-1 center speaker and picked up a N804 floor stander instead to get 100% exact sonic matching across all channels. |
06-22-2018, 01:33 PM | #84 | |
Rep 3,235
wrickem2101.00 |
06-22-2018, 02:11 PM | #85 | |
"Salud"
13653
Rep 4,662
But if you def want a universal, go with Harmony Elite. It wasn't available back when I used one. Reviews are stellar!
06-22-2018, 05:05 PM | #86 |
Rep 3,235
In general, I do like the Harmony remotes. But there are some really annoying things about them. Of all the Harmony remotes I've had, the Harmony One was the best in practical use. I don't know who came up with the layout first...whether it was DirecTV or Logitech or someone else. But the layout of the Harmony One or the old school DirecTV remote was just perfect. It was large enough to have all the main buttons you would want to access without scrolling through soft buttons/menus, but small enough to be practical. What I didn't like about the Harmony One was the lack of being able to set the sleep timeout of the remote. I would be in the middle of fast forwarding through a recorded show and miss where I want to stop because I had to wake the remote back up. Plus there seems to be a sensitivity issue as pressing the button is sometimes not enough. You have to press again to get the remote to recognize you pushed that button.
And the most annoying thing about Harmony remotes...the stupid low battery warning. I seem to recall if the remote takes alkaline batteries then it'll just keep going until the batteries lose power without the stupid annoying warning. With the ones which have rechargeable batteries, it'll throw up the annoying low battery warning. You then have to acknowledge the stupid warning before you can use the remote again. The Harmony One is notorious for this. The dumb thing should just throw up the warning once if Logitech is so insistent on having it. But the dumb thing keeps popping up as if to nag you to throw the remote on the charger. At least the Harmony 1100 allows the physical buttons to still work but the touch screen is locked out. Especially when you get the final warning about low battery....you can't click OK to get past it. While on the Harmony 1100, I want to know what idiot at Logitech thought it was a good idea to make the pause button the largest button in the playback controls and have it dead center while the play button is a small little button that the pause button normally should be. I called support on this and there's no way to change the buttons nor is there a way to reassign the functions where the big pause button is now the play button even though it shows pause. I have one of the Elite remotes now but haven't had a chance to run it through its paces. |
06-22-2018, 08:59 PM | #87 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
To prove my bonafides, this is what I do for a living. Here is the 7.1.4 room we're building at the moment in Montclair NJ... It actually has 4 subwoofers, but it still can rightfully be called a ".1" as they're all acoustically coupled in one location (lined up below the 2.35:1 acoustically-transparent screen). This happens to be our first room using SONY's bad ass VPL-VW5000ES LASER (rec.2020 capable) 4K projector. The room will cost ~$100k without equipment, but including custom Cinema Tech seating, Owens Corning custom acoustic treatments, and starlight ceiling.
EL Jeffe 5608.50 Bingham276.00 |
06-23-2018, 09:00 AM | #88 | |
"Salud"
13653
Rep 4,662
Dog Face Pony Soldier9719.50 |
