      08-17-2013, 09:31 PM   #1
Lefix
Drives: X5 4.8i
Door handle part needed, I have part number but can't find part, can someone help?
Hello guys,
I have a 2003 Z4, the driver door exterior handle doesn't work. I took the handle apart today, and found that the cable is broken. I took the cable out and the part number seems to be 036784119/04, but I cannot find anything online under this number.
Does anyone have any idea on what the part number should be? Any help will be appreciated!
      08-17-2013, 09:57 PM   #2
Lefix
Drives: X5 4.8i
I searched around a bit more and actually found it. It is #7 in the diagram below:
Part# 51217036784 FRONT DOOR LOCK BOWDEN CABLE
I wanted to post it here so if someone else searches in the future they will be able to find it.
      08-17-2013, 09:58 PM   #3
Lefix
Drives: X5 4.8i
$16.60 shipped, sure beats $300 from the stealership!
      08-17-2013, 10:17 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
Nice find. Where did you get that diagram? Image quality is really good.
RealOEM.com is the usual go-to for parts diagrams, but the images are low res.
I just discovered BMWfans.info, which has real nice images.
