      04-29-2020, 08:15 AM   #1
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Inspection I/II Long Term Schedule
How are folks handling these service intervals long term? When annual mileage was closer to 10-12k I was following a 15K/30K interval for the inspection I and II services.
Now that mileage is closer to 4K annually should I alternate inspections annually or is that overkill? Car is still taken to the track 3+ days a year.
      05-11-2020, 06:00 PM   #2
GyroF-16
GyroF-16's Avatar
15
Drives: Z4 M Coupe
I don’t see any reason to base the inspections on anything but mileage. My Z4MC has had the valves “adjusted” every 15k mi, and no shims were needed on the last 2. So lots of time and money to learn “it’s all good!”
Now, certainly fluids (brake, oil, coolant) can warrant replacement based on time, but pretty much everything else is most rationally tied to mileage.
      05-12-2020, 08:07 AM   #3
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Originally Posted by GyroF-16 View Post
I don’t see any reason to base the inspections on anything but mileage. So lots of time and money to learn “it’s all good!”
Glad to hear it! This is the adage I have been following and so far so good. Fluids are cheap and I flush the engine oil spring/fall and address brake, MT, diff, coolant, etc. at bi-annual intervals unless otherwise merited.
      05-12-2020, 07:07 PM   #4
bwright657
bwright657's Avatar
258
Drives: 08 Z4 M Coupe
That sounds like a perfectly reasonable plan. Brake fluid should definitely be addressed with time since it absorbs water regardless of how much you drive it. The diff and transmission would probably be fine to wait if the car stayed on the street. But with track use, they should be changed regularly. Only thing I'd add is checking the suspension bushings, driveshafts and and steering rack before each track day.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
Search this Thread:
Advanced Search
