      10-26-2009, 02:42 AM   #1
JB 007
JB 007's Avatar
Cyprus
44
Drives: Z4MC RRS MINI...
Lowering problems with H&R Coilovers
Hi
I have H&R Springs on car till I install H&R coilovers.Front drop is just perfect but problems on lowering rear.No problem on shocks.Problem is at lowering adjuster part on springs.When we adjust lowest range and put on the car, car is high as standart car setup.We try install springs without adjuster but car is too low to rub tires to fenders. What can I do now??
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
      10-26-2009, 02:50 AM   #2
JB 007
JB 007's Avatar
Cyprus
44
This is the adjuster part and lowering on front...
      10-26-2009, 09:39 AM   #3
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
do the instructions give you a diagram of how the rears are supposed to be installed? did you try adjusting them the opposite way to see if they raise or lower the car?
      10-26-2009, 09:51 AM   #4
JB 007
JB 007's Avatar
Cyprus
44
Don't give any fitting intructions..
      10-26-2009, 11:05 AM   #5
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
i beileve this should be similar and may help you
http://www.eurotuner.com/techarticle.../photo_01.html
      10-27-2009, 02:12 AM   #6
JB 007
JB 007's Avatar
Cyprus
44
Yes It really helps..Thank you very much.. I think we install the adjuster wrong....
      10-27-2009, 08:44 AM   #7
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
parakalo
go Omonia!
