      07-09-2009, 06:54 AM   #1
JB 007
JB 007's Avatar
Cyprus
44
Drives: Z4MC RRS MINI...
Lowest Suspension??
I use H&R springs on my car.Now I would like to buy a coilovers but I dont now which brand I buy for the very low car.I need the lowest coilovers to install my car.Any ideas please??
Thank you
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
      07-09-2009, 10:26 AM   #2
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
TC Kline can get the car VERY low. Especially using their shorty springs with perch adjusters. My car is very low but still drivable with caution on the TC setup, handling it superb.
      07-09-2009, 12:39 PM   #3
GP20
Drives: Z4M, F80 M3, 991.2 GTS
If you want the lowest, get the KW's.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      07-09-2009, 03:16 PM   #4
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
This low enough ?
I drive it like this every day no prob.
      07-10-2009, 01:16 AM   #5
JB 007
JB 007's Avatar
Cyprus
44
Yes its very low Thanks..
      07-10-2009, 03:00 AM   #6
OutOn
zetero
OutOn's Avatar
Spain
Drives: Z4M Coupe
Originally Posted by onelove View Post
This low enough ?
Would you share your spring rates please?
      07-10-2009, 04:35 AM   #7
Matjo
Drives: Z4 M Coupé
onelove, any rubbing issues at all? Mine is not that low in the front and rubs a bit when I press it...
      07-10-2009, 09:03 AM   #8
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Haven't noticed any rubbing even at full lock, I also have 10mm spacers on the front, car has tons of negative camber, and some clearancing on the plastic front fenderwells. I'm pretty sure the springrates are 500/600 but will have to double check when I get home. I've used various springrates on my previous coupe and it's jogged my memory a bit.
      07-10-2009, 11:12 AM   #9
OutOn
zetero
OutOn's Avatar
Spain
Drives: Z4M Coupe
Thank you very much for the info!
Lovely car BTW.
      07-29-2009, 02:00 PM   #10
apexstrafer
Drives: Z4 M Coupe
This low enough ?
Beautiful
Do you drive the car hard like that? Does it still have enough compression travel to deal with choppy/not-perfectly-smooth roads at high speeds? I really want to run a slammed ride height like that when I get my coilovers but I often drive "enthusiastically" on backroads that aren't exactly pool-table smooth. I don't want to be hitting the bump stops all the time...
      07-29-2009, 07:38 PM   #11
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Originally Posted by apexstrafer View Post
Beautiful
Haven't had any problems with it as of yet, most of the roads here in FL are pretty smooth. Only area I've had compression problems with was a small road course here that was repaved, including a nice 1" drop in the middle of the apex of a tight sweeper, I probably could have tightened the dampers to deal with it but realized that going home was a much better option. Other than that the car has been fine at the current drop. I do have RPI skid-plates on the front just incase, but don't have to many scratches on them yet.
      07-30-2009, 12:42 AM   #12
JB 007
JB 007's Avatar
Cyprus
44
What about the H&R Coilovers? Front 2" Rear 2" lowered..
      07-30-2009, 12:48 AM   #13
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
As onelove noted the TCKline D/As can go ridiculously low...negative camber on my car is significant....the other day my wife asked me "are your front wheels broken?"
I have no rubbing (full lock to lock) with 19" BBS RGRs with the ride height very low...in fact the other day I bent my RPI skid plates....this was okay as I have some scratches from tracking and running the curbs hard....I just removed the skid plates and hammered them straight again.
I haven't tracked this set up yet but will in a week or so....
