10-18-2020, 08:25 AM | #8009 | |
Schmollbraten
12512
Rep 1,985
For my taste they'd increased the difficulty at the actual version, at legacy winning even on hard notch wasnt so tough.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
10-18-2020, 09:52 AM | #8010 | |
2006 TIME Person Of The Year
9720
Rep 6,445
10-19-2020, 09:04 AM | #8011 |
9720
Rep 6,445
I'm always trolling for new glasses and these checked all the boxes. I'll return them if I don't like how they look when they arrive, but that's unlikely.
King Rudi13154.00 nyalpine907433.00 |
10-19-2020, 10:23 AM | #8012 |
Rep 1,965
Dig. Looking for new frames myself. After losing the weight, my frames are too big for my head now.
10-19-2020, 12:05 PM | #8013 | |
9720
Rep 6,445
10-19-2020, 12:08 PM | #8014 | |
Rep 1,965
Something I didn't realize when I started this journey is that your body loses it's fat as a whole....as in percentage. If you lose 5%, you lose 5% everywhere. Plus side to this, it does make your package bigger as well. That in itself is enough motivation to lose weight. |
10-19-2020, 01:54 PM | #8015 | |
Rep 4,365
King Rudi13154.00 |
10-19-2020, 04:29 PM | #8016 |
Rep 2,385
10-20-2020, 07:18 AM | #8017 | |
XK Red 27 Technique
576
Rep 10
"No matter where you go, there you are..." Buckaroo Banzai 2018 G01 X3 M40i | Alpine White 3 | Cognac Vernasca Leather | 21" Rims | Tow Hitch | Bone Stock 2002 BMW R1100S BCX | 2007 BMW G650X Challenge (sold) | 2012 BMW R1200GS Adventure (sold) | 1999 Alpine White E36 323i Convertible (sold) | 2012 F30 335i (sold) |
10-20-2020, 08:14 AM | #8018 | ||
Rep 1,965
macadamia9576.00 |
10-20-2020, 08:35 AM | #8019 | ||
Rep 1,923
Just saying...if you start out with a nub... |
10-20-2020, 09:42 AM | #8020 |
XK Red 27 Technique
576
Rep 10
My nw welding table!
Well, the absolutely last thing I bought was a sandwich from Jimmy John's, but my last major purchase was this welding table. It is a made in USA, Certi-flat FabBlock FB3030 and has a base kit with casters that I have not built yet. I followed the directions to a tee and have had a bit of an issue with the top not being completely flat. I had to cut out the welds between the frame and the top and will attempt to reinstall the top flipped over. The manufacturer says this should take care of the flatness issues and if not, they will ship me a new table!
I'm just learning how to MIG and TIG weld, and I have not stick welded since 1990. Photo 1: Action shot of me tack welding part of the bottom of the table on the temporary workbench. These are the support ribs and sides that give the table it's very rigid and flat construction. Photo 2: Assembly complete, need to check for flatness and adjust as necessary. I had issues here so I had to remove the top. Photo 3: Using a Dremel tool with a cutoff wheel to cut the welds between the tabs of the table underside and the slots in the table top. Photo 4: Tapping the top off with a small 3 lb. sledge hammer. Photo 5: Moving the top off of the temporary workbench. Photo 6: The table support structure after removing top. Photo 7: Close-up of the support structure tabs before grinding out the rest of the welds to dress up the tabs to reinstall the top. Photo 8: The top of the removed top. This will become the new bottom of the top. Photo 9 The bottom of the removed top. This will become the new top of the top. Photo 10: Close-up of the damage caused by using a larger cut-off wheel on my 4.5" angle grinder. These will ultimately be on the bottom of the top and I'll do some weld fill-in after the table is reassembled and welded out. Photo 11: Close-up of the same area in Photo 10 but on the other side. I have all of the tabs dressed on the table support structure and started to file down some high spots that I found. I hope to dry-fit the top today and if I can get it flat, weld it out. If not, I'll wait until the new one comes.
10-20-2020, 12:01 PM | #8023 | |
Rep 1,923
Hopeless dude - I'd just start googling prosthetics and go from there. Some real advancements in that field. I think you'll be satisfied. Either that or you could go with the cheaper option of some J-B Weld and a dildo. |
King Rudi13154.00 |
10-20-2020, 04:32 PM | #8024 |
Rep 2,807
Drives: F33 430 and F39 M35i
Son got me the Lightsaber book from Amazon today and I got him the Big Brick neopixel lightsaber today.
10-20-2020, 04:51 PM | #8025 | |
9720
Rep 6,445
(Joking)
10-21-2020, 04:40 AM | #8026 |
Schmollbraten
12512
Rep 1,985
This would be the next step after all books
10-21-2020, 08:49 AM | #8028 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
These are the car related things I bought recently..
Common sense is a flower that does not bloom in everyone's garden
10-21-2020, 09:15 AM | #8029 |
Rep 14,115
Drives: G82 M4C X-Drive
Is that a replacement for the horrid E9X cup holder or a completely new way to have one more cup holder?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
10-21-2020, 09:43 AM | #8030 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
A replacement, I just got one used from a low mileage car. I bought my other one from the same dude and it works perfectly
