      08-14-2010, 11:37 PM   #45
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by XMetal View Post
Does anyone knows if the back braces are "back-cut" to allow them to bend or break during a front end collision (similar to the dinan design)? If not, these two bars can potentially get pushed through the firewall into the passenger compartment during a front end collision.
Whoaa, good catch! Now I'm curious as well =O
      08-15-2010, 12:57 AM   #46
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
1. 45ACP / Z4MC / Complete set / Titanium silver
2. inTgr8r • Z4MC • Complete set • black textured
3. nmulax / Z4MC / complete set / black textured
4. crfine88 / Z4MC / complete set / black textured
5. shakib / z4mc / complete set / black textutred
6. a_riddler / Z4MC/ complete set / black textured
7. Tonybest • Z4MC • Complete set • black textured
8. Shereef_Osman / Z4MC / Complete Set / Black Textured
9. MakoBimmer1 /Z4MC/ Complete set/ Titanium Silver or Black
10. The__J__Factor • Z4MC • Complete set • black textured
11. slikm / Z4M / Complete set / Titanium Silver
12. fatmatt0116 Z4MC / Complete Set / Titanium Silver
13. Hairballs58 / Z4MR / Complete Set / Titanium silver
14. z4mc4s / Z4MC / Complete set / Titanium silver
15. xmetal / Z4MC / Complete set / Titanium silver
16. Crimson92 / Z4MC / Complete / Black Textured
17. mfanatic325 / Z4MC / Complete Set / Black Textured
18. Skelekitty • Z4MC • Complete Set • Black Textured
19.
20.
21.
22.
23.
24.
25.
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
      08-15-2010, 07:55 AM   #47
RBull
Drives: 2007 M Coupe
Depending on price will consider front bar only.
19. RBull / Z4MC / Complete Set / Black Textured
20.
21.
22.
23.
24.
25.
      08-15-2010, 10:01 AM   #48
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Good luck guys on this, I have the strong strut myself and the quality is unbelivable but I don't recomend using the acorn nuts that it comes with it. I had some problems with them and I know other people that did two. So get a set of OEM's to use instead and please don't make a costly mistake trying to reuse the ones that was in your car because they are one time use type nuts.
      08-15-2010, 12:17 PM   #49
kav
Drives: Z4M
What problem did you have with the acorn style nuts that came with the kit? I installed mine with them and they seem to install okay but maybe I should swap them out.
      08-15-2010, 02:19 PM   #50
mfanatic325
///M-fanatic
Taiwan
193
Yeah, and also, did you have the full kit or just the strut towers brace?
      08-15-2010, 03:43 PM   #51
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
You don't happen to know the part number do you? (Sorry, I know you're helping us out here and then we pepper you with tons of questions....)
      08-15-2010, 04:11 PM   #52
Diokaef
Engineer
Diokaef's Avatar
Yes I have the complete kit, the acorn nuts don't provide the correct depth so they will not provide the full tighteness that our suspension require, In other words they will bottom out too soon but It's almost not notecible. Also I had this problem twice, the parts will move getting out of position as the time passes.
I will try to get the part numbers for the hardware needed.
      08-15-2010, 04:13 PM   #53
Diokaef
Engineer
Diokaef's Avatar
The braces itself are much better then Dinan or oem in my opinion tho (I used both before OEM and Dinan)
      08-15-2010, 06:00 PM   #54
r0ckstar
Daman
r0ckstar's Avatar
Drives: Z4 ///M roadster
Complete set BLACK
IN!
VERY IN!
was going to buy OEM strut bars.
      08-15-2010, 09:42 PM   #55
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
20. r0ckstar / Z4MR / Complete set / Black textured
21.
22.
23.
24.
25.
      08-15-2010, 10:02 PM   #56
F360C
Drives: E86 S54
Is there any idea of what the price might be?
07 Z4 M Coupe AW/IR
      08-15-2010, 11:14 PM   #57
mfanatic325
///M-fanatic
Taiwan
193
As of right now we don't have finalized pricing just yet. The OP is working on it. The more interest we have for it though, the lower our pricing is going to be
      08-15-2010, 11:51 PM   #58
reyebe
Drives: 2007 M Roadster
The complete set^ includes extended accessory kit.
Is that the large kit c/w the tower caps or the small kit w/o caps?
large
small
...change my interest to 'complete set' plse.
you get the entire set with the plastic tower caps as you pictured it. Somewhere along the line BMW changed the hardware for the FW braces from a vertical threaded post that accepts a nut, to a threaded chassis that accepts a hex head bolt threaded down into it. In the case of the latter, the 10 mm acorn nuts for the FW braces don't fit so we don't send them.
      08-15-2010, 11:53 PM   #59
reyebe
depends upon the total number of orders. The more orders, the lower the price. However, we have not raised our prices in 5 years although our material and manufacturing costs have increased substantially. We will do the very best that we can for all of you with regard to price.
      08-15-2010, 11:56 PM   #60
reyebe
please tell us what the issues are with the acorn nuts because we have not had this reported previously. There is an issue with the OEM nuts and that is the fact the come in two shoulder diameters, large and small. The large ones do not fit in the counterbore of the Strong-Strut shock tower ring but the small ones fit perfectly. We have no idea when BMW made the change so so send everyone the small kit with the acorn nuts.
Paul at Strong-Strut
      08-16-2010, 12:19 AM   #61
Diokaef
Engineer
Diokaef's Avatar
Hey Paul they are not deep enough (acorn nuts), and it can also cause damage to the suspension hardware do to the fact that they can over torque the studs when bottom out (even using recommended spec. of torque) some studs ended up striped as well.
I never believed I had a need to report this since I'm very satisfied with the STRONG-Strut Product and that until not long ago I believed that was only me having problems. As of my recommendation for OEM I based myself on the experience that I had using different (claimed better, or as good) Nuts, and the Great quality of the ones from BMW that did not ever gave me any problems.
      08-16-2010, 12:54 AM   #62
Diokaef
Engineer
Diokaef's Avatar
Also none of the suspensions that we used was OEM so I can't say nothing about the use of the Acorn nuts on OEM suspensions.
      08-16-2010, 01:44 AM   #63
lo-tek
I'm a PC
Drives: 2012 135i M-Sport Coupe
how much?? I may be in.
      08-16-2010, 09:28 AM   #64
RBull
^if you're seriously interested add your name to the list. Read the post 4 before yours for the answer on price.
      08-16-2010, 10:03 AM   #65
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
Interested depending on when and the discount, very tentative as I have personal things going on. Possible move, new job, etc.
21. Juice84 / z4 2.5 / complete set / black textured or titanium silver
22.
23.
24.
25.
      08-16-2010, 12:52 PM   #66
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
Response from the vendor:
"Now it is making sense, he had an aftermarket suspension and apparently the threaded studs were taller than stock. This WOULD cause the acorn nut to bottom out and not be snugged down. Had he contacted us at the time we would have sent him some extra, matching, stainless steel washers."
