09-08-2012, 09:50 AM | #1 |
Rep 250
Alignment Critique Please
I want high speed stability, better front turn in and less front tire wear on the outer edge.
Camber shims installed. Stock suspension and wheels, 245/265 tires, sport street driving, 3 driver training days. I am concerned that reducing rear toe below OEM settings will impact high speed turn stability. -2.00* front camber .00* front toe -1.58* rear camber .37* rear toe Front Camber......... -2*00' +/-20'.... -2*20'/-1*40'...... -2.33*/-1.67* Front Total Toe In... 0*06' +/-06'..... 0*12'/ 0*00'......... .20*/.00* .. Rear Camber.......... -1*50' +/-15'..... -2*05'/-1*35' .... -2.08*/-1.58* Rear Total Toe In... 0*28' +/-06'...... 0*34'/ 0*22' ...... .57*/.37*.. Last edited by Punko; 09-17-2012 at 07:54 PM.. |
09-08-2012, 12:32 PM | #2 |
1821
Rep 5,337
High speed stability = toe-in front and rear. Better turn-in = toe-out front and negative camber. Less front tire outer edge wear = negative camber and less toe-in.
09-08-2012, 11:28 PM | #5 |
1821
Rep 5,337
Oversteer? At speed? You'd have to royally f**k up the alignment on this car to create that sort of handling characteristic.
As long as you have some minor toe-in in the rear it's unlikely to see high-speed oversteer in this chassis.
09-09-2012, 07:49 AM | #6 |
Rep 250
OK, great, again thanks for the comments.
If sticking to stock range in the rear, what would be the recommended target values? This is the stock range: Rear Camber -2.08*/-1.58* Rear Toe .57*/.37* |
09-09-2012, 11:20 AM | #7 |
1821
Rep 5,337
The smaller of the two camber will give you better rear tire wear, but reduce rear grip. Depends on how much "spirited' driving you do, if you don't track the car often I'd go with the lower end of the camber (-1.58º).
Couple that with moderate rear toe-in you should get pretty even wear AND good high speed stability. I'd go for a figure that falls somewhere between the two toe settings, and see if you can shoot for 0º 45' or thereabout. Too much rear toe will make the outside edge wear accelerate.
09-11-2012, 07:12 PM | #9 |
Rep 250
Went to my local dealer for the alignment...they can't do it without taking the front bumper off.
The arms come off the center of the wheel cannot extend past the front of the bumper to measure toe. Hunter machine about 7 to 10 years old. There is another dealer that has their machine in a pit and uses different arms and lasers. |
09-11-2012, 08:03 PM | #10 |
703
Ugh, I didn't know you were going to have a dealer do this.
Save yourself a headache and call and see if they'll even do a "performance alignment" before wasting your time. Many will not do anything but stock specs, and -2.0 is not stock and neither is zero front toe. Some dealers are great, I'm not saying all have issues, but there's a range of tolerance for mods and spec deviation that they'll tolerate. Also know that many are not super particular about how close they get it to your specs (you'll hear "it's in the range"), so make sure they are really going to nail it for you before leaving the car. I get the sense from this and other threads you are (as many of us, including me) are kind of particular about what you want/expect. I bet that most indies or race shops will probably work better for what you're looking for, and be able to provide good feedback/input as well. |
09-11-2012, 10:12 PM | #11 | |
enthusiast
48
Rep 1,695
What Fin said! |
09-12-2012, 05:48 AM | #12 |
Rep 250
Thanks guys, they had no problems with the specifications I gave them and also the range that I wanted.
I may make the camber tool used on the top of the strut so that I can release the three fasteners at the top, push to the motor and accurately return back into position. |
09-17-2012, 05:23 PM | #13 |
Rep 250
So here are the numbers I ended up with, spacer shims installed.
Couldn't get the front R camber closer to -2.0, best we could push it down to was -2.88. Tech recommended the slight front camber difference from left to right would help keep the car tracking on roads with a crown. Why would my right rear toe have been out so much? Front Camber L/R Before: -2.43*/-3.04* After: -2.65*/-2.88* Target: -0.50* to -1.500* Front Toe L/R/Total Before: -.12"/-.09"/-.20" After: +.00"/+.00"/+.00" Target: +.00" to +.04" (total) Rear Camber L/R Before: -1.73*/-1.40* After: -1.89*/-1.84* Target: -1.75* to -1.91* Rear Toe L/R/Total Before: +.07"/-.01"/+.06" After: +.04"/+.04"/+.08" Target: +.09" to +.15" (total) |
