04-07-2019, 04:58 PM | #1 |
Rep 110
What is this tiny severed wire against the firewall?
Checking under the hood prior to a Sunday drive and found this wire that has broken or been cut. The long piece comes off of the battery terminal, the short piece towards the top of the photo is from the cable bundle. What is it and could it be the reason why I suddenly have an airbag warning light?
04-08-2019, 10:58 AM | #2 |
Rep 411
I believe that is what is called the B+ wire that is part of the SRS system. I would definitely rejoin those wires with a properly soldered join covered with heat shrink.
You will need to clear the error code it generated afterwards.
Sent from my smart phone...
04-08-2019, 11:13 AM | #3 |
Rep 4,057
I would think that a section of wiring like that would be considered a critical part of the car's occupant safety system and that its' housing and routing through the car would be robust and designed to protect it from inadvertent damage.
Huz-Z
04-08-2019, 03:53 PM | #5 |
Rep 218
Could it be a part of the alarm system? While it may not have an alarm, they were wired for them.
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
04-08-2019, 05:54 PM | #6 |
Rep 110
If your explanation is correct, would there be other noticeable symptoms of an unpowered ECU after shut off?
04-08-2019, 07:46 PM | #7 |
Rep 484
Yes, it can throw eroneous codes.
I have a battery cutoff switch in my track car and was getting odd codes. Was told by tuner to let the ECU have power for several minutes after engine shut down before cutting battery. Curied the odd codes. Reconnect that wire, reset the SRS light and see if this solves your issue. |
