03-26-2019, 01:40 PM | #23 | |
Rep 344
How often is a valve adjustment needed? Inspection 1 was done at 22k. Car is at 33.5k now. I know about the rod bearings but was not expecting to worry about that until I get to the 60k mark. As this isnt my daily I dont expect to ever get to that number during my ownership anyway. With only 33.5k miles do I need to worry about vanos and take preventative measures? When you say to check bolts and hub ASAP it worries me lol I'm not as mechanically inclined as many members here so I would need to tell my shop to take a look for me as I wouldnt know what to look for. I'm fairly certain I can manage a valve adjustment on my own but when it comes to terms like "beisan pump disk" and the vanos components I am a bit lost. Not sure how costly these items and the labor are either. Also a few people mentioned the Royal Purple tranny fluid but I read online that it might be thinner then the OEM fluid. Does this mean if I go that route I should expect to change it often? Is there a mileage interval for tranny fluid I should know? |
03-26-2019, 03:26 PM | #24 |
Rep 2,866
Valve adjustment is every inspection. If your car is at 33.5k now, I would just wait until inspection 2 for the next valve adjustment.
Vanos preventative is just that - preventative. Do it when you see fit. But the sooner you do it, the less you have to worry about the hub tabs breaking. Not sure if the '06 have the problem of the Vanos bolt shearing off, but I would do that as well regardless when you do the pump disk - See the Beisan S54 procedures for more info => http://www.beisansystems.com/procedures/index.html Transmission fluid change is every inspection 2 per BMW's maintenance. However, I've always change mine out every inspection - roughly every 25k - 30k miles. So, using the RP fluid wasn't really an issue for me. I've asked the same question a few years back and how I had arrived at RP => https://www.zpost.com/forums/showthr...t=royal+purple Last edited by XMetal; 03-26-2019 at 03:32 PM.. |
03-27-2019, 08:12 AM | #25 | |
Rep 344
03-27-2019, 11:46 AM | #26 |
Rep 1,772
Drives: 2007 Z4M Coupe
Oh nice! I do get together with a few friends few times a summer and we do some nice scenic runs around the state. Looking forward to seeing you around town.
03-27-2019, 12:04 PM | #27 | |
636
Rep 3,124
Nope. Just straight RP Synchromax. Not sure if anybody mentioned the diff. Probably want to stick with OEM SAF-XJ+FM.
03-27-2019, 12:14 PM | #28 | |
salty cowboys fan
6158
Rep 3,406
Good read on the vanos failures - https://www.langracing.com/beisan-sy...d-maintenance/
she’s home! '22 M4 Comp xDrive
03-27-2019, 01:12 PM | #29 |
636
Rep 3,124
My bolts were broke when I bought the car at 40k miles.
When I took it home the Wife says "is it supposed to make that noise?" My hub broke somewhere short of 90k miles. Replaced it with a C300.
03-27-2019, 05:05 PM | #30 |
Rep 3,004
ASAP, have your tech save appx 6 oz of used engine oil (take sample 1/2 way through the drain process)and send to Blackstone Labs for oil analysis; their lab report will advise if you have potential connecting rod bearing wear; perform this test every oil change or annualy, whichever comes first; a $30 investment that allows you to to create a data trend to ID internal wear and a multitude of other lab tests of your oil.
03-29-2019, 10:10 AM | #31 | |
Rep 1,373
07 Z4 M Coupe AW/IR |
03-29-2019, 02:41 PM | #32 | ||||
Rep 344
Also thanks to everyone for taking the time to reply. Learned a lot of valuable stuff thats helped tremendously, greatly appreciate it! |
04-06-2019, 07:04 AM | #34 |
Rep 382
CDV delete, change the motor mounts, trans mounts and get a ZHP shorty shift knob. Just because it's low mileage doesn't mean the rubbers haven't worn out do to age. My roadster had a cracked motor mount with 56k on them.
Also check your lower rear trailing arm bushings, coil packs and pre cat 02 sensors. I first went with the Bimmerworld solid rubber mounts and Rouge trans mounts. Completely got rid of any shifting issues and was an absolutely pleasure to drive but at idle the whole car would shake, rattle and roll. I then went with the new kid on the block, 034 Motorsport mounts through ECS, they are solid rubber but softer, completely got rid of any NVH but a little bit of the tricky shifting behavior came back. Sacrifices. I agree with everyone else it's just the nature of the beast. My 350z was the same, terrible at low speeds but a precision rifle at high speeds. |
ryank382102.00 |
04-07-2019, 02:17 AM | #35 |
Rep 384
First things first - This will absolutely help with shifting, especially between 1st and 2nd gear.
Reset your Adaptive Throttle Response! This has been posted many times in this forum. If you bought a used Z4 the "Adaptive Throttle" is adapted to the previous owners driving style and if it was a grandma or just some slow poke-ass driver who thought it was better to look good than to drive good, you will notice a difference. Turn ignition off Turn key to "on" position Wait 15 seconds Turn ignition off Wait another 15 seconds Start the car Drive away normally What this does is reset the adaptive throttle response to factory settings, basically erasing from memory the previous owner and starting anew. If the previous owner drove just like you, you may not feel a difference, But what the heck, its yours now. Out with the old I always say. I do this any time clutching and shifting starts feeling like it's fighting with me.
04-08-2019, 08:17 AM | #36 | |
Rep 344
Honesty not sure which helped the most but after cdv delete and tranny fluid flush with Royal purple my shifts are spot on I have no problems anymore thankfully. Or maybe I just needed a little more practice but either way shifting is good Next step is getting a solid SSK |
04-11-2019, 08:39 PM | #37 |
Rep 215
It's definitely a car you need to learn to get the most out of. With the shifts, with a shorter ZHP weighted knob, it seems to shift best when you are shifting fast. Love that it always encourages me to drive faster
