      11-13-2017, 03:39 PM   #1
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Broken Factory Fender Strut Brace Mount Fix?
A long time ago, the factory strut brace fender mount on my '04 3.0i broke off (number 6 in the attached image, p/n 41007193040) and I am now looking to fix the mount. When it originally broke, I bought and used the ultra racing 3 point brace off of eBay as the fix. However due to a change in my local CCA autocross rules, this aftermarket brace will push the car into a higher class and I need to revert to the factory braces, or run without.
Has anyone encountered this issue before? If so, is this something a YouTube Certified shade tree mechanic like myself can fix or is this something a body shop needs to handle?
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      11-15-2017, 03:13 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Weld it up?
      11-15-2017, 03:17 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10624
Drives: Z4 3.0i ESS TS2+
There's a bmw repair instruction for that.
It basically says to weld the facelift strut bar bracket in place (so welding required)
Dont run the car without the braces!
jns_e8574.00
      11-15-2017, 08:58 AM   #4
jns_e85
jns_e85's Avatar
74
Welp. I am better at flying like a bird than I am welding, so guess i have to find a shop. Any link for the repair instruction? Couldn't seem to find one when searching here...
For now the eBay brace stays on!
      11-15-2017, 10:09 AM   #5
SaltyNC
SaltyNC's Avatar
369
Drives: 2006 BMW Z4M Roadster
I don't have the bulletin, but I bookmarked this page some time back:
http://www.bimmerfest.com/forums/sho...d.php?t=231800
Edit: There is a link to a bulletin in the last post in the thread linked above.
Hope that helps.
Salty
jns_e8574.00
      11-15-2017, 11:38 AM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10624
Here you are
I think there's one page missing (page 2) but you get the point.
jns_e8574.00
StickMon636.00
      08-26-2018, 12:17 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
This just happened to me.
Looks like this is probably the aforementioned ultra racing 3 point brace, and I bet it won't fit over an S54.
