02-07-2019, 06:25 AM | #1 |
Rep 2,039
Drives: 2022 X6///M Comp
Which windshield cleaner?
What do you guys use to clean your windshield? I have my car about 4 months and I can't get my windshield clean. I have these drip like marks that are making me crazy. I can't get rid of them. And when I use the washers or wipers I get these bad streaks. Not sure if there is some residue somewhere that is dripping. No matter how much I clean the windshield, it doesn't go away. I've used windex and some non streak glass cleaner I use in the house with microfibre cloths but it just doesn't make the glass clear.
Thanks |
02-07-2019, 07:35 AM | #4 |
Run Deep
15127
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [0.00] |
^ This. Works amazingly well. In addition, Stoners Invisible Glass cleaner is available nearly everywhere and I have yet find a better product for normal cleanings.
Here are some links to my favorite products... Best clay - use a clay mitt instead of actual clay, much better: https://www.autogeek.net/cobra-clay-mitt.html Here is the best sealant by far. The ease of use is nothing short of staggering. Will last about 3-4mos on paint, a few weeks on glass if you use your wipers. Amazing product and a bottle will last a year or more. https://www.detailedimage.com/Optimu...-P279/8-oz-S1/ Finally - here is a link to Invisible Glass, although any retail store also has it: https://www.invisibleglass.com/produ...cts/automotive
Don't sweat petty things....or pet sweaty things.
02-07-2019, 07:48 AM | #5 |
Rep 11,135
Clay bar and polish it, either using a machine or by hand. But I don’t seal my front windshield. I’ve experienced clatter before.
02-07-2019, 07:53 AM | #6 |
Rep 2,039
Thanks all!
02-07-2019, 08:00 AM | #7 |
Rep 1,965
I've clayed and polished mine before and even used serium oxide on it last year to remove some scratches and pits but I have never thought to use a DA and polish on my windshield. What polish did you use? 3 or 4 stage?
02-07-2019, 08:22 AM | #8 | |
Run Deep
15127
Rep 4,123
If you want to read up on how to polish your windshield - check out this link by one of the best in the business. https://www.autogeekonline.net/forum...hes-glass.html Here is another good thread discussing some of the things to watch out for when performing the process. Basically, you have to get the glass very hot when removing the defects, but it's easy to get it so hot that you end up warping it and causing more problems: https://meguiarsonline.com/forums/sh...ct-Correction&
02-07-2019, 08:41 AM | #9 | |
Rep 1,965
Run Silent15127.00 |
02-07-2019, 01:30 PM | #11 |
Rep 5,577
Not sure if mentioned above
But I like any good dedicated windshield cleaner spray or foam and use newspaper to apply. I find it curious they dislike newspaper. You cruise down the highway at 75 mph getting peppered by dust... |
cmyx6go15692.00 |
02-07-2019, 01:46 PM | #12 |
Rep 190
I had a bad streaking problem on my 1992 325is after the combination of these 3 things:
silicone blades silicone windshield treatment 1 dusty road that just stuck to everything until I finally cleaned the windshield with denatured alcohol and changed the blades back to factory. If it ain't broke... |
cmyx6go15692.00 |
02-07-2019, 01:52 PM | #13 | |
Rep 2,039
02-07-2019, 01:58 PM | #15 |
Rep 2,039
02-07-2019, 02:09 PM | #16 | |
Run Deep
15127
Rep 4,123
I am absolutely ridiculous when it comes to my front windscreen. Drives my wife nuts because I will pull over to clean a smudge. I typically shoot some glass cleaner (the invisible glass I mentioned) over the window and do a wipe down nearly every morning before work if it isn't raining. That being said - let me know if you have further questions - I've tried literally everything and nothing seems to beat regular quick wipe downs and periodic sealing or clay. Also - when cleaning, always use a dedicated rag just for windows. Had a hard time figuring out why my window would always streak until one day I realized I was using a rag that I had used to remove wax once before. I have also found that the microfiber waffle weave cloths work much better than the normal microfiber towels. The regular ones will sometimes leave little particles behind due to the static they create. Not so with the waffle weave ones. This is the one I use: https://www.chemicalguys.com/Waffle_...BoCRwoQAvD_BwE
02-07-2019, 02:20 PM | #17 |
Rep 2,039
I'm a nut when it comes to clean windshields, inside and out. I always carry windex and microfibre rags. My drivers Ed teacher Mr. Briganza told us the most important thing is to have a clean windshield. Can you imagine? I remember my drivers ed teacher's name from 40 years ago but I can't remember what I left my office to get...
It's frustrating. A new car usually has that nice fresh windshield and it makes me happy when I use the wipers and the windshield is crystal clear and streak free. It's one of the things I look forward to when changing vehicles. Not sure why this one has all these strange drip marks and streaks. I wish the camera would pick up what I'm talking about. |
02-07-2019, 02:28 PM | #18 | |
Run Deep
15127
Rep 4,123
1) Don't use Windex. It's a terrible product. Not only does it leave horrible streaks and stains on your window, if you use it on tint - it will melt it. 2) Don't use normal microfiber cloths - especially on the inside. Use a waffle weave or at least a normal cotton washcloth. In a pinch, a used tshirt is also a good option. Seriously give the clay bar or clay mitt a try - I think you will be amazed at the difference.
cmyx6go15692.00 |
02-07-2019, 02:46 PM | #19 | |
Rep 2,039
02-07-2019, 02:50 PM | #20 |
Hapless Noob
99
Rep 125
I've been using RainX and tired of the clatter; I just can't seem to buff it enough to get it to stop. I'm ready to try the clay mitt and invisible glass... any suggestions how to safely strip the RainX off the windshield?
cmyx6go15692.00 |
02-07-2019, 03:01 PM | #21 | |
Run Deep
15127
Rep 4,123
The most sure fire (no pun intended) way to completely remove RainX is to use naptha. Regular Zippo-type lighter fluid is naptha based. So is Coleman (or similar) camp fuel. You can also use VM&P naptha...found at most home improvement and paint supplies stores. Naptha eliminates any RainX that has even found its way into auto glass' microscopic 'pores'. Here is a link: https://www.homedepot.com/p/Klean-St...VM46/100122813 It's somewhat nasty stuff. If you want to try a more soft method, then most APC's will work with some decent scrubbing. Another alternative is McKee's 37 High Performance Glass Restorer on a White 5 1/2" flat foam pad with a Porter Cable 7424 dual action polisher on speed 4. Link below: https://www.autogeek.net/dp515.html
cmyx6go15692.00 |
02-07-2019, 03:15 PM | #22 |
Rep 11,135
I've had good luck with Duragloss NuGlass:
///M Power-Belgium63209.00 cmyx6go15692.00 |
