04-13-2017, 02:33 PM | #1 |
Rep 16
E46 M3 brakes vs. M3 w/ ZCP package...
Question on the difference. I've done many searches but I don't have the answers I am looking for. Other than the semi-float, larger front diameter, different rear caliper (larger piston), and different caliper bracket, is there a difference on the spindle and/or upright? StopTech offers two different brake kits for regular E46 M3 and E46 M3 with ZCP package. If there is no difference in the spindle/upright, why would they offer two difference products? Also, AP Racing sells two different brake kits for an E46 M3 and a Z4 M Coupe. I own a Z4M and am trying to figure out why an Essex AP Racing brake kit for a M3 will or won't fit my car. I already called and asked Essex and Bimmerworld and they don't know the answer.
Thank you. J |
04-13-2017, 06:54 PM | #2 |
1820
Rep 5,337
They're interchangeable.
04-13-2017, 10:10 PM | #3 |
Rep 10,645
I have Stoptech kits F&R for my car, both were for the M3 w/ZCP. Fronts are plug and play with our cars, as are the rears. The ONLY difference is the Z4M has longer rear brake lines and you need to source those from Stoptech. They sell those however, so it's no issue.
04-17-2017, 07:47 PM | #4 |
Rep 104
Are the piston diameters / areas the same on the OEM E46 ZCP M3 calipers and on the Z4M ones?
Stoptech claims to tune their kits for each application based on optimal F/R brake force distribution, so I wonder if this is why a separate and distinct Z4M kit exists. Beyond that you could adjust the actual F/R brake torque to your liking by running different pads F/R. |
04-17-2017, 08:58 PM | #5 |
1820
Rep 5,337
Yes.
04-18-2017, 03:21 AM | #6 | |
Rep 912
The rear has a different part number just because of the brake lines being longer on Z4M than on e46 M3 ZCP. If you need more information on stoptech kit for Z4M, please post here so that i can provide it or attempt to. I have the trophy 4 piston front kit with stock rears. |
04-18-2017, 01:41 PM | #7 | ||
Rep 1,100
04-19-2017, 06:35 AM | #8 | |
Rep 484
04-20-2017, 11:55 PM | #9 |
1820
Rep 5,337
The Z4 rear brake line comes in two sections. You can get away with only replacing one section.
04-21-2017, 08:50 AM | #10 | |
Rep 912
My kit makes a lot of noise though, i got the race rotors which are fully floating to eliminate knockback (they don't have the cupped washers on the attachment bolts so the rotor is actually floating in the air and when the wheel turns the rotor clunks around on each of the attachement points) |
12-18-2018, 11:52 AM | #11 | |
Rep 175
12-19-2018, 11:18 AM | #12 | |
1820
Rep 5,337
BMW calipers use a screw-in type line fitting, where the line terminates in a threaded tip that goes into the caliper. Some OE fixed Brembo calipers use the same design. MOST aftermarket and the majority of Brembo's OE fixed calipers use a banjo bolt type fitting to the caliper, so the fitting on the caliper end is universal. Changes are pretty damn good that the caliper end fitting for the brake lines are the same. Probably 95% certainty that the banjo bolt fittings are the same between AFTERMARKET solutions like StopTECH, Brembo Aftermarket, Wilwood, AP Racing, Performance Friction, RacingBrake...etc. The hard-line connection (from the flexible brake line to the hard line on the body side of the car) may be different from car to car, but the majority I've seen uses the same threaded collar. The only difference in application is, obviously, the length of the flexible line.
04-03-2019, 11:04 AM | #13 |
Rep 431
Apologies for bumping an old thread but I came across this site with some amazing brake bias data for the E46 M3 that is 100% applicable to the Z4M. Hopefully it's helpful for anyone searching for similar info:
https://thebuildjournal.com/tech-gui...-chart-e46-m3/
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
