      10-12-2018, 12:14 PM   #1
jns_e85
jns_e85's Avatar
34
Drives: 2004 z4 3.0i & 2006 z4M
Anyone run a 265/40/18 tire on the FRONT of a Z4M?
Just curious to see if anyone has run this size tire on the front of a Z4M before (with modified suspension of course).
A friend of mine has Yokohama AO52s and swears by them for autocross duty. Looking at prices, there is a huge difference between the 265/35/18 that I know will fit over the 265/40/18 size he runs on a 350z. ($325 for the 265/35 and $250 for the 265/40).
FWIW I am on FA 500's lowered about an inch with a butt load of front camber (-3.4 front). Set up is intended for regional autocross duty on a tire limited BSP set up. Intended wheel size is 18x9.5 et 35
2006 Z4M - Epic Tune / Turner Pulleys / Eventuri / Euro Headers / Section 1 / Custom Stromungs / FA 500 + Camber Bolts / VT Engine Mounts / RE Trans Mounts / AS SSK / Arc 8s
2004 Z4 3.0i - Koni Yellows / Style 224s / AFE / Stromung Exhaust / Z4M Engine Mounts / M3 Trans Mounts / Beisan VANOS / GAS DISA
      11-05-2018, 02:53 PM   #2
CTMP4me
Drives: 2008 Z4M Coupe, 2019 M2 Comp
I ran 245/40/18 RS4s and they rubbed the front fender liner (running 1/2" lower than stock, 2.5 degrees of camber and max caster). There is a good chance the 265/40 will rub even more unless you run stock ride height. I'm going to 265/35/18 Trofeos on the same spec wheels for next year because of this.
      11-05-2018, 08:26 PM   #3
dc_wright
dc_wright's Avatar
231
Drives: 2006 Z43.0si Roadster
At that price you might as well just ante up for the purple crack since you're already in BSP.
Top Down 365
      11-05-2018, 09:11 PM   #4
jns_e85
jns_e85's Avatar
34
While I agree, and purple crack is tempting, I'm not sure I'm ready for them ability wise. I haven't maximized the BSP build yet either, and would get a front sway before A7s. Still learning the limits!
Further complicating the matter is BSP isn't a popular class locally to me, so if I want competition it makes more sense (and more cost effective) to run in a tire limited class with the BSP index. Also, running Hoosiers will bump me up a class with the local BMW club, and I would have to compete with guys in stripped out SM equivalent cars
      11-07-2018, 04:40 AM   #5
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Curious as well
Instagram: ariusen26
Youtube: Track vids
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
