      07-23-2018, 01:16 PM   #23
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
812
Drives: Independent Tuning Specialists
Agreed that doesn't look right, it sounds like my CS staff are getting you taken care of, please let me know if I need to step in and make things go smoother.
-James
      07-23-2018, 06:36 PM   #24
StickMon
StickMon's Avatar
Drives: 2006 MR
ECS link is 009422ECS01-03.
Picture is 009422ECS01A-01.
I'll be ordering one as soon as this is resolved.
I've always felt queasy yanking the stock one out knowing there's a plastic tip wanting to get caught and break.
Tip is guaranteed not to fall off the ECS stick?
      07-23-2018, 07:13 PM   #25
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
Originally Posted by gpraceman View Post
Why not return it? It is useless to you, as the min/max ranges are way off of the OEM dipstick.
Let us know how this turns out. That stock one breaking off like that is certainly concerning.
You make a compelling point. I sent the wrong ECS dipstick back today.
      07-23-2018, 07:24 PM   #26
mainsoda
mainsoda's Avatar
-James
Thanks James. I believe I am a good salesman for your product after the trauma of my stock dipstick's plastic tip breaking off!
I love your product, but so far I have sent a few emails last Friday and today asking about what your guys have found and have received no answers. I know they are probably busy, but I'd like to know the status if possible. I just changed my oil to get the plastic bit out and I'm not really sure how the level sits as I have only a broken stock measuring implement.
      07-23-2018, 07:25 PM   #27
mainsoda
mainsoda's Avatar
The part number difference may be just a finish option, it says they both fit the Z4M coupe on the ECS website if I'm not mistaken.
As for the possibility of the ECS stick breaking let me tell you, it's no plastic bit that's fore sure. It's heavy duty.
      07-24-2018, 09:39 AM   #28
ECSTuning
ECSTuning's Avatar
812
PM me your order number I'll step in an assist.
-James
mainsoda171.50
      07-27-2018, 10:31 PM   #29
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Got mine in today - NOT IMPRESSED!
I got the same result as mainsoda. Not only is the ECS stick quite shorter than OE, there are a couple of different oil level markers on it that have no correlation. The 2 marked lines are different than the carved out indicators? Obviously, the longer carved indicators are the correct ones, but why have the lines?
This is what I had ordered and it does indicate the correct fitment for the S54 => https://www.ecstuning.com/b-ecs-part...422ecs01-01~a/
StickMon636.00
mainsoda171.50
      07-29-2018, 12:36 AM   #30
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
That's not good. I'll certainly hold off on getting one of these until they get this issue resolved.
2006 Z4M Interlagos Blue/Beige
      07-29-2018, 02:13 AM   #31
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS
      07-29-2018, 10:55 AM   #32
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
After seeing the dipstick first hand, I'm not sure if I like the smooth bullet measuring head. I would much preferred if they put in some type of crosshatch grooves to retain some oil for proper readings - that's just my opinion.
Heck, I don't even need the bling - I would be perfectly happy if they (ECS) made a lower cost OE replacement with bends and crosshatch grooves at the end like the attached pictures. I hate to worry about that plastic OE piece falling off everytime I check the oil.
      07-30-2018, 09:35 AM   #33
ECSTuning
ECSTuning's Avatar
812
@XMetal are you already working with my CS staff? If not I'll get on that order asap.
-James
      07-30-2018, 11:45 AM   #34
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
-James
Yes - Already got an RMA and the package should be on its way back to you. Could you please look into why or how a dipstick that is advertised for our cars turned out to not fit the application at all? Thanks
ECSTuning812.00
      07-30-2018, 04:14 PM   #35
mainsoda
mainsoda's Avatar
I got my replacement dipstick today and the new one has the same issue.
      07-30-2018, 05:00 PM   #36
mainsoda
mainsoda's Avatar
As far as I can figure the ECS dipstick is somewhere between 35 to 37mm too short.
XMetal1131.00
      07-31-2018, 10:43 AM   #37
mainsoda
mainsoda's Avatar
I just got off a chat with ECS tuning support and I got some math wrong. I don't think the guy even cared and just seemed to want to get rid of me as fast as possible. After wrapping my brain around the measurement I've come to the conclusion that the BAD dipstick from base to tip is 589mm.
So a good one would have to be 35mm more or 624mm from base to tip.
I'm not sure ECS tuning has any good ones anymore, as we know of at least 3 bad ones just on this thread. They certainly don't seem to be able to tell a good one from a bad one or care to even check. It's a small dollar item I know, but I am disappointed in this product now and in ECS in general.
Does anyone know of any other non plastic tip aftermarket dip sticks?
StickMon636.00
XMetal1131.00
      07-31-2018, 11:09 AM   #38
Reborn_
Drives: 2007 BMW Z4MC
Customer service is customer service. Shouldn't matter if you spend $5 or $5k. Disappointing to hear how this is going.
XMetal1131.00
      07-31-2018, 12:22 PM   #39
ECSTuning
ECSTuning's Avatar
812
Sorry for the issues with these guys, I've alerted my head of R&D of the issue and he'll be reviewing production here shortly. If anyone needs assistance that hasn't PMd me yet, please do, I'll need your order number to pull it up in our system.
-James
      08-03-2018, 01:36 PM   #40
mainsoda
mainsoda's Avatar
-James
Hey James,
Any word on this?
      08-13-2018, 01:59 PM   #41
ECSTuning
ECSTuning's Avatar
812
Originally Posted by mainsoda View Post
Hey James,
Any word on this?
Sorry for the delay. We had a production error, until we have it corrected (new stock) I've had these turned off on the site to avoid somehow shipping any bad stock. I've been dealing several guys (yall that have posted and a few others) that got hands on the bad batch. IF you haven't been taken care of please message me ASAP so I can set up a proper return and apology for you.
-James
      08-14-2018, 03:19 PM   #42
mainsoda
mainsoda's Avatar
-James
Thanks for the update.
      09-15-2018, 03:24 AM   #43
polar
polar's Avatar
Sweden
53
Drives: Z4MC07
The dipstick on my Z4M allways make a very good resistance when I’m about to pull it out.
I wonder if someone has a good advise about the best way to put the dipstick in and out so the tip dont brake off? Is there like an specific angle, twist motion or any other tricks?
      09-15-2018, 01:30 PM   #44
StickMon
StickMon's Avatar
Drives: 2006 MR
Mine turns about 1/2 turn on the way in and out.
I don't argue with it. I let it turn whichever way it comes out/goes in easiest.
