      09-13-2013, 07:05 AM   #45
Shipkiller
Shipkiller's Avatar
Drives: Me
      09-13-2013, 11:26 AM   #46
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
For those that want to change the Rod Bearing as maintenance, maybe we should compile a list of shops based on location that are recommended for replacing the rod bearings?
Originally Posted by Beedub View Post
Food for thought???
September 10, 2013
When we first began looking at the S54...If a rebuild is in your future on an S54 I encourage you to investigate the costs of a standard rebuild and compare those costs to our rod bearing modification kit.
Beedub, Who/which company is this from?
      09-13-2013, 11:32 AM   #47
Beedub
Lang racing
      09-13-2013, 01:24 PM   #48
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Yep, here's their blog post http://www.langracing.com/finding-a-...aring-failure/
      09-13-2013, 04:37 PM   #49
seank
enthusiast
seank's Avatar
48
That's Andrew Lang, the s14.net racer.
The s14 and s54 aren't that far apart.
      09-13-2013, 04:41 PM   #50
beta
Drives: 2006 M Roadster
A quick search didn't bring up the price for their rod bearing modification kit, anyone know?
      09-14-2013, 12:01 AM   #51
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by ga41 View Post
Awesome find...I can't believed these guys are in my backyard and I didn't even know about them
I might go in to check them out one day.
Here's their blog post for addressing the problem => http://www.langracing.com/addressing...ification-kit/
      09-14-2013, 08:11 AM   #52
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Wow... Fantastic info here.
Nice work guys!
      09-14-2013, 08:41 AM   #53
GriffBrew
Seems like a reasonable extra expense if replacing bearings anyway. Assuming this is really a permanent fix.
I assume the new parts aren't going to provide additional power. But, I wonder if the lighter rods will translate to a faster spinup of the engine. Perhaps this wouldn't be noticeable due to the drivetrain and other variables?
      09-14-2013, 10:24 AM   #54
seank
enthusiast
seank's Avatar
48
Not actually true.
If you can get it sufficiently oiled, you can run thinner oil which will make more power. Minimal though. I run 10-30 on my s14 where most are running 10-40/50. I have done these same mods
      09-14-2013, 05:51 PM   #55
beta
Really great info, posted september 14th so it's hot off the presses!
      09-14-2013, 08:50 PM   #56
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by seank View Post
Not actually true.
I'd love to figure out if boosting pressure is possible on the S54 as you mentioned before on the S14.
      09-14-2013, 09:53 PM   #57
seank
enthusiast
seank's Avatar
48
They do: http://store.vacmotorsports.com/vac-...ump-p1033.aspx
And it's cheaper than the nla euro oil pump for the s14.
And one of these while you are in there: http://store.vacmotorsports.com/vac-...kit-p1847.aspx
All the issues with the s54 are exactly the same that people have with the s14. All the engine upgrades that I have seen or heard are nearly the same.
      09-14-2013, 10:57 PM   #58
StickMon
StickMon's Avatar
Drives: 2006 MR
I think that's already included.
Does anyone have a flow diagram of the lubrication system?
I'm wondering where the CPV sits.
I remember when mine started leaking I found something on the web that said something like "The Constant Pressure Valve reduces the oil pressure to the ...", and I'm kinda fuzzy on the rest.
Might have been the rear main.
      09-15-2013, 07:01 AM   #59
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
@Seank
I was thinking more along the lines of modifying the pressure valve to allow higher pressure.
I think you mentioned something about shimming the spring on the S14.
      09-15-2013, 07:51 PM   #60
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
mine see's 81psi at redline.
around 50psi ish just cruising
20psi at HOT idle.....
This reading is taken from the spare port on the oil filter housing ( where bmw check oil pressure) using the stack pro stepper range.
Confirmed, I get the same numbers on my gauge.
      09-16-2013, 08:16 AM   #61
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
S65 rod bearing material changed by BMW
For anyone following the E9xM3 tech area; it seems BMW changed the actual bearing material for later rod bearings. It seems the Babbitt layer has been removed. Maybe someone knows from looking at these photos taken by another board member. The only reason I can see is environmental as the new top layer looks like tin?
http://www.m3post.com/forums/showpos...4&postcount=19
      09-17-2013, 07:06 PM   #62
seank
enthusiast
seank's Avatar
48
@Seank
Yes, they can be modified. That is what VAC started doing when the s14 euro pump became NLA. I don't know how to do it and I can't find the write up on s14.net about it. There search bar is worthless. That being said, for $500-$600 i would buy VAC's. They say that it will increase flow by 22% and it should also increase pressure.
These would also be good questions for Andrew Lang. If I need to replace my bearings and/or pump, this is the route that I am going.
      09-18-2013, 06:57 AM   #63
JonM
Drives: E90 M3 Sedan
Another data point for S65 engines with regards to oil pressure... the Stack gauge in my M3 reads about 83 psi at steady highway RPMs. It can peak higher than that and even at idle it runs around 45 pounds. Altogether much higher than my S54 engines.
When I installed the gauge, I thought I had done something wrong I was so surprised. I tried other gauges and other senders, all the same result.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      09-18-2013, 08:39 AM   #64
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
For anyone interested in NJ area, Rogue Engineering quoted me as below:
The kit is $400 from Randy Forbes, when available.
The job is approximately 8 hours...at our standard labor rate of $115/hr.
I will be writing this reply in a few other threads about Rod bearings as Rogue is a pretty reputable shop which specializes in E46 M3.
The Raspinator
      09-18-2013, 08:57 AM   #65
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
That is interesting. I've not seen numbers on the pressure. So the pressure for the S65 should be enough for proper lubrication, and the S54 may indeed need a bit higher for the rod bearings to last. I was considering moving to a lower weight oil with the S54 before I had to sell her, but with the S65, I'm not so sure.
      09-18-2013, 01:59 PM   #66
pal
pal's Avatar
433
Drives: Z4 M Coupe
I am very wary of aftermarket 'improved' moving parts like oil pumps and unless I can find a few 'real' users who DD their cars and track regularly, I tend to not be the guinea pig. I would rather try and find an OE oil pump that will work on the S54 and raise oil pressure if that is helpful than have a rebuilt and 'improved' pump.
But this is a great discussion to narrow down the problem.
My strategy is to replace rod bearings again and possibly rebuild the bottom end with Pauter or Carillo rods and new OEM pistons and rings on OE crank and bearings.
