01-03-2022, 04:47 PM | #1 |
Rep 267
Drives: 2006 Z4 M Roadster
Picked up a Z4 M roadster at the beginning of Dec. Prior owner had done a good bit of work to get it running and driving like new. PO said that he changed all the fluids, but I have a hard time believing the trans fluid was changed. See pic of the oil I removed today. Replaced the oil with Red Line MTL. Haven't been able to drive it yet, but just rowing the gears while in the garage, I can tell it's shifting much smoother.
MTL is 75W80, but seems thin like ATF. We'll see how it does. May switch to MOTUL 75W90 as I'd like a little thicker oil in the gearbox.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
01-04-2022, 03:30 AM | #2 |
Down Under!!
1621
Rep 4,294
Trans fluid from BMW is lifetime, so he's probably not lying to you saying he's changed all the fluids as he probably didn't know that the tranny fluid can be changed, or he's bought the drivel that BMW tells you. Can't blame him really. Good on you for swapping it out though
Hawkeye2069.50 |
01-04-2022, 05:11 AM | #3 |
Rep 1,795
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
I'm a Red Line lubricant fan, using their recommended transmission oils in my Chevy, Ford, and Triumph vehicles. The Triumphs use the MT90. Two things I'd like to point out....MT90 is actually a 75W90 weight GL4 oil...secondly, Red Line recommends their D4 ATF oil for both the 2004 Z4 5spd and 6spd mt's (D6 ATF for 2006-2008 Z4's). So with the MT90 you are going thicker (think it'll be fine unless used in cold climates).
Hawkeye2069.50 |
01-04-2022, 07:05 AM | #4 |
Rep 267
Thanks for the feedback fellas. I'm in VA, so our climate is not usually too cold. So I'll see how the 75W80 does for a bit and then decide whether to try a heavier weight.
Also, I'm planning to make transmission fluid changes a regular maintenance item,I.e., every 30K or 60K, like the rear diff.
01-04-2022, 07:07 AM | #5 |
Rep 208
Drives: 08 Z4 M Coupe
Anytime I buy a car, I always change engine, gearbox and diff oil, brake and clutch fluid so I know exactly what's in there and what my intervals are.
For you new to you Z4M, Royal Purple Syncromesh is popular transmission fluid. That's what I'm currently running in my car and it improved the shifting in my car. Now I just have to take the first shift into 2nd carefully and it shifts wonderfully after that. I would also check the condition of the motor mounts and transmissions mounts. Rogue Engineering transmission mounts are another common upgrade and they do much better than the OEM mounts.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
01-04-2022, 11:21 AM | #6 | |
Rep 375
The servicing schedule says diff & gearbox oils every Inspection 2. Last edited by mmm-five; 01-04-2022 at 11:27 AM.. Reason: Resize attachment |
pungo880.00 |
01-04-2022, 12:12 PM | #7 |
Rep 2,547
01-04-2022, 12:15 PM | #8 |
Rep 375
...and in my case, 1200 miles after I had a new diff under warranty at 80,000 miles and 150,000 miles (insurance paid due to an accident).
...and since the first diff, I was getting mine done as an extra on every Inspection 1. |
01-04-2022, 01:12 PM | #9 |
Rep 1,343
At this age, I'd replace all fluid, belts and inspect all other wear items. It's just a safe bet and resets the maintenance to 0 under your watch.
Other areas to look into are the bushings, ball joints, boots etc. Might as well check the top motor to see if there were any water accumulation. I use a cocktail of MTL & MT90. Works great all these years. Not too thin not too thick... just smooth for my shifting pleasure. |
tomjonesBT33177.00 |
01-04-2022, 06:34 PM | #10 |
Rep 267
I'll be changing the rear diff fluid this weekend. I'm planning to use Castrol Syntrax. I'll probably run the Red Line in the transmission for 500 miles and then change again. After that it should be good for 30K I hope.
When I get a chance to go to my Father in law's, I'll put the car on his lift and get a real good look at the bushings, boots, etc.
01-05-2022, 06:16 AM | #11 | |
Rep 2,051
I'll be doing my research to see if D6 is a safe application for the Z4M gearbox. |
01-05-2022, 07:44 AM | #12 | |
Rep 1,795
Drives: E86 3.0si
01-05-2022, 09:55 AM | #13 |
Rep 267
I too saw the Red Line recommends D4 for the Z4M. FCP Euro lists D4 as compatible. MTL does not show up if you search for 'transmission fluid' while filtering for a Z4M. But if you dig up the item on their site, it says it compatible. ECS Tuning also says it's compatible. But I didn't like the inconsistency of the FCP Euro site, so I asked a local speed shop that specializes in BMW race cars. They said MTL or D4 is fine. MTL is a little thicker than D4. One of the guys there will Z4M uses a mix of D4/MTL. Apparently D6 is even thinner than D4. So better for cold climates but doesn't offer as much wear protection.
01-06-2022, 09:04 AM | #14 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Non-Ms and some newer M vehicles have "lifetime fluids", but yes BMW recommended trans/diff flushes on our Z4Ms.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
01-07-2022, 09:10 AM | #15 | |
Down Under!!
1621
Rep 4,294
Makes it a good point to have a rough idea yourself. |
01-07-2022, 03:46 PM | #16 |
Rep 375
01-07-2022, 06:08 PM | #17 |
Rep 267
My '04 Z4 2.5i is an auto and the owner's manual says the transmission fluid is lifetime. But I changed it anyway. BMW must define lifetime as 100K miles figuring that folks will sell and move on by then.
01-10-2022, 08:38 AM | #18 | |
Rep 1,107
