07-09-2019, 07:09 AM | #573 |
Rep 14,521
11 days after CarbonX and the lawn is thickening good. Fungus is looks to be gone as well!
Marigold's really coming alive
King Rudi13154.00 |
07-09-2019, 07:11 AM | #574 |
Rep 14,521
if anyone's familiar with Spruce's I wonder what these are? I don't think they're pine cones since this isn't a pine tree?
see the lawn domination from the next door neighbor!
King Rudi13154.00 |
07-09-2019, 07:19 AM | #575 | |
Rep 1,543
The tank itself has a frame underneath it. Part of it sticks out and has 2 long, lateral bolts. The top bolt rests in the hooks of the rectangular bracket that mounts to the LT. 2 pairs of machine nuts get tightened up once the sprayer is mounted. These are supposed to hold the tank at the desired tilt/pitch (which is somewhat adjustable). The bottom bolt has a 'foot' on it that sits on the LT's flange for adding tow attachments. The tank can pivot so you can pitch/tilt it up/down but the problem I had (which I read about online beforehand) is that the tank wanted to pitch downward some once it was filled. The weight is too much for the 2 pairs of lug nuts to clamp in place. I picked up some extra machine bolts, washers, and nuts from HD last night to see if I can use them as spacers. This thing honestly made spraying the whole yard much easier (tank cleaning is still annoying). Even though it was my first run across the yard and it looks like I missed some lines, I'm seeing a lot of 'wilt-y' weeds and some are starting to crisp/brown on the edges. Drive speed is what dictates the application rate since the DC motor on the tank runs a a constant speed. Now I wish I had a speedometer. lol I was going to rig a cellphone mount to use an old phone as a compass so I can try to keep better lines of bearing when doing diagonal mows (from one end to the other is like peering over the earth's horizon....not gonna happen). I can use the same GPS app for relative speed. I had more left over herbicide brew than i anticipated so I just made some cross passes over the more weedy areas. Since I won't be using non-selective herbicides, I won't be caring 100% if a little residue is trapped somewhere. The time this thing will save.....oh my! 2 other things: 1. There is a self-agitate mode where the pump will recirculate the contents. That's useful to help mix the large amount of liquid in the tank. I just won't run it while spraying since it decreases spray pressure. 2. The pressure for the spray wand is awesome!
- Jeff
bosstones' flickr |
07-09-2019, 07:23 AM | #576 | |
Rep 14,521
07-09-2019, 09:06 AM | #577 |
Rep 11,722
Abundant of blessing: numerous amount of yellow plum caused this branch to snap.
lsturbointeg9158.50 |
07-09-2019, 09:39 AM | #578 |
Rep 14,521
it could possibly be the tree is not being pruned correctly. I've watched a lot of University Extension YouTube videos about how to properly prune trees which in turn will help support trees to grow correctly and also to help load disbursement like fruit trees.
07-09-2019, 10:11 AM | #579 | |
Rep 11,722
07-10-2019, 11:29 AM | #580 |
18032
Rep 9,378
I'm not able to do it right, but I think the key on fruit tree pruning relates to AFTER buds set, so that you don't end up with broken trees.
Me/chickens are getting pretty regular with all the plums falling right now. I don't bother trying to pick from the tree itself, those that fall during the day are perfect for eating! And with the shade the tree provides, the grass under it a bit thicker/greener than the rest, so they have a nice cushion when they land. |
07-10-2019, 06:19 PM | #581 |
Rep 14,521
So here's the lawn as is. Gonna put down this chelated iron to see how dark green I can get it. Will report back in a few days if it works
07-10-2019, 09:28 PM | #582 | |
Rep 1,543
Went to HD and got the shortest 1/2" bolts they had. Unless the washer I put on the rod bends, it should work as a good spacer to maintain pitch/tilt of the sprayer when fully burdened.
- Jeff
bosstones' flickr |
07-11-2019, 06:27 AM | #583 |
Rep 14,521
Nice pictures! I do.lift so I'm not being a pu***.lol! I see how it mounts now. My yard is square and i can still maneuver around the trees. Im.kust trying to find ways to make the job easier and not harder. Not that a backpack sprayer is harder it's just easier to.drive around the yard than walking. I do have the room in the garage but don't wanna follow it up with a lot of lawn equipment
bosstones1154.00 |
07-12-2019, 07:09 AM | #584 |
Rep 1,543
lol...just messing w/ you. I paid a little more for the mounted sprayer. Tow-behinds of similar if not slightly larger capacity would be a cheaper route. Either way, it is definitely an easier way to go.
I just ordered: 1gal Q4+ - for those times when I need some liquid crabgrass control + other broadleaf weeds 1gal T-Zone - for broadleaf weeds excl crabgrass. It's cheaper than Q4+, too, so this will probably become my go-to for general purpose weed control 1gal Spreader Nonionic surfectant - wasn't badly priced and I forgetting to try dishsoap 2.5 gal Propiconazole - fungicide. I'm see lawn rust starting to come up in a few spots and I don't want to go thru what I did the last 2 late summer/falls in the backyard. I'll probably put down the propiconazole and some Dimension this weekend. I'll use the later as a pre-M for broadleafs and post-M crabgrass control (which I thankfully don't have much of anymore). Tank will get its use again this weekend! Lawn is starting to want to go dormant w/ all the heat we've been having and no rain. 1hour of impact sprinkler watering only yielded about 1/8" in my tuna cans! Wtf?! Ordered a water pressure gauge and looking into some larger throw sprinklers. Curious about BigSprinkler (mentioned by Pete/GCI) but need to measure the throw of my current impact sprinklers to see if the $ would be worth it. My yard is too big. lol
- Jeff
bosstones' flickr |
07-12-2019, 11:56 AM | #585 | |
Rep 14,521
07-12-2019, 06:51 PM | #586 |
Rep 1,543
I just started w/ RGS & Humic this year. 2 apps of RGS and 1 of Humic-12 (although one of the RGS apps was via Carbon-X in the back yard). I'll see how it goes. My biggest issue is irrigation. I'd really like to get an irrigation/in-ground sprinkler system. I need to finish planning out the landscaping, deck, etc... first so I don't have to redo the irrigation stuffs later, though. For now, I'm just looking for the longest throw sprinklers I can get to run off a standard, city water fed hose bib. It is a PITA to try to water my yard.
- Jeff
bosstones' flickr |
07-12-2019, 07:06 PM | #587 |
Rep 4,821
Not sure if it is common where you are but we had a well drilled for irrigation here. No water bill for irrigation, just a little electric to run the pump. But they needed to go deep enough (100 ft. if I recall) to avoid a smell in the water.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
07-12-2019, 07:41 PM | #588 |
Rep 14,521
Just sprayed out the Iron and now letting the irrigation water it in. Will post some results in a couple of days
I inquired about it and my HOA won't allow it
07-14-2019, 07:46 PM | #589 |
Rep 1,543
So my little idea to rig my tank sprayer didn't work......not enough room for the bolt heads. I think I might have enough room for a flat head bolt w/ a cotter pin, though.
Put down some Propiconazole w/ Signal (blue dye) anyways. A bit frustrating since the spray wasn't as even due to the droop of the tank under its own weight. The Q4+ blanket spray from the other week is working nicely. I'll probably spot spray somethings that were missed (tank droop) since I have to spot spray the front anyways. I do want to put down dimension to help w/ anymore weed growth until fall, though.
- Jeff
bosstones' flickr |
07-14-2019, 10:26 PM | #590 | |
Rep 14,521
07-15-2019, 09:03 PM | #591 |
18032
Rep 9,378
you see what happens when the water stops falling from the sky
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
07-15-2019, 09:52 PM | #592 |
Rep 640
Drives: 2008 M3 (E93)
I feel like I run my sprinkler system non stop and my lawn is still looking a little dead. I do the scotts 4 step and re-seeded etc. Oh well lol
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
07-16-2019, 04:54 PM | #593 |
Rep 14,521
07-16-2019, 04:55 PM | #594 |
Rep 14,521
pictures?
