Thread Tools |
| 10-02-2025, 01:52 AM | #1 |
Rep 17
Z4m need help with wheels.
Hello all!
I have read the whole pages on the wheel thread, but dilemma is a little different. I have been looking at this particular wheel specifically. Desmond Regamaster Evo ii however, my options are limited with sizing and offsets. Details: Aragosta coils type ss Front brake, CTSV 6 pot conversion 380mm (pending) Rear brake , stock. Looking for options Wheel size. Options. F 19x9 +45 F 19x9.5 +38 F 19x9.5 +22 R 19x10 +35 R 19 x10.5 +15 I am not sure if the cts v 6 pot will clear 18" But if in case, here are options for 18" F 18x9.5 +45 F 18x8.5 +45 R 18x10 +25 R 18x10.5 +15 R 18x10.5 +20 Thank you. |
| 11-04-2025, 10:10 AM | #2 | |
Rep 714
https://apexwheels.com/fitment-guide...ressive-street Then go here https://www.1010tires.com/Tools/Wheel-Offset-Calculator Use the offset calculator to find out how far in either direction you go compared to the apex guide and where you’re currently at. Unless there’s another member here running the offsets you have in question this will be the next best thing to find your answer. Use the configuration you currently have as well to plug in to the calculator and use an old fashion ruler to see how you’d sit in comparison to where you are now as a quick way if you’ll have fender/suspension clearance for what the new wheel will be. |
| Bookmarks |
| Thread Tools | |
