Valve cover replacement
My Valvetronic sensor and actuator seals are leaking quite bad, and there is a "seep" type of leak from the valve cover gasket, but its hard to tell with how much the other seals are leaking. I feel like I should just replace the valve cover along with the other 2 seals, but the valve cover I have now seems like its plastic. I see two different valve covers that are aluminum, which seems like a better option than the stock plastic. Which one is the better of the 2? API from PartsGeek, or Bremmen from Tuner Motorsport? The latter is about $100 usd cheaper
