      03-12-2025, 07:59 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Master cylinder movement when stepping on the brakes
Not sure if anyone ever noticed, cared, or measured, but I tested how much deflection exists in the brake master cylinder when pressing the brakes hard.
I measured .020".
In the Toyota Supra world, they make "Brake stoppers" that lock up against the shock tower.
Perhaps I will be doing something like that for the future. Thoughts?
      03-12-2025, 08:03 PM   #2
gaseosx
Drives: E85 Z4 3.0i
Seems like a good idea. I’ve seen some for Tesla M3’s.
      03-17-2025, 06:17 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1779
Drives: 2007 Z4MC
no ABS on yours? do you miss it? eng out for a reason? or general maint while your replacing the box?
Powered by
      03-17-2025, 09:15 AM   #4
dre99gsx
Image is from a Supra I'm building, where I'm actually installing an MK60 ABS. But, I measured firewall deflection on both cars (The Z4 and Supra).
      03-20-2025, 12:17 AM   #5
Vanne
Vanne's Avatar
1779
Drives: 2007 Z4MC
Ahh okay.. any other specs on the supra? I haven't measured the deflection on mine, as I may still swap out the Willowood master yet for a chase bays master (which I have already in stock) as the pressure required to fully lock the brakes is a lot. Possibly it's the abs unit not playing ball in between, so I'll need to look at that and or possibly remove the abs.. (which I hoped to retain)
      03-20-2025, 08:28 AM   #6
dre99gsx
I just completed installing MK60 ABS on the Supra. It's a work in progress, feel free to join my instagram if you want to follow! (@andreleads)
Found a rusted out RHD shell, converted to LHD, building another track weapon.
