06-26-2018, 07:06 PM | #199 |
Rep 1,923
I think op is not active anymore?
07-10-2018, 08:15 AM | #200 |
Rep 431
Track: NJMP Lightning
Car: Z4M Coupe - Stock S54 Conditions: Sunny & Hot ~85*F Tires: Extreme VR2 R7 265/35/18 140TW Best Lap: 1:15.503 Found almost a full second by carrying more speed through turns 6 and 7 but was scrubbing a bit too much speed in T1 negating much of the gains... so settled with a .25 improvement. Until next time to hit that elusive 1:14:XXX! https://drive.google.com/file/d/108e...ew?usp=sharing
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
07-10-2018, 09:13 PM | #201 |
Rep 12,565
I’m still here but I just wait to do a bunch of updates at once as opposed to every time someone posts. Lap times were last updated on May 30th and since then were only a handful of new times. Will get around to it next week when I’m off from work
Azeka1285.50 |
07-11-2018, 06:07 PM | #202 |
703
Rep 7,850
You can put Zach Boozé down for 2.06.00 on Thunderhill East. RE71R tires. Dry, 106 degrees. I saw the time on Harry's in his hand
You can put me down for 2.09.02 for Thunderhill East, 106 degrees, and 1.49.38 at Laguna 78 degrees. Both on tracks were on RE71Rs. Both are Z4M coupes stock motor. Zack is running TCKs and I'm running stock dampers. Thanks for keeping this updated! |
07-16-2018, 09:10 PM | #203 |
Rep 911
Track: Pocono North CW - Night time
Car: Z4 Coupe - 2JZ Conditions: Sunny/Humid & Hot ~92*F Tires: R888R 295/265 Best Lap: 1:01.991 First outing with an LSD, re-learning how to drive. Otherwise, nothing too impressive to see here
Andre - 2J into a Z4 Coupe!
07-19-2018, 02:34 PM | #204 |
Rep 12,565
All lap times updated through post 203
07-24-2018, 10:10 PM | #205 |
Rep 431
Track: Watkins Glen International
Car: Z4M Coupe - Stock S54 Conditions: Cloudy - 70's Tires: R888R 265 Square Best Lap: 2:16 First time out at the Glen and it was an amazing experience. Given half the event was in the rain, I was only able to really focus on improving the first sector. With a theoretical best of 2:05, I'm leaving tons of time on the table. Will try for < 2:13 in Sept. https://drive.google.com/open?id=1mG...al3uXlBnJrkAjb
07-26-2018, 08:34 AM | #206 |
Rep 104
Who here wants to submit a time for Canadian Tire Motorsport Park GP? Anecdotally, one guy at BMW Trillium last year (and may or may not be a member here) was running low 1:37 or maybe even high 1:36 on nothing more than stock size RE71-Rs and camber washers.
07-28-2018, 09:28 AM | #207 |
Rep 911
Car: Z4 Coupe - 2JZ Conditions: Hot, Muggy 85degF Tires: R888R 295/265 Best Lap: 1:15.910 Improved from my last 1:19.0 by simply carrying more speed into the corners. My tires aren't showing much of any wear - I need more seat time and confidence. My best time was actually done with very little boost, tried going for momentum than shear torque. Also ran into traffic most of the laps, but that isn't the point of these HPDE events Had two crazy lightning and downpour events, closing the track twice. Track got flooded, with 40mph winds. It's crazy out here.
Azeka1285.50 |
07-28-2018, 09:51 AM | #208 | |
Rep 431
07-28-2018, 01:18 PM | #209 | |
Rep 12,565
How’d the brakes perform? What’s your current setup? |
07-28-2018, 04:31 PM | #210 |
Rep 911
Thanks everyone. Lots of learning to do!
I did measure brake temps after a cool down lap: Fr rotor/caliper: 560/360F Rr rotor/caliper: 370/255F Both these tracks never gave me brake issues for some reason. Had SRF in it, but since I wasn't coming in hot into any corner, was barely using them (unlike Pocono). Still on this setup: -335i front floating calipers/Z4M front rotors/2.5" cooling ducts to front/Brass caliper guide pins-no rubber boot -135i rear fixed caliper/Z4M rear rotors (custom brake shoes to make it all work on the 3.0si) -PFC08 pads all around We had ~40mph winds on a torrential downpour around 11am, fooded the entire pit-road access area with 18" of water. It drained after 30minutes. A few trailers rammed into vehicles from the wind. I was in my truck and started to really fear for what would happen. Wind plus flat wide trailer = easy sail! I had chocked my trailer right before the storm. Storm came back around 3pm (10mile radius of lightning forces track to shut down) and another evil wind driven downpour ensued. This is why they call these tracks "Thunderbolt and Lightning" ? lol By not running boost on the straights, I had more time to think and plan the next corner, entry speed, and focus. That helped tremendously as I wasn't trying to brake for my life at every instant. I actually let the entire pack pass me the first 2 laps so I can focus, and I have video showing me passing everyone by the next few laps. Not to say my driving ability is supreme, but that I think I was carrying a good pace being a bit more relaxed. Wish I had more sessions to continue working on this - got cut short by the weather.
07-28-2018, 04:35 PM | #211 |
Rep 911
Some photos of the storm/flood
07-31-2018, 07:52 PM | #212 |
Rep 128
Thought I would post up some times. The car is stock configuration Z4M (engine, seats, diff) with only a TCKline DA suspension. Running 265/35/18 RE71r tires on 4 x stock rear wheels.
Tracks are Summit Main, Dominion Raceway, VIR Full, and Pitt Race. |
08-03-2018, 01:12 PM | #214 |
Rep 431
Love your roll bar, thanks for sharing it!
08-20-2018, 10:37 AM | #215 | |
Rep 431
Same Track, Same Conditions and Car Setup exactly the same way but running 265/35/18 square R888R Tires with 3 Days / 12 HC in them. Consistently running mid 1:17's to low 1:18's then tapered up to 1:18-1:19 as they cycled out over the weekend. Easily ~3 seconds slower than the Extreme VR2 that I was running earlier this summer.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo Last edited by Azeka1; 08-27-2018 at 10:43 AM.. |
08-20-2018, 10:57 AM | #216 |
Rep 911
What led him to believe the shocks were "toast" ? And is the slower time due to shocks, tires wearing out, or combination? Are you suggesting that R888R are inferior to those VR2s?
08-20-2018, 12:13 PM | #217 | |
Rep 431
At first I was driving the car the same way as with the VR2 and the tires just could not handle it and do what I was asking. After playing with tire pressures and wing AOA, I needed to step back, reset all the changes and adjust my driving style to account for it. I'll also look at cornering G differences later when I download all the data.
AriuSen776.50 |
08-27-2018, 08:58 AM | #218 |
Rep 911
Track: Pocono FUSA (double infield with hairpin)
Car: Z4 Coupe - 2JZ Conditions: 80degF, beautiful day Tires: R888R 295/265 37psi hot Best Lap: 1:53.022 Practiced not-overbraking for each turn, slight improvement from last time here. In three spots on the track, I am around 3krpm and way out of my powerband. Too lazy to shift into 2nd gear (what is this, an autocross track?!). I'm losing some time there. Hit 160mph on the long straight - that was fun. I have the brakes and power, but I seem to lack momentum during turns. At least, compared to others who have basically stock vehicles, "lesser tires". Had an instructor drive with me, didn't see much of anything wrong with my lines. I was driving the tires hard for sure. Perhaps going from -3 to -3.5 front camber can help... Tires have 6 track days (about 20 sessions), still tons of meat on them. Don't think they are falling off yet?
08-27-2018, 11:40 AM | #219 | |
Rep 12,565
08-28-2018, 08:14 AM | #220 |
Rep 911
Some video footage of one of my sessions - look how quick that McClaren is!
