06-07-2012, 12:51 PM | #1 |
1797
Rep 7,662
iND | Macht Schnell MS97 Spec Shifter Knob
Finally, a more aggressive knob made for the BMW shift lever. The Macht Schnell MS97 knob stands at 97mm in height allowing for a more efficient shift motion all the while bringing the knob closer to the 3 o'clock hand position. As a result the driver can focus less on shifting the vehicle and more on steering input. The knob is machined using 6/6 nylon which means less heat transfer from the aluminum shift lever and reduced NVH.
The knob is a pressure fit and does not require any screws. For clients with the 1 piece OEM knob and boot modification/trimming is necessary. Macht Schnell MS97 Spec Shifter Knob - $89.00 MSRP IN STOCK AND READY TO SHIP!
06-07-2012, 02:43 PM | #2 |
Rep 5,329
ya no... i think this would be PERFECT but i think they missed a trick by not engraving the shift pattern on the top..... Theirs more than enough space... also does nylon mark easily, so if im wearing a ring is this thing going to look like shit in a few months??
product looks nice, any weight info???
06-07-2012, 02:56 PM | #3 | |
1797
Rep 7,662
Weight was roughly .2lbs (90grams) on our UPS scale.
