12-11-2021, 05:21 PM | #2619 | ||
Rep 1,687
12-11-2021, 05:54 PM | #2620 | |||
Rep 4,057
Huz-Z
12-13-2021, 04:39 PM | #2623 |
Rep 12,565
Have you tried online quotes (Vroom, Shift, Carvana, etc.?)
12-13-2021, 04:42 PM | #2624 |
Rep 132
12-13-2021, 05:16 PM | #2625 |
Rep 12,565
Mind I ask what that was? You can PM me…
12-14-2021, 08:56 PM | #2626 |
Rep 972
Well, it has been busy shopping Christmas this 2021
Here is what I have gotten - E46 M3 CSL front ARB - the necessary hardware for the ARB - Racing diffs rebuild kit (advanced set) - Severn tuning Alpha-N custom tune Next year I may do rod bearings and change spring rates (again) |
pokeybritches479.00 |
12-17-2021, 07:43 PM | #2627 |
Rep 1,687
So, the Skyer Time Attack Spoiler arrived today. When I purchased one from the initial ten last month the lead time said 8-10 weeks. It was just barely under a month.
That is impressive considering all of the manufacturing and shipping problems. I don't know when I will get it installed but hopefully soon. And the carbon fiber looks good. |
12-22-2021, 07:43 AM | #2628 |
Rep 12,565
Had folks message me about tips, need to adjust muffler upwards but you get idea on how tips look
racerbruce3851.50 Steeler2427.50 |
12-22-2021, 01:49 PM | #2629 | |
Rep 972
I am debating about reverting exhaust back to stock and the tips is my main issue, well that and that I would need an x-pipe My best setup to date has been euro headers, dfk section 1 with 300 cel cats, ss x-pipe and OE mufflers. It was deep tone and no rasp and let the CSL intake be heard in full… I have had several combos and all are just to loud and we all know the exhaust sound of the S54 is not very nice. |
12-22-2021, 02:13 PM | #2630 | |
Rep 12,565
Re tips, I asked a fellow from Z4-forum (handle "machine monkey") who produced a bunch of custom SS tips for Z4 owners across the pond. They can be slipped over stock or riveted/welded by removing the stock tips. I chose the latter. The workmanship is good but not sure if Z4 mufflers have different specs in UK as the tips were a tad big (i.e. very little to no spacing between each tip, see 2nd pic above but they're practically touching). I don't mind it, but something worth calling out. Lastly, I had to grind out few thousandth of an inch on the inner diameter. It's a super tight fit and perhaps intentional but it required me to use a mallet and wood to force them on. That said I'm still very happy with them. I will post more pics after I get the muffler re-aligned. PS - I didn’t even know DKF offered 300 cell, thought it was 100 or 200 only. Last edited by 3002 tii; 12-22-2021 at 02:22 PM.. |
12-22-2021, 02:31 PM | #2631 | |
Rep 972
The next test for me is put the US section 1 with secondary cats as those cans are much larger and could tame sound a bit. And maybe they will smell less being an OE part, though I think they are 200cpi too, or maybe 400, who knows. Pls post photos one you have them 👍 |
12-22-2021, 03:10 PM | #2632 | |
Rep 12,565
Edit - actually realized what I have now are the 100 cell. I have both as well and ultimately settled on the 100s. With factory mufflers back on, I smell way less fumes. Here are pics by the way, custom tips on blacked out oe mufflers Last edited by 3002 tii; 12-29-2021 at 10:10 PM.. |
12-22-2021, 03:23 PM | #2633 | |
Rep 1,543
Some parts can get made pretty quickly but waiting for other parts to arrive. In this particular case, we got lucky and shipped out ahead of the plan. ..and yes, shipping nowadays are a PITA. many thanks for your kind word.
12-29-2021, 10:10 PM | #2634 |
Rep 12,565
Better shot of the new tips on the stock mufflers. Left side still needs to be adjusted ever so slightly.
12-31-2021, 09:28 AM | #2635 |
Rep 197
Drives: BMW Z4C 3.0si 3 pedal
Ground Control front Anti-Sway Bar, GC adj Rear Camber arms , APR frt Carbon Splitter, Modified custom Alcantara wrapped steering wheel, and Turner frt fixed camber plates
12-31-2021, 04:10 PM | #2636 |
Rep 684
My PVC on the 3.0si seemed to be on its way out but didn't feel like changing the valve cover gasket so soon after last time. You can chisel the cap on the valve cover off and seal this one on instead. Saved me about $500 and a heck of a lot of time. Works absolutely perfect, like a different car. To seal I used one min gasket in the squirt tube can (like a whipped cream tip) and JB Weld black epoxy. Would never know. I did take the intake manifold, throttle body, and other stuff off to clean. Was needed for sure. Also put a new starter on while I was in there.
01-27-2022, 01:34 PM | #2637 |
Retired
96
Rep 174
Winter project
Brakes for all four corners ordered from German Parts in Toronto. I found them to be less expensive than the same equipment from south of the border. All shipping costs to my door were only $22 CDN. Before I ordered I asked them f they had any discounts running at that time. They sent me a one time promo code for a 10% discount. All totalled up, $300 less than the closest supplier in the states, before adding the duties and brokerage fees. |
Steeler2427.50 |
01-31-2022, 12:22 AM | #2639 |
E86 M Coupe
265
Rep 402
Rota Slipstreams!
02-01-2022, 10:21 AM | #2640 |
Rep 25
grannyknot950.50 |
