      07-06-2024, 08:25 AM   #1
V vette
Drives: Z4
Remove connection clips-Pressure sensors
OK I give. Need to replace the brake pressure sensors and cant figure out how to remove the damn clips? Any help as Im pressing, pushing etc and no luck. Thanks
      10-16-2024, 01:27 PM   #2
Rixster
Drives: 2006 BMW Z4 3.0si Roadster
You need to pull on clip but at the same time you have to push your brake pedal in. So what I did I grabbed a weight from my cousin place it carefully ok the brake pedal. After the brake was pressed in. I pushed the brake light switch in all the way until it came out of the clip. After that you just need to pull the clip towards the seat I believe you might need a small flat head like the ones used for tightening glasses to help release the clip.
