11-23-2019, 11:32 AM | #1 |
Rep 51
Battery kill switch, which one and where in car ?
For long term storage of e86.
There are master switches that hook up on the battery itself. Probably the easiest route but a bit annoying removing the battery cover each time. Not a track car so can't just drill holes in the interior with a big red switch. I thought maybe somewhere in the engine bay, but would like to still be able to connect trickle charger to the battery +/- connections in the bay, while battery is disconnected from the rest of the car. Not sure that's possible. Anyone good ideas / product suggestions ? |
11-23-2019, 06:06 PM | #4 |
Rep 51
Thanks, yes will do trickle but thought it best to simply also cut car electronics if long not in use, but probably I'm fuzzing over nothing.
Will maybe put this on : https://www.grandado.com/products/au...SABEgLPRvD_BwE |
11-23-2019, 06:07 PM | #5 | |
Rep 51
11-23-2019, 08:30 PM | #6 | |
Rep 885
11-24-2019, 05:39 AM | #7 | |
Rep 51
But BMW Z4 Manual does say to disconnect the battery if storing >3 months, so hence I'd like a cut off switch, to avoid wrenching the clamps each time. |
11-24-2019, 06:16 AM | #8 |
Rep 885
When I had my Z4MC I just put it on the tender, my bad I guess but I never had any issues. Mind you I'd usually start it up once a month, bring it up to temp and move it up and down the driveway. I know there are lots of different views on how to put a car away for the winter months and many would say that was wrong but some say it's ok. That was just my thing.
wdb4718.00 |
11-24-2019, 08:08 AM | #9 |
Rep 18,719
Just want to be precise here. I think Salty is referring to a "battery maintainer" and not an actual trickle charger. There is a difference. Trickle chargers slowly and constantly charge an auto battery, and if left on the battery for a long period of time can eventually boil off all the acid. The term "trickle charger" is a bit out dated and is a device that is a slow-rate charger versus a fast-rate charger that many service shops use to rapidly recharge an auto battery.
A battery maintainer controls the voltage level of the battery and maintains the proper state of charge of the battery without over-charging it. That said, Salty's advice is spot on. OP, just get one of the several brands of battery maintainers, hook the leads up to the under-hood terminals either with the alligator clips most units come with, or the permanent pigtail leads that can be affixed to the under-hood terminals. Most brands come with both types of leads. IMO, I think most modern cars do better with attaching a battery maintainer to the vehicle rather than leave the control modules and other electronics without electric power of long periods of time.
11-24-2019, 08:29 AM | #10 | |
Rep 885
Efthreeoh17273.00 |
11-24-2019, 08:32 AM | #11 |
Rep 18,719
Yeah, me too. Old school because I'm.. well... I'm OLD (doctor confirmed ). I just wanted to be clear in case a fresh out reads the thread and gets the wrong device. Heck, I'm not even sure they are still made.
Salty Dog3572.50 |
11-24-2019, 10:44 AM | #12 |
dances with roads
4718
Rep 4,096
Many modern battery chargers do both recovery charging and maintenance charging. I use CTEK brand, MUS 4.3 specifically, and I'm very happy with them. I even recovered the battery in my E93 with one, which easily saved the cost of the charger.
Efthreeoh17273.00 |
11-24-2019, 04:29 PM | #13 | |
Rep 51
Just a bit confusing. Wouldn't it actually slow down degrading of electrical components if there is no power to them at all ? Or does that potentially mess with the delicate (im)balances in tiny transistors etc. Thanks for feedback to all by the way, appreciate it |
11-24-2019, 07:57 PM | #14 | |
Rep 18,719
But over the 30 or so years I've kept batteries on a maintainer (mostly brainless motorcycles and my diesel tractor), the batteries have lasted very long periods of time.
11-25-2019, 01:35 PM | #16 |
Rep 18,719
Condition-Based Service. The car uses sensors, and/or time-based algorithms to notify you of maintenance items due. The E86 Coupe really just has engine oil change notification and Inspection I & II notifications. Other BMWs, especially ones a decade newer have more sophisticated CBS systems; while at the same time dropping the maintenance technical data published in the manual set that comes with the car...
11-26-2019, 12:50 PM | #17 | |
Rep 51
