      05-22-2019, 09:13 AM   #1
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Rear suspension noise when starting from a stop?
Hi everyone! I am having a little suspension noise from the driver's side rear when I start moving from a stop. It is a slight groan/squeak as the weight transitions in the car. I can only hear it when starting from a stop, and not on the road. For the life of me, I cannot figure out what is causing it.
Currently have FA 500s, RE RSMs, AKG RTABS, and TC Kline 600lb rear springs.
I *think* it may be bushing related. Problem is, I have no idea which bushing....
I checked rear sway bar mounts and verified those are tight. Shock mounts are tight and I just replaced the rubber bushings with new per RE install specs (before swapping, I did tighten the old ones down too much which result in more noise, but the noise overall wasn't fixed with the new rubber). Rear shocks don't seem blown, and the noise existed before I installed the new TCK springs.
Anyone else have this issue and was able to rectify it?
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      05-22-2019, 09:11 PM   #2
Clearancediver
Drives: 2004 Z4
If you had said your emerg brake was engaged .... and you pushed down on the rear of the car... and heard the noise from the rear drivers side... I would have said emerg brake mechanism.
Wonder if you have emerg brake "tightened" up enough that the acceleration surge which "squats" the car is replicating this issue.
Sent from my smart phone...
      06-05-2019, 10:35 AM   #3
jns_e85
jns_e85's Avatar
74
Gave in and took it to my indy. Culprit was discovered to be a loose trailing arm bushing bolt. Was only slightly loose but felt like an idiot for not checking that, since the moron who last touched it was me installing RTABs. Guess who is going to triple check his bolts from now on...
