      11-18-2019, 10:10 PM   #1
sikedsyko
Drives: 2005 Z4
Seat mount differences E85 v E86
I'm trying to figure out if the coupes use different mounting points for the seats vs the roadster.
Several companies advertise bottom mount seat brackets that they claim are specifically for the coupe. I talked to a rep with Corbeau today and they specifically said they don't make a bracket that fits the roadster.
However, looking at BMW's part numbers, the seat brackets for the coupe and the roadster are the same part.... I'm guessing they've just only validated it in the coupe and don't want to commit to it fitting the roadster without testing.
https://www.realoem.com/bmw/enUS/par...&q=52107053947
Can anyone here verify that the aftermarket brackets labeled for the e86 will also fit the e85?
      11-19-2019, 12:54 PM   #2
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Don't worry, they are the same. In fact, they are shared with the E46 so any E46/E85/E86 will work.
- My VAC brackets stated Z4 on them and did not specify between coupe/roadster
- My Brey Krause brackets were actually for the E46 but fit my E86 perfectly
- E85/E86 M Seats are a common swap on the E46
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      11-19-2019, 02:14 PM   #3
sikedsyko
Drives: 2005 Z4
Thanks! That's what I figured, but just wanted to verify before I bought a bunch of shit.
      12-11-2019, 08:54 AM   #4
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Can also verify the Corbeau E46 bracket slider fits in the Z4m roadster. However, it was higher than my VAC mount with bracket and slider with the same seat installed. If you had to clear a broomstick and you were on the taller side, you may have some issues
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      02-12-2020, 10:32 PM   #5
sikedsyko
Drives: 2005 Z4
Thanks for all the input. I ended up buying a set of VAC brackets. Should be here soon.
