      04-03-2019, 12:57 PM   #1
nadaclue
Drives: Urban Green 2003 3.0
Supersprint advertising N54 E85/86 swap exhaust
I found this to be interesting, Supersprint is advertising an exhaust system for swapping an N54 into the E85/86 chassis, something I'd like to do and was looking into. Anyone have experience with the swap? I'm assuming it would require some sort of standalone ecu.
https://www.supersprint.com/ww-en/sp...onversion.aspx
      04-03-2019, 04:17 PM   #2
Huz-Z
Huz-Z's Avatar
Odd. Why swap in an N54 when the N55 is a newer design with more reliable high pressure fuel pumps? I didn’t know that this swap was “a thing”. How does one manage the interface with the car’s electronics?
300 hp sounds nice though!
      04-03-2019, 04:27 PM   #3
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
The work involved will likely cost as much as sourcing a 330 hp M car!
wdb4732.00
      04-03-2019, 08:56 PM   #4
mad1stgen
Master Wagon Builder
mad1stgen's Avatar
409
Drives: 2015 F wagon S55/6MT
Thing is N54 is never a 300hp car.
My wife wants me to do the swap to her 3.0si. Should be happening shortly. It's not exactly a thing, and was never done with a complete engine to the best of my knowledge. Not exactly a bolt in, but that's what hotrodding is about afterall. Exhaust is the least of one's worries though ...
N55 is not exactly more reliable either. It would be however easier as the single turbo downpipe would be easier to route around the pesky RH motor mount that sits in the way of twin N54 downtubes.
      04-04-2019, 07:53 AM   #5
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Sounds like an easier and better solution would just be to buy an E89 with the N54.
Newer, more luxurious and contented cruiser without the headache or worry about being a swap. If you're really set on the E85/E86, you're probably still better off to buy an ///M and supercharge it.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      04-04-2019, 11:29 AM   #6
Huz-Z
Huz-Z's Avatar
I think that the later E89 in SDrive 35is trim would be the one to buy.
Huz-Z
      04-04-2019, 12:13 PM   #7
rockstar93
rockstar93's Avatar
Although the auto-only might be a deal breaker. IIRC the earlier 35i model was available in both transmission options.
      04-04-2019, 12:37 PM   #8
Huz-Z
Huz-Z's Avatar
Agree - good point!
      04-06-2019, 10:16 PM   #9
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
If your going to do a swap, then go big or don't bother imho. Ls swap, 2jz, s85, viper motor etc are swaps worthy of recognition. Otherwise like previously stated, buy the next gen that already came with the motor from factory.
wdb4732.00
      04-07-2019, 06:04 AM   #10
wdb
dances with roads
wdb's Avatar
4732
If you're swapping to get attention at the cars n' coffee maybe. But if you are swapping to get more power without destroying the car's other fine qualities, not so much.
      04-07-2019, 09:57 AM   #11
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
https://www.autoblog.com/2006/12/05/...e-biturbo-z30/
      04-11-2019, 08:53 AM   #12
mad1stgen
mad1stgen's Avatar
409
Originally Posted by pokeybritches View Post
That's an N52 with N54 turbos bolts on and tuned using N52 DME, thus the poor HP/TQ results.
      04-14-2019, 12:52 PM   #13
pokeybritches
2006 BMW Z4M  [8.50]
The article says it's the 335i motor (N54). Where did you get the additional info from?
      04-16-2019, 07:24 AM   #14
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
They also stated it was a z3
