09-14-2021, 03:44 PM | #1 |
Rep 195
FS: 2007 Z4M Coupe
Interlagos Blue with wood dash and tan Extended Leather interior 89860 miles *sigh* Putting my baby up for sale. Time to move on. I bought the car in 2012 drove it daily for a few years, then relegated it to weekend cruising and HPDEs. Car was originally from Florida, then brought to Reno by PO who decided an M6 was more to his liking. It's been in Nor Cal ever since (SF Bay Area). Would prefer a local buyer for obvious reasons but willing to work with buyer to ship. Since you'll be wondering: rod bearings were done proactively at 81k, VANOS has not been touched. Just had a full paint correction and detail done, oil change, brake flush, new brake pads, new battery. Major service at two local race shops: BTM Motorwerks and Edge Motorworks. I've done most of the routine maintenance myself. (Oil changes, brakes, etc.) Cosmetically it's in very good shape, but not perfect. There are a few paint chips, the rear apron was damaged by misaligned hot exhaust tips (although it's hard to see), the windshield gasket has a tear (but no leaks), the headlight washers are disconnected (because the covers tend to blow off at high speed), and the windshield washer pump is disconnected (because it was leaking and I haven't got around to fixing it). Titanium Rob Knob in pictures is not included. Replaced with stock shift knob. The JRZ's are fantastic on track. For street I dial them down to full "soft" and the ride is better than stock. The current alignment is aggressive (3.5 front, 2.5 rear, 0.06° toe) but it tracks perfectly on the street. Questions? Please ask. JRZ RS Pro adjustable coilovers Ground Control adjustable camber plates Ground Control adjustable sway bar links (front) Ground Control weight jacks Ground Control adjustable rear control arms Vibra-Technics motor mounts (road) Rogue Engineering transmission mount Rogue Engineering rear shock mounts (track, 75A duro) Superflex polyurethane FCA bushings Eisenmann Sport mufflers Apex 75mm bullet nose wheel studs Replaced all engine mount bolts and washers VANOS high-pressure line replaced with Bimmerworld flexible line Rod bearings done proactively at 81k (by Edge Motorworks, Mountain View, CA) Rear subframe bushing (axle carrier) replaced Differential mount & bushings replaced Flex disc replaced Black grilles Clutch stop Ultimate pedal kit VMS stubby antenna All trunk trim currently removed (for shock installation and access) Headlight washer hoses disconnected, washer covers zip-tied shut Brake wear sensors disconnected Staggered wheel setup (currently mounted): Front: Apex ARC8 18x8.5 ET38 Hyperblack Rear: Apex ARC8 18x9.5 ET22 Hyperblack Bridgestone RE71R 235/40 & 265/35 (Tires are ~3 years old and tired) Square wheel setup: Apex ARC8 18x9.5 ET35 Hyperblack 5mm front spacers 12mm rear spacers Bridgestone RE71R 265/35 Fluids: Oil: Castrol Edge 10-60 (standard oil change kit from ECS) Brakes: Motul RBF-600 Trans: Redline MTL Diff: Redline 75-140 Blackstone reports available Brakes: Brand new stock pads Front rotors at 26.8 mm / 25% (new 28, min 26.4) Rear rotors at 19.5mm / 70% (new 20, min 18.4) OEM Accessories: Floor mats 2 tow hooks (coated with red plasti-dip) Foam battery accessory tray Air pump Road triangle and mounting straps Tool bag Car cover (never used) Trunk liner Parts: All original parts included (trunk trim, mufflers, shocks, springs, control arms) Rogue Engineering X Pipe DKF Section 1 with street & race cats, coated DKF muffler hanger VAC Motorsports seat mounts PFC08 front pads @ 50% Any other bits and bobs I've forgotten also included. |
09-15-2021, 11:18 AM | #3 |
Backroad Warrior
64
Rep 112
Drives: Z4MR
Amazing looking for the miles, should sell quick! You have my dream wheel setup, how did you like those offsets? any rubbing?
09-16-2021, 11:57 AM | #5 |
Rep 195
There’s a bit of rubbing on the outer edge of the wheel liners with the square setup. If I was keeping the car I’d probably have the fenders rolled.
01-18-2022, 11:34 AM | #7 |
Rep 195
The car is now advertised here: https://sfbay.craigslist.org/pen/cto...433696521.html.
I'll also consider selling the extras separately: x-pipe, seat mounts, dkf exhaust, wheels, etc. LMK if you're interested in any of those. |
01-21-2022, 03:17 PM | #9 |
Rep 10
I don't know if you have already sold this tasty ride... but I live locally, and I am very interested. Sorry I didn't contact you earlier, I was on vacation. I just saw it on Craigslist, but now it is gone... sold?
