      07-22-2020, 02:46 PM   #1
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
Refinishing Center Console
Just in case anyone was looking for a nice project to bring some life back to their interior. I experimented with the Rustoleum textured paints. I used “hammered steel” on my faded and chipped grey plastic. 250,000 kilometers will do that. And I’m happy with it. I do not recommend using any oil based paint like this on surfaces that are constant touch points, like the steering wheel trim. In my experience the paint will absorb oils from your skin and discolor over time. But for places like this it is very chip resistant. I know it might not be everyone’s cup tea but there are many different options, and it does make the interior look more fresh!
      07-22-2020, 06:55 PM   #2
Oldmcst
Drives: 2004 BMW Z4 3.0I
VERY nice!!! What did you use on your steering wheel??
      07-22-2020, 07:04 PM   #3
Sterling Roadster
Thanks! I used a regular gloss black acrylic enamel on the steering wheel trim because the oil based paint I first used was all discolored after only a year. For the leather on the steering wheel I used a product called ColorBond. It's supposed to be meant for leather and it's held up well. They actually match factory leather, so I went with BMW Coral Red.
      07-23-2020, 10:17 AM   #4
rsutoratosu
Drives: Z4 3.0i
Wow! I just bought hammer paint for a bunch of stuff at home. for the center, I'm trying carbon fiber wrap and have the colorbond black to put over beige... I have it all out.. just not finished..
looks great!
-Roranji
      07-23-2020, 10:51 AM   #5
Oldmcst
Thank you!!!!
      07-23-2020, 12:45 PM   #6
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
very nice.
it appears you pulled the console apart? I've yet to do that(heard horror stories)...?
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      07-23-2020, 03:00 PM   #7
spurto
spurto's Avatar
Drives: 2006 Silver BMW Z4MR
2006 BMW Z4MR  [0.00]
looks good. I was think about doing something similar in matte black with duracoat. It's a ceramic spay on coating typically used on firearms.
      07-23-2020, 05:24 PM   #8
pungo
pungo's Avatar
I used the hammered steel paint on the frame of my gas bbq grill. I agree, it's tough, chip resistant and has held up well for many years outside.
      07-24-2020, 06:29 PM   #9
Sterling Roadster
looks great!
Nice! Do you plan on painting the plastics and the leather?
      07-24-2020, 06:32 PM   #10
Sterling Roadster
Originally Posted by kaybat View Post
very nice.
I’m not one for taking apart interiors but it wasn’t too bad. I just followed the YouTube video and I think maybe one or two clips broke in the process but nothing is loose. I just recommend having a little tray or bag for all the hardware and clips.
      07-24-2020, 06:34 PM   #11
Sterling Roadster
That is some heavy duty stuff. Definitely better than factory durability.
      07-24-2020, 06:35 PM   #12
Sterling Roadster
I haven’t played around with the other textured paints yet but I’d imagine they are pretty good too.
      07-24-2020, 09:50 PM   #13
rsutoratosu
Drives: Z4 3.0i
have pic ?? my weber after almost 15 years is chipping on the outside.. wasn't sure how much I want to refinish it.. interested in doing
-Roranji
      07-24-2020, 09:53 PM   #14
rsutoratosu
Drives: Z4 3.0i
very nice.
almost thing is ready to break.. i took a few clips off...
https://www.ebay.com/itm/174144741420 this seem to be the most expensive piece.. its the piece under the parking brake, literally the smallest piece around that area i broke 2 of those clip off under.. im going to try to glue them back
-Roranji
      07-25-2020, 09:02 AM   #15
pungo
pungo's Avatar
Sorry, no pics, I gave that grill to a friend and he's still using it 20 years later.
My 11 year old Weber legs and bottom shelf needs some paint touch up. The sharp edges at the top of the legs has some surface rust, as well as the large round hole for the tank in the bottom shelf. I'm pretty sure it's powder coated. I plan to wire brush the rust, use some rust converter, then spray just those areas with grey satin enamel to match the existing paint. Most of the grill is T304 stainless, so no rust there
Sorry for the non-car post, though I've been using this same rust repair method for over 30 years on vehicles. The rust converter will stop the rust and turn the metal into a hard black rust resistant surface.
      07-25-2020, 05:42 PM   #16
Slalom
Slalom's Avatar
Drives: 04 Z4, 18 X3 M40i
2004 Z4  [0.00]
2018 BMW X3 M40i  [10.00]
Looks good. I am noticing some marks in that area on my 2004.
I have used that paint on floor registers - it holds up well and the texture hides surface irregularities.
      07-25-2020, 05:53 PM   #17
rueyme
Drives: red z4
very nice.
What storied have you heard? I've pulled it apart 3 times for various things to work on and it was pretty straight forward actually. The key is take your time and don't force anything lose.
      07-27-2020, 09:08 AM   #18
Sterling Roadster
I think that's basically it, i'm pretty impatient and a lot of people are like me where you get to a point when you think you've undone all the fasteners so you just pull and then you hear a popping sound which lets you know you've broken something. If you've done any interior work with clips and plastic fasteners than I certainly wouldn't call it difficult. Like any car thing just make sure you have the time for it before you start working on it.
      07-27-2020, 09:10 AM   #19
Sterling Roadster
That's sort of the benefit I was hoping for. I've used high gloss paint on interior pieces like the wheel spokes and if there are any sanding marks you didn't sand out perfectly, you will see them all the time. The textured paint also covers imperfections and is very forgiving.
