07-17-2020, 06:24 AM | #1 |
Rep 97
Soft black top cleaning
What would be the best product to use to clean the soft black top?
The top in my car is in great condition but have these small areas which looks like a light sand colour which can not be removed just by using a dry rag and brushing them away. Thanks |
07-17-2020, 10:05 AM | #2 |
Rep 390
Personally.... dish soap. It has degreasers in it and you get a nice foamy action when you agitate it.
Wet the top down and apply liberally. Use a soft bristle brush softly on the top to lift dirt out. Rinse until the roof is soap free. When you go to waterproof the roof I would use the BMW product. The trick to get the best absorption of any waterproofing product is to soak the roof down.... make sure it is saturated and then let start to dry. When it's still damp/wet apply your product then. It will absorb into the roof material. Let dry.... Why... think microfibre cloth. When dry it is absolutely useless to pick up a spill... but get it wet... it will absorb water instantly. Same principle. In this case you want the roof to absorb the product.. not reject it... Simply using it on a dry roof will have the product on the surface of the fabric.
Sent from my smart phone...
07-18-2020, 02:01 PM | #4 |
Rep 127
I've been happy with Ragg Top Cleaner and Protectant. Get the product for a fabric roof. The protectant can leave a greasy surface on glass and paint, so make sure to mask that off or wash it off if you get over spray from applying to the fabric. You can find how to videos online.
07-19-2020, 09:51 AM | #5 |
Rep 108
Drives: 2004 BMW Z4 3.0I
I've used 303 products that work well.
07-20-2020, 10:08 AM | #6 |
Rep 127
I used RaggTopp. After using the protectant, 2 coats, I was told the top should bead water but doesn't. Is that normal or did I do something wrong?
07-20-2020, 11:10 AM | #7 |
Rep 778
I used to use rag top but since i'm redying from beige to black I bought the
renovo convertible top dye with their cleaner, and they also have a proofer after you clean or redye to make it waterproof.. My beige had this black line over it, i figure if i color it black, I'll hide that line
-Roranji
07-20-2020, 01:21 PM | #8 |
Rep 1,106
I'm not going to play "expert" here, but years ago I talked on the phone with a representative from one of the cloth top manufacturers. He may have been from Haartz.
His advice was to wash the top with a cleaner/soap as little as possible (certainly easier if the car is garaged) and to use cloth top specific cleaners and protectants. He mentioned Raggtop specifically as one they approved of. The concern he said was to preserve the stitching. Additionally, he said every time you use a cleaner you strip away any protectant that was on the top and will need to re-apply. Use a vacuum to remove surface dirt and do water only rinses with a very soft brush to get rid of deeper dirt. Your mileage may vary.... |
07-20-2020, 06:20 PM | #9 | |
Rep 108
I just read the previous quote about just vacuuming and no soap when washing. I think that makes good sense. |
